Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu Siemens lap top AMILO l1310G
Dear Sir,
The LCD panel becomes blank and white lines flash. This happens ocationaly. But the external CRT monitor connected to the LAP top works.
I shall be extremely thankful if you can suggest the remedy.
Best Regards,
  • 1 more comment
  • Anonymous Dec 10, 2008
    I have the same problem and i own the same model fujitsu siemens laptop.
    I suspect that the FL inverter which supplies video the laptop screen is faulty, or it is driver issue. But there are no driver updates as far i know that have dealt with this problem. I had this problem for over a year and my warranty expired then the problem started.
  • A Riot Jan 18, 2009
    I've only had my lap top (same model) since August 08 and it has started to flicker, not amused.
    Any solutions?
  • azrael716 Mar 28, 2009
    We have the same problem, could recreate by moving cable harness between the motherboard and teh inverter / display. Computer shop said its the screen, but the fault canbe recreated by turning the cable. Have been unable to identify a spare cable on the net so far. Problem also started last August 2008!
Screen turned all white: I had the same problem, I reseat the cables after checking for continuity on the wires. I re-installed the system through the CD backup. The problem seemed to go away for several days. then one night on standby I could not wake it up, or so I thought, I reboot, nothing. I pulled out the battery then booted up, it went through bios then on Vista GUI screen it went white then blank. I ported the video out at the back to a HD monitor, nothing. it is not the screen, must be the video cable if not the built-in video sync. I brought it outside to see if there is a faint signal on the screen. If the FL is busted, simply nothing.. I returned it back to its package. 10 years from now Maybe I will have another problematic laptop and thus isolate the real problem.
Posted on Feb 09, 2012
Try reconnecting the LCD cable on the back of the screen. You have to open the screen in order to access the lcd cable.
If this won't work, the cable is most likely not working correctly.
Posted on Feb 22, 2010
Fujitsu instructions
these keys r function keys and need to be pressed while holding the FCT key - some computer r different
Aug 14, 2014 | Fujitsu Siemens Amilo Pro V2055 V2030...
Why lines only come sometimes in lcd fujitsu siemens amilo laptop
Probably a loose connector between the motherboard and the screen - if you are not sure what you are doing this one is best left to service!
Jul 02, 2014 | Fujitsu Siemens Amilo L1310G Laptop...
3 beeps 3beeps 1beep
The beep codes indicate the battery is discharged - and needs to be recharged. A manual can be downloaded at
Nov 22, 2013 | Fujitsu Siemens Amilo Pro V2055 V2030...
Screen total black out
turn your lap top off, take out the battery, hold your power button for 30-60 secs, turn it back on and PRESTO!
Feb 13, 2012 | Fujitsu Siemens AMILO Pro V2010 Notebook
Only ocationaly rebooting the system. most of the time it says operating system not found.what could be the reason.Please help.My system Fujitsu seimens amilo pro 2065
Hey, either a hard disk corruption or some missing/corrupt files - Solution: Format and reinstall your Operating system. If that doesnt work, maybe you need a hard disk replacement.
But before that, are you sure you haven't connected any USB drives or flash drives or an external hard drive when you computer boots up. That could be the reason. Solution: disconnect any such device before you start your computer.
May 21, 2011 | Fujitsu Siemens Amilo Pro V2065 Laptop...
Dear Sir; I havent got my lap-top( AMILO Notebook Pa 3553 model 52242 ) s web-camera,please send me this lap-top s web-cam s download,my e-mail is, Yours sincerely and...
best to choose a compatable device, a lot are just plug-and-play these days,goto your manufacturers site and find list of compatable devices this is the easiest way,foreward.--good luck!
Davey Snake!
Oct 24, 2010 | Fujitsu Siemens Computers & Internet
Fujitsu Siemens Amilo - Won't boot
could be hard drive failure,or you might try to reinstall windows before bying a new hardrive,but before any of that go to the BIOS and make sure that the boot order is right usualy hard drive first
Apr 05, 2010 | Fujitsu Siemens AMILO Pro V1000 Notebook
My siemens amilo d7830 the screen is showing blank. any idea please
Fn+F8 then it might be working.
If that does not work then try;
Dec 30, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Amilo pro v2000
Here'e a link where you can download all the drivers and software for you Fujitsu Siemens Amilo Pro v2000
Nov 05, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Blank screen
Sometimes an easy solution to this is to turn off your laptop completely, remove the power lead from the socket and the laptop, then remove the battery, leave for a couple of minutes and then try again.
If this does not work, then you are into the realms of programming / restoring.
I hope this helps you, Chris
Oct 27, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
1,321 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
