Question about Mountain Best Bikes NFL Michigan U 26-Inch Adult Bike
Bicycle Brakes Problem
I think my bicycle brakes have a problem they are making weird sounds when I use them, they stop perfectly well, but I'm a bit afraid that this sound means trouble.
Any thoughts are ideas?
    Guru:
  • 104 Answers
First thing to check with a such a brake problem is your brake pads these are the two cushion like
things that cling to the wheel once you press the brakes.
If they are worn you should change them.
Sometimes after rainy days or riding throw water the brakes also make noise.
Let us know how it went.
Posted on Oct 29, 2008
Installation of disc brakes on a gas bike
Motorized Rear Wheel Disc Brake Kit - YouTube
? 4:18
https://www.youtube.com/watch?v=ZFl5o6OyUTw
Aug 11, 2013 - Uploaded by bicycledesigner
Convert your mountain bike rear disc brake wheel into a motorzied disc brake ... How To Install a 48cc 4 ...
Custom Motored Bicycles - DISC BRAKES, ROTORS, 26 ...custommotoredbicycles.com/disc_brakes_rotors_26_inch_wheels_conve...More Disc Brake Parts for Motorized Bicycles coming soon! ... This lazer cut, offset bracket fitting allows you to install disc brakes on virtually any Bicycle [without ...[Brakes] - engine kit on a bike with disk brakes ' Motored Bikesmotoredbikes.com > ... > General Bicycle QuestionsJan 30, 2013 - Hello, I'm not sure if there is a post about this or if I'm posting in the right section, but I am wondering if it is possable to mount an engine kit on a ...Install engine on a bicycle with rear disc brake. - M
Dec 25, 2015 | GAS Motorcycles
Hi have a ford mondeo having problems with my front brakes when braking the peddle seems to be jumpping back up and i can hear a clonking noise sounds like something lose
I think you may have a cracked brake rotor. Please take it to a reputable shop where they repair brakes. Fortunately, brake rotors are cheap these days.
Aug 01, 2014 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Adjust brakes
Brakes are very frustrating. Seeing how you have played around with these I am sure you already know where the adjustments nuts are. The one thing that is often overlooked by myself as well is the actual positions of the pads themselves before adjusting. The have been known to slip. Adjust those to the rim first and then adjust the calipers. I think you will have better luck with them this time.
Sep 03, 2012 | Columbia Sportswear Columbia Northway 26...
Mountain bike front brakes will not return to original position
Perhaps some adjustment is necessary or there is so much friction in the cable housing or brake bosses that the spring tensiion of the brakes can't overcome it.
Search engine of your choice "adjust brakes on bicycle" or "service bicycle brake cables".
Jul 31, 2011 | Cycling
I have a 24" bicycle
Are you able to adjust the spring tension on the brake arms? It sounds like there it too much friction in the cable, try lubricating the cable.
Feb 27, 2011 | Cycling
This bick sucks and you have to have an
That's fine as long as the wheel spins freely and not stopping the wheel from turning. You can loosen the nuts a bit so it would have some play. If it does affect the wheel from freely turning then you've set the tension to much. It's the same concept with automotive brakes using a floating caliper, one side will release more than the other although not hindering it's operation.
Apr 30, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
Adjust rear hand brake on Mongoose 20 inch bicycle
Here is the perfect site for you:http://www.bikeguide.org/how-to/brakes/brakes.php They're called gyro brakes by the way.
Aug 27, 2009 | Mongoose 20-Inch Gravity Games BMX...
How do I balance the response between my front and back brakes?
Front brakes are going to produce about 80% of your stopping power. On a bicycle (or motorcycle) if you apply both brakes at the same time and the back tire skids, you need to let up on the back brake and increase the front brakes. This "mix" may change based on road conditions (downhill, dirt, etc.)
Aug 23, 2009 | Cycling
I don't know how to turn it on
You push down on the black pedals until it starts to move forward. Remember to actually sit on the bicycle first, preferably facing forward, and on the soft part that looks as though it can accommodate a buttocks. Balance is key, because both of your feet will be busy making circular motions on the pedals, so it is balance that will actually hold you up. Do not try to balance without moving forward, because this could lead to a catastrophic fall, possibly chipping a tooth or some other such disfiguring contusion. Stopping is equally important. Do not simply pitch yourself from the moving bicycle, as this could lead to additional contusions and abrasions. Reversing one's feet in a backwards peddling motion can stop some bicycles, although if you hear a clicking sound instead of stopping, yours is not that kind of bicycle and at this moment you would prepare yourself for a spectacular crash. If a metal portion of the bicycle makes contact with the asphalt and you are going fast enough, you may even see an array of sparks. You would have at this time determined you have the type of bicycle with hand controlled brakes. Good luck, stay safe, and happy cycling.
Jun 11, 2009 | Cycling
Bicycles Brakes Tightening
Are the brakes center pull or side pull?
Center pull would have a nut directly in the center of the brake. Now go to the brake lever on your handle bars and tighten the turn screw where the cable handle is. Keep turning the nut till your brakes grip.
If you have side pull brakes. Then where the cable meets the breaks. Their is a nut that the cable slides through. Loosen the nut and firmly pull the cable till its tight and retighten the nut.
Nov 03, 2008 | Cycling
Mountain Best Bikes NFL Michigan U 26-Inch  Adult Bike  Logo
493 people viewed this question
Top Mountain Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
