Question about Miele W149 Top Load Washer
Flashing start light
I have a Miele Novotronic W149. I have fille dit with not too much clothing, I checked that already, and when I plug the power in and open water supply the small light next to the START button is flashing. Unfortunally the manual got lost and I can only find a W143 manual in Internet.
I have also removed the water from the washer tube and cleaned the ventil but no success. Any ideas?
  • rafi900 Nov 04, 2008
    Got the same problem.
    Machine is working for about 30 seconds, then stops and the start led is flushing.
Hi, I have the same problem. Did you find a solution?
Posted on Dec 27, 2010
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Sep 05, 2009 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier Plus - no water into the machine
Plug off the wall. Unscrew the hoses that bring water to the machine, check the fine meshes on hose as well as machine, clean out well with tooth brush (not yours), see that pressure is good in your wall socket. Refit carefully, check for leaks.
Feb 26, 2009 | Miele Novotronic Premier 500 Front Load...
Water runs through the waterpump and down to the floor when i start my Miele Novotronic W149
it sounds like the waste pipeis too low lift it up more and thisshould clear the problem
Dec 21, 2008 | Miele W149 Top Load Washer
Miele W149 Top Load Washer Logo
556 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
