Question about RCA F32650 32" TV
RCA Model f27650 High pitch squeal
RCA Model f27650 TV is about 2 years old, when plugged in there is a high pitch squeal and a clicking noise from rear of set , no picture or sound. Opened rear of set and transformer was hot to the touch. Any help would be greatly appreciated. Thanks in advance! TV does not come on I hear a squeal coming from the back
  • cherrera1 Feb 13, 2009
    My RCA tv is making a high pitched squeel. My son put coins in the back slots of the tv, could this be the reason? I cannot fix this myself, is this a feasable repair if I take it to a shop?
  • 749 Answers
The high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Posted on Oct 29, 2008
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
When my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
May 01, 2009 | RCA 36F530T 36" TV
Trouble turning on tv. High pitched noise/click.
The mainboard might have some loose components, or cold solder , or may be the filter capacitors are becoming faulty. Yes it is worth repairing, bring it to the repair shop. Cheers.
Nov 25, 2008 | RCA Televison & Video
RCA F36650 36" TV
is the squealing noise from the back of ur set , if so it is ur flyback transformer
May 29, 2008 | RCA F36650 36" TV
High pitched squeal
What an RCA I hope you didn't pay mutch for this, NO it's not the part of the board were the cable goes in, the so call squeal is the horizontal oscilation of the coil you hear, narmaly it is at the rate of 15747 hz, to find your problem you most open the back cover, and while the ptv is on try to hear by insolating the noise were it is comming from with a credit car or something that will hide the section you trying to find, it will be a transformer or a coil, close to the power supply or the horizontal defflection section. To fix your problem well that's all a different game, you must contact me via e mail at rlandry@vianet.ca
I hope this help.
Meanwhile keep on smilling, life to short
What about Bob
Bob
Timmins, Ontario
Feb 24, 2008 | RCA P46921 46" Rear Projection Television
52 in RCA widescreen HDTV Monitor
high pitched squealing noise >> im thinking is the color wheel which will also give you the yellow color, don't know if that would also cause your screen to blank.
mcm carries RCA
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
High Pitched Noise on TV
THIS NOISE IS NORMAL. IS THE DEGAUSING COIL
Sep 16, 2007 | Televison & Video
RCA 27r410t 27" won't turn on,just makes high pitch noise
that high pitch is comming from the flyback replace the flyback and the HOT.and you will restore back the life of your tv.good luck.
Jun 04, 2007 | RCA 27R410T 27" TV
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
RCA F32650 32" TV Logo
288 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
