posted by Vice on Sep 05, 2006
I have Acid Pro 5 and would like to record live music from an instrument... A am somewhat familiar with Acid Pro, but I cannot seem to get the rcording to go through on 2 channels. I am running my audio through firewire, on a Prosonus Firebox. Any ideas as to why I only get one channel when I record?
1 Other User Has The Same Problem
Comment by MarkDono, posted on Mar 19, 2008
Me too. I have a Presonus Firebox and can get only one channel (left side) to record in Sony Acid Pro. The same box works fine in Cubase LE. Perhaps the problem is with the Sony software?
Best Solution
posted on Aug 15, 2007
Are you plugging the instrument directly into the computer? If so you only have mono jacks from your bass, guitar so on and so forth! So in channel in only one to record! Try using a stereo microphone and record pointing at the amp. That way you will get stereo through your device. If that is not the problem make sure that the settings on the Prosonus is set to output stereo. And for most check all your plugs to make sure they are stereo inputs and outputs.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Sony ACID Pro 5 for PC
Email this problem
Email this problem
Can you Help with these Graphics Publishing and Multimedia Software problems?
Sony ACID Pro 5 (SACSB5000) for PC
Stuttering and slowing of tempo
The more tracks I record, ACID... Answer This...
Audio Playback problems
when recording audio ( vocals... Answer This...
Repair Service
Find Graphics Pub. Repairman Near You:
