Question about Microsoft Xbox 360 Console
Xbox won't shut down
Everytime I try to shutdown either by using the controller or hitting the power button, my 360 elite won't turn off! TO shut it off I just have to pull the plug. WHAT CAN I DO??? HELP!!!
  • mavedog21 Jan 03, 2009
    My xbox is not the elite but still has the same problem. when I shutdown either by controller or via power button it just restarts.
    I've contacted xbox with no response yet.
    Novelist:
  • 111 Answers
HI there,
im guessing you have some problems with your Elites motherboard, could possibly be damaged electronics within the motherboard, as it is the motherboard on the Xbox which prepares the system for shutdown when the button is pressed and also wirelessly through the controller.
Luckily Xbox systems come with 5 years warranty. and because this is potentially a hardware issue, i would recommend contacting Xbox customer support to solve this issue. their contact information can be found on http://www.xbox.com/support
Hope this helps
Posted on Oct 29, 2008
Hp laptop won't shutdown
Could you be a bit more specific? Could you tell me the correct sequence you spoke of? I am trying to understand , you shut down using the windows 7 shut down and it re starts? Your response didn't clear up my confusion. I can remember ever encountering this. Just a thought have you done a Maleware scan lately? If not try MALWAREBYTES found at : http://www.filehippo.com/download_malwarebytes_anti_malware/Install and Run a FULL SCAN and a program CCLEANER found at : http://www.filehippo.com/download_ccleaner/ Install and Run, it's a good program to clean the junk files out and speed up you system. That a good place to start.
Nov 08, 2012 | HP Computers & Internet
Xbox 360s makes a weird sound when it reads a disc and shuts down
Sounds like the drive is very dirty, or going out. Try cleaning it, or just replace it.
Sep 16, 2012 | Microsoft Xbox 360 Console
How do i exit my current session on my xbox 360
Usually you can hit the Xbox Button in the middle of your controller and then hit the yellow "Y" button then select yes return to dashboard.
Oct 04, 2011 | Microsoft Xbox 360 Elite Console - Black
Can you connect a white xbox 360 controller into a black xbox 360 console. If yes how??
Yes you can do this. Simply get the White controller turn it on and hit the sync button at the same time as hitting the sync button on the Elite Console.
Jan 23, 2011 | Microsoft Wireless Controller for Xbox 360...
Como conectar el control
To connect the controller first press the small connect button on the xbox itself. It will be left of the power button on the front of the xbox, the elite will have a round button on the older styles, otherwise the new slim version will have a square button. Then hit the button on the controller while the xbox lights are spinning in a circle to connect. This button is next to the charging port on the front of the controller and will be a small round button, about 3 mm wide.
Let me know how this works out for you.
Benjamin
Dec 08, 2010 | Microsoft Xbox 360 Elite Console
When my Xbox 360 is off, the light on the AC Adapter is orange, but when I hit the power button to turn the Xbox 360 on, the light on the AC Adapter turned red.
HI you did not mention is you are able to use the unit even tho the led turns red. If not then the unit is drawing to much current and the power supply is shutting down. Or the power supply is faulty, If you can and know someone with a 360 system try to borrow theirs and see which part of the system is faulty if you know his is good and the same thing happens, or take yours to his house and try, but if same results then the 360 is at fault.
Apr 21, 2010 | Microsoft Wireless Network Adapter Xbox...
Xbox turns on for a second then shuts off
i would check you xbox360 owners manuel
Nov 29, 2008 | Microsoft Xbox 360 Console
Won't Shut Down
Is your xbox button on your control stuck down? Are you haveing trouble while playing games?
Jul 14, 2008 | Microsoft Xbox 360 Console
Xbox 360 Controller Shutdown
hi there
one common problem is if you have other 2.4gzh around the house
try turning off your phones (uniden is a really common one that interferes) or if you have a wireless router change it to a different channel and see if it helps.
good luck
smeags
Dec 31, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
527 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
