Question about Dryers
Drum wont move till i give a push - Dryers
    Genius:
  • 1,122 Answers
Your motor is to weak to turn drum,you can go on ebay like i do and get a motor for around $30,just put the make and model number in and see what pops up,let me know how you do-mike
Posted on Oct 29, 2008
Why wont my 50 hp mariner start ?
renew spark plugs,mix up some fresh fuel,put choke on,throttle set at just above idle,pump up fuel bulb by hand till tight,put outboard in a water drum,try pulling or turning on starter till it fires,then push choke in and restart
Jul 25, 2014 | Mercury Gear Set, Complete, Mariner, Force...
Suzuki eiger
is that a semi-auto or manual clutch?
Nov 02, 2013 | Motorcycles
The machine fills with water but the drum wont turn. the machine drains the water until the next cycle, but the drum still wont turn
Tony could you give me a little more info? Is this a machine you just got or one that's been running just fine till now? Is it a top loading machine or a front loading machine? Because if this is a top loading GE for example i'd say, see if the agitator spins freely in both directions if it is and if it does i'd give you some instructions on an easy repair. However if you said it's a whirlpool top loader i could probably give you a link to a youtube vid that'll show you step by step how to fix it. Etc. Etc. Thanks.
Jan 13, 2013 | Washing Machines
How to remove rear brake drum on a toyota tazz 2004 model
3 methods: Sometimes you have to get to the adjusters from behind the drum, and turn the brake shoes inward, so the drum slides past them. Sometimes tricky to turn the adjuster wheel inside the drum (look for a rubber plug to remove and see the adjuster.) A couple of small screwdrivers will be needed, one to turn the adjuster wheel, and one to push a little clip away from the adjuster wheel so it can turn-tricky till you get the hang of it.
2. Best way to remove the drum, if your drum has two small drilled and threaded holes just out from the drum's center hole and opposite each othe on the drum-those holes are for drum removal. Find or buy two short bolts that will fit the holes and turn them in evenly. The bolts will contact the backing plate and force the drum outward. Usually you need to get it just moving a very little, then it will come off.
3. As a last resort, you can always heat the drum with a propane torch till the metal expands from the heat (15 minutes?). Tap it all around with a hammer, it should come free. Often what holds the drum fast is the center hole can have a rust build-up-sort of tacks itself to the center hub.
Nov 17, 2012 | Cars & Trucks
Hi my hotpoint dryer wont turn please help
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to turn.
Apr 25, 2012 | Washing Machines
Did complete brake job on 1997 Ford Escort wagon no abs rear shoes, drums, lines, wheel cylinders,even changed the block at the rear were the lines go in & out of. Front lines hoses pads, caliplers...
is brake pedal hard to push down without engine running ,if so proceed to step two and thats to start engine and then push on brake and if pedal softer to push then the servo is working ,now if excessive pedal travel with engine running then remove the rear drums ,make sure the outside lip is cleaned out and then adjust the brake shoes manually till they rub when you turn the drum ,this will cure it but remember that it has to bed in of course new pads brake disks ,new shoes and drums it has to bed in so give it a chance .
Aug 24, 2011 | 1997 Ford Escort
Kenmore electric dryer makes a loud noise when start button is pushed, the drum wont turn and when it does turn it will stop within minutes
this is common for a bad belt or bad belt tenchioner you should replace the belt and clean the trenching when their is a stuck tenchioner the motor will flop and make a bang sound the drum will turn for a couple mins or more till the motor loses tenchion and belt slips
Aug 30, 2010 | Kenmore Dryers
I just got a 06 Gsxr 1000 and the speedometer is stuck in kph. How do I get it back to mph?
press and hold the milometer button which resets yr mileage or push in and twist and make sure the ignition is on or it wont work bud
Aug 10, 2009 | 2006 Suzuki GSX-R 1000
My hand brake does work when I pull it up even when I ajust it
slacken cable right off ,then remove the rear brake drums and using a small angle grinder clean the lip that forms on the drum as this will stop you from adjusting the brakes right up when you push the drum back on.next check condition of wheel cylinders and ensure their is no leaks and cylinders move when pushed in and not seized.then using a conventional oil can and not that silly spray junk lubricate the pivots and anything that looks like it should move.Then adjust the automatic adjuster till the brake shoes are just touching the drum when you offer it back up and spin it.Next adjust handbrake cable till you have 3 clicks on it .job done
Feb 01, 2009 | 1988 Mitsubishi Pickup
Changing a dryer belt
unplug the drier pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .and put yours on
May 22, 2008 | Dryers
Dryers Logo
55 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
