I am using D-Link DGS 3024 Gigabyte managed switch 8in our company. In the morning if i try to open a word document in my system, The System is hanging.Then i have to remove the network cable from the pc. After removing the cable all files are opening. Why it happens? Is it a switch Problem.
The DGS-1008D is a gigabit switch and not a router. It does not have a DHCP server as it will simply pass traffic between all the devices connected to it. It is meant to be connected to a DHCP server (router).
you can find all the data you need in the following PDF manual
ftp://ftp.dlink.de/dgs/dgs-1005d/documentation/DGS-1005D_man_en_v2-01.pdf
hope this helps.
connect only DGS -1024D to your network....it will be faster...
because DGS supports 10/100/1000 speed....
but DES supports only 10/100 speed...
connect DGS directly to your network and work with that...
if you wish to extend the number of ports then connect the DES to one of the ports of DGS
Switches, hubs or routers typically are used in a star topology connection, so if one device fail everything else is still working. Everithing is managed inside but not like a bus topology system. You may need to use a tree topology in some case, keeping in mind the consequence of a failure.
Open a web browser an put the IP address of your switch in the addresse bar. Once in the web interface, open the Monitoring folder and then click the Port Utilization link. The switch is actually creating graphics of each port utilization.
it depends on the type of internet service you have if it is cable internet most cable modems can act as a gateway for conecting multiple computers but the cable company needs to activate that feature on the modem.
