Icons need my icons back on screen for embarq
  • 49 Answers
GO TO SYSTEM RESTORE AND SELECT CHECKPOINT TIME BEFORE U HAVE INSTALL NEW ICONS AND ATART TO RESTORE OR
DOWNLOAD UNINSTALLER SOFTWARE TO COMPLETE UNISTALL ICON PACAKEG
Posted on Nov 05, 2008
I have a Belkin mdl. f5d8236-4 v2that worked great
if ur internet service is embarq then u need to first unplug the modem from the router
because the embarq modem and belkin has the same ip address
so jus connect the computer alone to router and power on the router
then login to router setup page with 192.168.2.1 then on left side click on "LAN SETTINGS"
IT WILL ASK U FOR A PASSWORD THEN LEAVE IT BLANK AND CLICK SUBMIT
then change the lan ip to 192.168.5.1 and then click on apply changes then go ahead and click on OK
once it is done then plug ur modem to the router then unplug the powercord of router then plug it back again --- then u can have the modem and internet light to be solid --- then u can access the internet
Jan 27, 2010 | Belkin F5D8236-4 Router
When trying to install gets message cant find internet trying to hookup to embarq 660
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi there! This are some steps on how to setup your modem/router
New DSL Modem Available
Embarq is now shipping an updated version of the DSL Modem called the "660". It is smaller than the older model (645) and is much easier to setup.
A few years ago, Sprint/Embarq changed the way their servers communicate with the DSL modems. The new method is called DHCP, which is how the 660 modem works. The older 645 Modem used "PPPoE". So it's best to have the new 660 DSL modem.
The older 645 modem also had the same default IP address as the Linksys Router (192.168.1.1) - so you had to change one of the addresses to make them work together.
The new 660 DSL modem uses 192.168.2.1 as the default IP address. This does not conflict with the default IP address of the Linksys Router (192.168.1.1). Note that if you had changed the Linksys Router IP address to 192.168.2.1, then you will first need to reset it back to the default address 192.168.1.1.
If you call Embarq and request the new 660 DSL modem they will sent it to you at no cost. When you install the 660 DSL modem, you need to be sure that you power down the old 645 modem amd leave it off at least 1 hour before you plug in the 660 DSL modem. The Embarq server needs to "forget" the old 645 modem. After an hour, all you should have to do is plug in the new 660 modem and everything should start up properly.
Call Embarq Tech Support 1-877-646-3282 if you have problems setting up the modem. If the Internet Lights does not come on after a few moments - then call Embarq Tech Support.
Aug 15, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
I got Embarq DSL a few weeks ago, i can get online for a minutes then the internet will go out, i have to reboot the modem several times before it will come back up, ive tried changing where the modem and...
If Embarq cannot or willnot help you, drop them and get another service.
First connect your modem directly to the computer to isolate the problem. If it solves problem then difficulty is in the router. Then contact the router manufacturer.
If problem persists the Embarq should help you.
Apr 29, 2009 | Dell Microsoft Windows XP Home Edition
I have a laptop comp i just got a desk top comp i have embarq broadband internet which comp do i pit the cd into to install and which comp do i hook up the embarq box to?
It sounds as though you will need to get router to allow the sharing of the Internet between the two computers. Using a router makes it much easier to share an Internet connection between multiple computers. You would connect the Embarq box to the router on the WAN port, and then connect your computers to the LAN ports of the router. You may also want to get a wireless router in the event your laptop has a Wi-Fi connection.
Oct 06, 2008 | Computers & Internet
Embarq online security is causing a problem with my Quickbooks programs it says the security system is interfering with ActiveX controls.
Hello cncurfman,
After reading your issue, I would recommend you contact our RescuIT team at 866-626-8154 or visit their www.embarq.com/rescueit page for more information. This is a team that can support pc concerns with conflicting software.
Thank you for using Embarq, your complete communications solution.
Lamont L.
Embarq Customer Support
embarq_lamont@embarq.com
For additional support please visit www.embarq.com/freetv or call 1-877-646-3282
Voice | Data | Internet | Wireless | Entertainment
Aug 11, 2008 | Computers & Internet
Can't get a connection back on my ISP (embarq).
If you have dial-up, go to tools>internet options>click "always dial my default connection" or if you have broadband click on "Never dial a connection" These settings are found in Microsoft Internet Explorer 5 or higher.
Apr 11, 2008 | Dell Microsoft Windows XP Home Edition
Acer desktop 90 days old
have your service provider check your router and WAN conection. Also request to look into the airial cable
Mar 22, 2008 | Acer ALN 325 Network Adapter
PSP
right click on wireless icon on taskbar,go to configurations and chose what you want there.look around and open all you find till you come to the wep .
Dec 28, 2007 | Belkin Wireless Pre-N (F5D8230-4) Router...
All downlods stall
try disabling windows XP firewall...
May 20, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Computers & Internet Logo
David Payne
David Payne
