Question about GMC Denali 700C Road Bike
Shift Bicycle Gears
What is the correct way to shift bicycle gears?
    Problem Solver:
  • 9 Answers
To shift gear properly, while riding the bike you be sure you are turning the paddles, and shift the gear.
Try to avoid shifting gears while riding standing up, this stress the gear system.
Posted on Oct 29, 2008
How can I reinstall gears after changing rear tire?
I assume you mean to reinstall the rear wheel with the cluster, as there is no need to remove any gears for a tire change. Try the written instructions and pictures at Bicycle Repair Remove Install Rear Bicycle Bike Wheels by Jim Langley and/or one of the videos below. Be sure to first move the right shift lever to the high gear position (should be little or no tension on the shift cable and the derailleur should move all the way outward from center.
Feb 16, 2016 | Cycling
I cannot get my bike to shift through the gears
Web search "shift through the gears" "derailleur adjustment", "how to..." just about anything.
http://www.parktool.com/blog/repair-help
Aug 10, 2011 | Shimano 24 Speed Road Racing Bike Bicycle...
I need a manual for the 700c Ladies Savannah. I need how to use the gears.
Use a search engine and ask that question. "how to shift gears on a bicycle" = many videos.
Jun 14, 2011 | Cycling
Fgnibus@wpa.netNeed to know how to shift gears on a 26 inch hyper wave 21 speed bicycle?
Many vids and tutorials:
Google "how to shift gears on a mountain bike"
Apr 29, 2011 | Cycling
Need instuctions on how you shift
Google bicycle shifting technique, for example:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chainline is as close to straight as possible.
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you
Mar 20, 2011 | Cycling
Gears will not shift
The simple nature in which you state the problem reveals a novice level of bicycle gear understanding.
If you feel up to it, start here for tools and techniques regarding the hardware...
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Google bicycle shifting technique for operational advice, for example:
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency. To demonstrate this for yourself, put the bike in the same combination of gears you
Mar 08, 2011 | Diamondback Cycling
How do I operate the 8 gears on my bicycle as I have no instruction manual ? Please advise. My bicycle is a "Carolina Free Spirit". Thanks
The basics of shifting are these:
1) The big ring and right side of the cassette in back are for speed.
2) The small ring and the left side of the cassette are for high torque, lower speed
3) The middle ring works with all rear cogs.
Avoid crossing left front to right rear and vice-cersa. It cause excess side loads on the chain.
Mar 07, 2011 | Cycling
18 speed bike 6 gear shift works fine 3 gear
If the cable is rusty or otherwise binding it won't let the derailleur fall toward the smaller sprockets when the control is moved. Likewise, it may not even let you move the control in the direction that pulls the cable (bigger rings).
If you don't know much about the process I suggest you read this:
and take the bike to a Local Bike Shop for a look-see and maybe a tune-up.
Mar 16, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
I need an owners manual for the land rider bike. bike takes to long to shift up or down, sometimes not at all. thank you, frank
most bicycle owners manuals do not explain bicycle mechanics and are rarely of any use other than basic bicycle safety. You shifting issue is not specific to your brand of bicycle anyway, as it is simply a mechanical issue. Probably a good cleaning of the drivetrain and re-lube would make the bike shift better. Use a degreaser and stiff brush and water and clean up the chain and the chain rings and the gears or cogs on the back hub. Follow up with a good chain lube.
Jan 07, 2010 | Cycling
Problem with top/low adjustment screws on shimano gears
Forget the screws as those are more for fine tuning once you are close to having it set correctly. Where the shift cable connects to the shifter on the bars you will typically find an adjustment knob (note that you may have the same type of adjustment knob where the cable meets the gear shift mechanism also) which the cable rides in. You will make much larger jumps in adjustment when using this method as opposed to using the screws located on the gear changing mechanism. Best of luck to you on the fix!!
Please be sure to rate this solution.
Regards,
Joe
May 08, 2009 | Mountain Shimano Alivio Front Bike...
GMC Denali 700C Road Bike Logo
815 people viewed this question
Top GMC Cycling Experts
Mike
Arnie Burke
Arnie Burke
Donald Ayers-Marsh
Are you a GMC Cycling Expert? Answer questions, earn points and help others
