Question about kawasaki 73026-9 KDX126FS Dual Suspension 26 Inch Mountain Bike - Black
Bicycle Chain Problem
Having a problem with my bicycle chain, it keeps falling all the time, this is very aggravating, don't know how to fix this.
Please post here ideas that might help me fix my Bicycle Chain problem.
Thank you.
  • papkec May 11, 2010
    Is this a multiple or a single speed bike?
Losen your back wheel pull it back to words the bak of the bike make shore the wheels strete and not tuching the framekep pulling it back and you will c that the chain is tight wile your holding the wheel bak as far as it gose then ask a perant or sum1 to tighten the wheel bolts
hope that helps...
Posted on Jan 22, 2009
This is probably because your chain is too loose try going down to your local bike shop and ask them to remove a link or if you have vertical dropouts you should buy chain tensinors.
hope it helps.
Posted on Jan 18, 2009
    Problem Solver:
  • 7 Answers
Have to loosen back wheel use some kind if wedge with the bike upside down put the wedge between the frame and tire pull on the wedge and after it feels tight tighten the nuts back on the wheel just make sure tire is straight before u tighten
Posted on Dec 17, 2008
  • 4 Answers
Disregard my 1st question I now see what modle of bike this is.
Your problem is with your limit screws on the deraileur. There should be 2 srews on your dearailuer; these screws limit the travel of the deraileur so it will not push the chain off. I can't tell you which screw adjusts which limit because deraileurs are different from one another; but I can tell you if you figure out which screw adjusts which limit you screw it in until the chain doesn't shift off the gears. Be careful if you adjust the screw in too far you will not be able to hsift to all your gears.
Posted on Nov 05, 2008
    Problem Solver:
  • 9 Answers
Your chain problem is probably because your chain is not tightened and maintained.
You should clean your chain after a ride, and oil it (very little oil).
Good luck
Posted on Oct 29, 2008
You might want to invest in a set of chain tensioners. you can get themanywhere that specifies in bike sales and service.
Posted on Dec 12, 2008
How do i fix the rear sprocket on my huffy rock it bicycle
on all single speed bikes, it has been my experience, that chain tension is the reason for the chain to come off, try tightening it again, since this seems to keep happening the chain may be stretched out now and replacing the chain and getting it tight should solve the issue.
Apr 30, 2014 | Huffy BMX 20" Boy's Rock It Bike
How to fix my bicycle
Make sure that the tire and the crank sprockets are "in line" (the same plane). If the wheel is not lined up straight, the chain will easily fall off. If you have a bicycle with gears, you'll want to be sure that the derailleur is tweaked correctly too.
Apr 30, 2014 | Huffy 20" Rock It Boys Bike, Black/Orange
How to fix my huffy rock it bicycle
Sounds like you may not tightening it down tight. should have about 1/2 play in it. If that dont do it you might look at the sprockets ( bent or missing teeth ) or may need a new chain. Hope that helps you. Good luck. Vern
When Coasting chain rolls backwards and falls off
Chains usually fall off because the chain is not tight enough. With the bike sitting upside down on the seat and handle bars the nuts on the rear axle should be loosened and the axle moved rearward so the chain tightens. When it is tight the nuts can be tightened. In addition to having a tight chain the rear axle nuts adjust the alignment of the wheel to the frame. You know you have it right if both the chain is tight and the tire closest to the crank is centered in the frame. The nuts should be tight enough so they don't allow the axle to move when you ride it. I hope this helps.
Aug 16, 2011 | Schwinn Windwood 26 Men s Cruiser Bicycle
My sons chain won't stay on and it falls off when
Being a physical problem and lacking any clues about the bike we'll need you to observe and judge what is really happening to make the chain fall off. Use a search engine for "bicycle chain falls off" to get some ideas and guidance on identifying the dysfunction, then the fix(es).
Aug 09, 2011 | Cycling
The chain keeps falling off the largest three sprockets on the cassette, when pressure (e.g. during a climb) is applied.
Falling off - where to? Or just slipping?
Perhaps the indexing adjustments or worn teeth or chain are the cause.
Mar 19, 2011 | Shimano Dura Ace 7800 10 Sp
My grandsons bike chain broke. Went to the store to buy a new chain. On the back of the package it said I needed a chain rivet extractor and of course, the store didn't carry that tool. How can I fix...
You should go to a bike shop, they can sell you a master link, and keep your own chain. Is your grandson's bike a 1 speed or a multi speed bike, if it is multi then you need a chain tool. Bike shops can do the job cheaper than you can buy the tool and it will be done right. Take the chain back to the store that didn't carry the tool.
Sep 18, 2010 | Bell Sports Bell Uni Chain Bicycle Chain...
Chain keeps fallin off!
Does the rear wheel go on such that you can adjust it to take any play out of the chain? If so, turn the bike upside down or put it on a bike stand. Loosen the back wheel and pull it so that the chain is tighter and then tighten the wheel. There are other possible causes but I suspect this since you recently removed the wheel. Also I'm not sure how often the chain falls off. If this doesn't work, ask again and let us know how often its coming off. Good luck!
Mar 15, 2010 | Schwinn Windwood 26 Women s Cruiser...
kawasaki 73026-9 KDX126FS Dual Suspension 26 Inch Mountain Bike - Black Logo
696 people viewed this question
Top kawasaki Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a kawasaki Cycling Expert? Answer questions, earn points and help others
