Resistor problem in sanyo
I have a resistor problem in sanyo please help me.
location R617..the problem is the resistor of this tv has change value and can't find the the sign color of the resistor because it the resistor will burn.
  • elvie08 Oct 30, 2008
    this is the the model of the tv ST-21G1
    ST-21G1 is the model # of the sanyo tv..
  • 4,234 Answers
I can not even begin to help without the model number as each model is slightly different. Can you post that please?
Thanks,
Dan
Posted on Oct 29, 2008
What is the value of R617
In order to answer that, one would need to know the manufacturer's name and model number to the CRT you're trying to repair- in order to look up the schematic for that particular unit...and the printed circuit board number that the resistor 617 is positioned on...
Try an online search engine to locate the service/repair manual for your t.v, or go to a local t.v. / electronics repair shop; they'll be able to ID the resistor you'll need.
Apr 08, 2015 | Televison & Video
Tip
Hitiachi Convergence Circuit Resistor Values
This site has been very helpful in diagnosing and repairing my Hitachi 57XWX20B. I recently changed the IC's and a resistor to fixe a convergence problem and had to use the small button on the convergence circuit to get set to return from static mode and enter dynamic mode. I searched everywhere trying to locate the correct resistor values and noticed many other's needing the same information. Here are the results of my research. I obtained some from manuals and others from comparison of the different models. My main focus was finding the values for the 57XWX20B. The resistor values are given in ohms at 1 watt. This means RK42 is a 3.3 OHM 1 watt resistor. RK58 was the problem in my set. It was giving a value of 2.3 and needed to be 4.7. I first replaced the IC's and thought the resistors were all good, but I later noticed my convergence was off. I could manually align it but the magic focus initiation would not save. It gave an overflow error. I bought the sanyo brand of IC's, not the cheap inports and found that if you use a desoldering wick then the repair is easy. The new IC's restored the beautiful color the set had when new. Now it is brilliant as well as converged. My repair cost was:
STK-110 13.00 Bought from local electronic supplier
STK-150 15.00
RK58 3.00 Bought from a local TV repair shop
The elecronic supply store gave me 6 inches of desouldering wick
Total cost: 31.00 Dollars
51UWX20B DP23
57UWX20B DP23
51GWX20B DP23G
57GWX20B DP23G
43FWX20B DP24
51XWX20B DP23
57XWX20B DP23
51SWX20B DP27
57SWX20B DP27
65SWX20B DP27
57TWX20B DP27D
65TWX20B DP27D
DP 23 DP 24 DP 27 RK42 3.3 3.3 3.9 RK46 2.2 1.8 1.8 RK50 2.7 3.3 2.7 RK54 1.8 1.8 1.8 RK58 4.7 4.7 4.7 RK62 2.7 2.2 2.2
on Apr 02, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Sanyo tv model ST21G1 chassis AC5G, will you please help me find the value of R617,power suppy section,thanks.
look for the colour code on the resistor and then look it up on a chart ,different values between a silver band and a gold band but the value is the same its just the % tollerance ,gold band is a lower tolerance
Jan 25, 2011 | Yugo GV Cars & Trucks
How do I locate resistor values?
Click HERE to download service manual copy for free. Download all 12 files and unzip with winrar to get pdf file.
Hope this will help you to find out required resistors value.
Oct 28, 2009 | Hitachi 43UWX10B 43" Rear Projection...
I have a resistor problem in sanyo ST-21G1
it's very difficult to give the exact value of that resistor.,but i can give some tips to find the value of the said resistor .( find how the resistor works, it is a dropping or fusable? if fusable used .47 or 1 ohm resistor if it is a dropping resistor you should make a trial and error .from 100k,10k or 1k.
Oct 29, 2008 | Televison & Video
Magnavox resistor problem
The CRT board is the one that connects to the back of the CRT.
Follow the 200VDC line to locate the burnt resistor, is normally a low value fuse resistor.
Apr 15, 2008 | Philips Magnavox 27MS343S 27" TV
Bush ws7680 tv pcb
Yes it can be replaced if you know the value in ohms and watts and you can use a soldering iron.
Resistors normally blow because of excessive current flow sometimes caused by downstream or upstream components that have shorted out or are being overloaded beyond what they are rated at.
Sometimes (but rarely) they just blow for no reason.
Oct 16, 2007 | Televison & Video
Resistor
http://www.eserviceinfo.com/downloadsm/25749/RCA_24F512T.html
down load the schematic diagram &get the value.
hope this will help you.
Oct 12, 2007 | RCA 24F512T 24" TV
Samsung projection tv convergence problem
I was just working on replacing my stk's and was wondering if you could tell me what value the resistors are? Here is my previous post if you would like to see it. http://www.fixya.com/support/t191186-blue_out
Sep 12, 2007 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
