Question about DeLonghi Pinguino PAC-02 Air Conditioner
Pac 36.unit dead.need wiring diagram
I got pinguino super split delonghi pac 36 that is completely dead.there is power on unit only pump works if micro switch is trigard.Can jou help me with a wiring
You need drain the water and then function normally.
Posted on Oct 02, 2007
  • 1420 Answers
SOURCE: delonghi pinguino pac l90 manual
Here you go!
Posted on Aug 19, 2008
  • 66 Answers
SOURCE: DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Posted on Feb 19, 2010
  • 66 Answers
SOURCE: i own a delonghi pinguino eco PAC T120 and when i
Probably, the
"ft" means to check the filter. If your filter has not been cleaned in a while, it cannot breathe,and operate properly.
  • 5 Answers
SOURCE: Looking for a user manual
here ya go....
Posted on Oct 09, 2010
Hi, I have a DeLonghi pinguino PAC CT110. The circuit board is broken. I turned the on button on with the casing off, right on the circuit board. There is no power. Everything looks fine. What can be the...
If your unit is totaly dead after plug power & turn on, no one of Led-s is iluminated or no "bip" sound generatet you have with alimentation cirquit, maybe the primary of transformator is burn. The pcb work with 12 V so you can conect a new transformator.
if the leds go on and you need to see if some error mesage is .
May 22, 2014 | DeLonghi Pinguino PACL90 Portable Air...
Air conditioner Pinguino PAC CT110 DeLonghi. I need the manual for the owner. THANKS
Try with this site; -
Dec 29, 2010 | Heating & Cooling
Selonghi pinguino super pac 26 works fine for about 20 min the turns off with the warning light that is the same as the power light flashing. How can this be fixed as apart from that it is fine. I did...
I had the same problem. Except it only lasted 10mins. It turned out that the water pump was not moving enough (any actually) water to cool down the heat exchange unit. The unit turns off if it overheats. I pulled the back off and realised that the water resevoir container was full of lime & calcium scale. Some of that had obviously got into the impeller blade in the water pump. I removed the water pump & hose and discovered a lot of hard crud in there. Cleaned it out, reassembled and hey presto the water was flowing agin and the heat exchanger was happy. Problem Soved. Anthony
Nov 21, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Exhaust Hose DeLonghi PAC-210U replacement
You need to go here
Feb 14, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
DeLonghi Pinguio Pac 45
1. Clean air filer every 2 weeks.
2. clean ACCU and FCU every 3 months.
3. check and re-tight all electrical connection every 6 months.
Jan 10, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Brewer in dire need
this is gold, is strange to heard that one fails, but have to happen, dont leave regular people tuch it, get a good tech, it seems to have a sort problem, I know the compressor are ok becouse it have dobble protection, must be a capacitor problem..good luck
Aug 08, 2006 | DeLonghi Pinguino PAC-GSRU Air Conditioner
DeLonghi Pinguino PAC-02 Air Conditioner Logo
404 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
