Computers & Internet Logo
Posted on Oct 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Win xp system restore
Good morning. As the computer administrator, I can't get system restore to work. When I go to system restore, a pop up says I don't have sufficient security privileges to restore the system.
Lalit Varadpande
Level 3:
  • Master 488 Answers
  • Posted on Oct 29, 2008
Lalit Varadpande
Master
Level 3:
Answers
488
Questions
Helped
155533
Points
1377
Do read this article :http://support.microsoft.com/kb/304449 think it should help..all the best!
My laptop has an inactive windows xp on starti g up, i want to remove it and install windows 7 can you tell me how, i need to get past the front screen
I would recommend restoring XP first. If you don't have your XP disc do the following. Then install Win 7.
Restore without installation CD
If you don't have the original Windows XP installation CD, you may be able to use System Restore in Safe Mode if this feature was enabled from the start.
To access Safe Mode, follow these steps:
  1. Turn on the computer
  2. Press and hold the F8 key right after booting
  3. At the Windows Advanced Options screen, choose Safe mode with a Command prompt
  4. Once the option is highlighted, press Enter
  5. Login as Administrator or as any user with administrative rights to your PC
  6. When Command Prompt appears, type this command and hit Enter: %systemroot%\system32\restore\rstrui.exe
  7. Follow the next of instructions to continue with System Restore.
tip
WINDOWS XP SYSTEM RESTORE
System Restore is a tool that takes your computer back to a previously working state. This option is available in Windows ME, Windows XP and Windows Vista. Windows takes snapshots of critical system files, program files and registry settings and stores them as "Restore Points". If ever you should have any problem with your computer, you can "restore" your computer to one of these Restore Points, when your computer was working fine.
Please remember - System restore does NOT have any effect on your personal files such as emails, documents or photographs.
HOW TO USE SYSTEM RESTORE TO RESTORE WINDOWS XP TO A PREVIOUSLY WORKING STATE
In order to perform a System Restore, you must have administrative rights in your computer. If this is your own personal computer, then chances are that you will be having administrative rights in it, however if you are on a network computer, say for example in a computer at your workplace, then you will have to request your Network Administrator to help you.
In order to restore Windows to a previously working "Restore Point" follow the steps given below:
1. Log on to Windows with administrative rights.
2. Click Start, go to All Programs, go to Accessories, go to System Tools, and then click System Restore. System Restore starts.
3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
4. On the Select a Restore Point page, click the most recent system restore point and then click Next.
Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
6. Log on back to your computer. The System Restore Restoration Complete page is displayed.
7. Click OK.
If you have successfully restored your computer to a previous state, and the computer is performing as it should be, you can stop here.
But if the restore process completed successfully and the computer is still not performing as you want, you can either restore your computer to a different restore point or just undo the current System Restore. In order to undo a System Restore, please continue reading.
HOW TO RUN SYSTEM RESTORE FROM THE COMMAND PROMPT?
Many times, you may not be able to run System Restore because your computer will not start up normally. But you can still run System Restore from the command prompt.
  • Click on Start -> Run -> and type in %systemrestore%\system32\restore\rstrui.exe and click OK
OR
  1. Start up the computer in Safe Mode or Safe Mode with Command Prompt
  2. At the Command Prompt type %systemrestore%\system32\restore\rstrui.exe
  3. You can replace %systemrestore% with C:\Windows, if you like
  4. You might have to select the Operating System in your computer
  5. You might also have to enter your username and password
  6. You should have Administrator Rights in your computer to do this.
HOW TO UNDO A SYSTEM RESTORE:
You may have unintentionally restored Windows XP to a previous configuration that you do not want. To undo the restoration, follow these steps:
3. On the Welcome to System Restore page, click Undo my last restoration, and then click Next.
4. On the Confirm Restoration Undo page, click Next. System Restore restores the original Windows XP configuration, and then restarts the computer.
5. Logon to the computer as Administrator. The System Restore Undo Complete page appears.
6. Click OK.
You can now run System Restore again from a Different Restore Point.
on Jul 06, 2010 • Computers & Internet
2answers
What are WIN XP DOS commands for (1) remreplacing the administrator passwordadmiCOMMANDS
you dont need the administrator password for a system restore, simply boot of the restore CD.. Google Windows XP password reset DISC and download and boot that disc to reset the password. I cant post a specific software here as it may be considered soliciting..
1helpful
My hp pavillion dv6000 wont start normally. in safe mode will start but continues to request product key when i log in with my password.
It seems to be an issue with some software that is conflicting with the operating system. I would advise you to clear the start first. The steps below would help you clear the start up.
For XP:
  • Click on the start button(with the windows logo on it) on the bottom left corner of the screen.
  • Click on Run.
  • A small pop up box would open at the bottom left corner above the start button.
  • In the dialogue box beside "Open : " type "msconfig" and hit enter.
  • System Configuration Utility would open.
  • On the top menu, identify and click on Start up.
  • Now, click on the button "Disable All", at the bottom right corner. This will disable all the start up programs. However, you will still be able to access all those programs from Start->All Programs.
  • Click on "Apply" and then click on Ok/Close. If "Apply" is grayed out, click on Ok/Close. If administrator password is prompted, click OK and proceed with the steps below.
  • You would see another pop box with 2 options, "Restart" and "Exit Restart" or "Restart Later". Do not worry, if you do not get this option.
  • Restart your computer.
  • Immediately after your computer restarts, you will see a pop box. In that box, CLICK TO CHECK THE RADIO BUTTON AND ONLY THEN CLICK ON OK.
  • If you forget this step, you will have to start over again.
  • Your computer should have now booted to normal mode.
For VISTA or Win 7:
  • Click on the Start button (with the windows logo on it).
  • Click on Start Search and type msconfig.
  • On the top, under programs, you will find a link for msconfig. Right click on msconfig and click on Run as administrator. Click on continue (in user account control box).
If you still face the same problem, you can download and install the BIOS update.
If any of the above steps do not work, then it could be an issue with windows updates and any other updates that might have created a conflict. In this case, restore the computer to an earlier date when it was working fine. For that, follow the steps below.
For XP:
  • Click Start.
  • Click Help and Support.
  • Type system restore in the Search box, and then press ENTER.
For Vista or Win 7:
  • Click Start vistastartbutton.jpg, type system restore in the Start Search box, and then click System Restore in the Programs list.
  • If you are prompted for an administrator password or confirmation, type your password or click Continue.
  • In the System Restore dialog box, click Choose a different restore point, and then click Next.
  • In the list of restore points, click a restore point that was created before you began to experience the issue, and then click Next.
  • Click Finish.
Hope all this helps you.
Still if this does not work, then contact an expert who can help you with doing more troubleshooting on this in recovery environment. In recovery environment, we can try sfc /scannow and check /r.
Good luck.
Have xp professional and on my start up page all my links are gone? cant even do system restore.how do you restore it or fix this problem, really need some help!!! also get c:\program...
How to use System Restore to restore Windows XP to a previous state loadTOCNode(2, 'moreinformation'); Note To perform System Restore, you must be logged on to Windows as an administrator. If this is your personal computer, you are likely already logged on with an administrator account. If this is a computer that is part of a network at work, you might have to ask the system administrator for help. To verify that you are logged on to Windows with a user account that is a computer administrator, visit the following Microsoft Web site: http://support.microsoft.com/gp/admin (http://support.microsoft.com/gp/admin) To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
If the restore process completed successfully but the computer is still not performing as you want, go to the "How to undo a system restoration after you perform a System Restore" section. If you received an error message and the restore process did not finish, or if you cannot run System Restore, go to the "Next Steps" section.
2answers
I am running Windows XP Sp3 and System Restore will not restore to any active restore point, even the most recent date. After selecting a restore point the system reboots with the message "Your system can...
Try to restore your system in safe mode.
To start your system in safe mod, start your computer, then press F8 during system start. A list of options will be displayed, select safe mode, login to your administrator account and perform a system restore.
Cannot hear any sound
You can use Restore Point for this matter:
  • Note: To perform System Restore, you must be logged on to Windows as an administrator. If this is your personal computer, you are likely already logged on with an administrator account.
  • Log on to Windows as Administrator.
  • Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  • On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  • On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
Note: A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  • On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  • Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
    Click OK.
*If those steps doesn't work, reinstall the drivers.
Password
You can try booting in the safemode to see whether the default administrator account is enabled. If it is there then log on to the administrator account and changed the password for the account.
If the administrator account is not enabled then you should have the Vista disc to do system restore. Boot the computer from the Windows VIsta disc.. when you see the setup screen look for Repair your computer link at the left bottom corner. Click that follow the instruction to do system restore.
IF you dont have the vista disc call you Acer support to find how to boot in to Win RE
Good luck
Bala
2answers
Wont start
Hi what you need to do is you have to log in safe mode and uninstall norton If its HP od compaq then you have to tap F8 key
2answers
Lost my right as administrator
You have done big mistake that's why you are getting problem.
1)Regarding installation of win XP over windows vista.
You have to install first lower version and then higher version i.e. you should install first win xp and then windows vista. But vice-versa you can't do it.
So my suggestion is that format your c drive then install win XP
after installation win XP install win vista.
2) which operation system do you want to open .
You can remove it using windows tweak utility software wich is freely available on most of the website. Also you can manually edit it.
For manually do this.( i m not sure about windows vista it is available or not)
right click on my computer->click on Advanced Tab->setup and recovery framework click on settings->click on Edit button
You will see the boot.ini file. You can remove the windows XP line from that file.
Grand Canyon Tech
Grand Canyon Tech
