Televison & Video Logo
Posted on Oct 29, 2008
I have a Daewoo DRT-10, DVB-T DVD RECORDER under 2 years, It will no longer record from the EPG application, the screen keeps going blank, I have to then unplug it replug it and switch it back on. It won't play (anymore) pre recorded region 2 dvd's and when using the remote control, mixes up buttons. for example if I press no 2 it switches off or chooses another channel or application. When using the EPG if I'm moving through the channels it will skip days or instead of being 1 hour view skips to 2 hour views. I have not moved it in anyway so have not damaged it. Hope you can help. Sophie
5 Related Answers
Anonymous
  • Posted on Aug 19, 2008
SOURCE: Romote control not working
1. The owner's manual is available online:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
Download the manual under Operating Instructions.
2. To remedy "SET1" problem, Press 1 & Enter at the same time.
Hope this helps
Anonymous
  • 273 Answers
  • Posted on Aug 25, 2009
SOURCE: Cannot view / record from AV input - no option on remote
look for a source button or 1 with a square with an arrow pointing in to it both are types of av button
Anonymous
  • Posted on Sep 06, 2009
SOURCE: I have purchased a Teac HDR2500T video recorder. I
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Anonymous
  • Posted on Jan 15, 2010
SOURCE: We have a Daewoo DC DVB-T HDD/DVD Recorder. We
menu--hdd playlist--ok -select recording--select play then scroll down to dubbing--ok --add or scroll down to start dub.
Its not a problem
Anonymous
  • Posted on Mar 02, 2010
SOURCE: panasonic dvd recorder remote when pressing any
Try Holding Enter then press 3 for 2 or more seconds. Pressing both together will not work.
Flashing red cassete light mean
So.... Who uses a VCR any more. They are ancient history.
They don't last forever so perhaps it's time to think ahead....
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. I got him a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Main Features:
DVB-T Twin Digital Turners
DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
2.5" Sata Hard disk: 500GB
Time Shift Function (Pause live TV)
HDMI Digital Output
Digital Audio Output
CVBS/YPbPr/SPDIF connectors
Supports TV formats 4:3 and 16:9
Electronic Program Guide (EPG) up to 7 days in advance
EPG searching and auto download
Recorded program edit
Parental Control
Copy files from internal HDD to external HDD
Built-in WiFi
Network Playback
USB 2.0 Interface
Cheers
Good Luck
Maybe you can get a little more life out of that VCR still
Panasonic troubleshooting
I guess you mean a Set Top Box to convert digital TV transmission to old analog TV. Choose the correct video format for your screen.
Ah... Perhaps Your recording at an old standard & passing it to a modern TV or HD TV with the digital output from 1080 HD to 720 or lower still.
OR
Get a Digital Hard Drive recorder.....
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
Main Features:
HDMI Digital Output
Parental Control
Built-in WiFi
Network Playback
USB 2.0 Interface
2answers
Bush dvr3006 will play audio disks but wont play any dvd ! just says load for ages then turns off or no disk ! help please ?
These are the formats your DVR will or will not play.
  • Blu Ray Playback: No
  • Blu Ray Recording: No
  • Compact Flash Card: No
  • DTS Decoder: No
  • DVB-C: No
  • DVB-S: No
  • DVB-T: No
  • DVD Audio Playback: No
  • DVD Player / Recorder: DVD Recorder
  • DVD+R Playback: Yes
  • DVD+R Recording: Yes
  • DVD+RW Playback: Yes
  • DVD+RW Recording: Yes
  • DVD-R Playback: Yes
  • DVD-R Recording: Yes
  • DVD-RAM Playback: No
  • DVD-RAM Recording: No
  • DVD-RW Playback: Yes
  • DVD-RW Recording: Yes
  • DVI Interface: No
  • DivX Playback: No
  • Double Layer Recording: No
  • Electronic Program Guide (EPG): No
  • Ethernet: No
  • Firewire IEEE-1394 Interface: No
  • HD-DVD Playback: No
  • HD-DVD Recording: No
  • HDMI Interface: No
  • HDTV: No
  • IPTV (Internet Protocol Television): No
  • Integrated VCR: No
  • MP3 Recording: No
  • MPEG4 Recording: No
  • Memory Stick: No
  • Multimedia Card: No
  • Number of Scart Interfaces: 1
  • PCMCIA Interface: No
  • Progressive Scan: No
  • Real Dolby: AC3
  • Secure Digital Card: No
  • Show View: No
  • Smart Media Card: No
  • Super Audio CD Playback: No
  • Super Video CD / Video CD Playback: No
  • Table / Portable: Table
  • USB Interface: No
  • W-LAN Connection: No
  • xD-Picture Card: N
I don't know how to tune the digital channels in my vcr. I can automatically tune channel 2, 9, 10, etc but not 7mate, 99Go etc
If your unit does not state DVB anywhere, either in the manual, or on the unit itself, and there are no options to tune in digital services via the menu on screen (as well as no EPG), chances are the tuner in it is analogue only, hence why you cannot tune digital channels in it. To receive all SD/HD digital channels, you would need to connect an external set top box to the recorder's AV inputs, and record/view them that way. (Set top boxes are cheaper than upgrading TVs and DVD equipment in many cases).
The only positive point here is it didn't cost you a workshop repair fee or a new unit - the user manual as a pdf for this model is available on FixYa if needed.
1helpful
Its not a problem
1helpful
Polaroid dra-01601a hdd to dvd recording
You will have to split the title and record on more than one DVD. The default speed is SP, that is 2 hours of recording. If you want to record longer programs, go into setup and change the default record speed to one of the other settings, for example: SP+ which is 2 1/2 hours or one of the other longer record settings. This DVD burner will only record at the same speed as you recorded to the hard drive. You can also edit out the commercials by using segment. Go to the title you want, press the right arrow, scroll down and select segment. When you want to start your edit, press enter. when you want to stop the edit, press enter again. You can use your right arrow to skip forward 30 seconds and your left arrow to skip back 10 seconds if you went too far when editing. You will see where your edits are on the screen by the darker color. Do this through the whole program. When you record to DVD, the commercials will not be recorded. Hope this helps you.
2answers
Dvb t vcr/dvd recorder drvt 43 freezes after being plugged in
I have the same problem. Telephoned Daewoo and they said that there was a download available that will fix it. Unfortunately, the contol keeps freezing so I can't do this. Therefore, I have contacted the retail supplier and they are sending a replacement and also letting me have relevant info to send the defect one back. Hope this helps.
How do I use my URC remote control with the daewoo DRT-10 freeview tuner/dvd recorder? What are the codes I would need?
i see one time website with codes for urc send me all deitels of your urc i try find something for you.
1helpful
Trutech DRT-S810 Does not power on
known issue with this unit. The power supply used in this unit is below quality and is often the cause of power not getting to rest of the unit. The company is from china and does not have a usa warranty service since they operate under the daewoo umbrella.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
