Question about Nortel BAP 120 (NT5S40CEE6)
Unable to acces the ap with some network cards
I am unable to access the nortel access point with some older and new laptops
  • 135 Answers
I might advise you to reconfigure the access point, maybe it lose the connection from before, reconfiguring the access point will going to have the previous performance.
Posted on Mar 09, 2009
Cisco Acces Point series 1020 Air-AP-1020-A-KG
This is an enterprise AP and needs to run with a Cisco router.
Mar 30, 2014 | Cisco Computers & Internet
I want to factory reset my nortel AP 7220, how do I reset? What would be default IP after reset?
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
Can't get better than 54 mbps in datat rate with this device
The Access Point, or whatever you are connecting to, must also support "N" wireless (~300Mbps); otherwise, the connection speed will be the "lowest common" connection speed, which in this case is "G" (54Mvps).
Note that if a "B" device, such as an older laptop, connects to the Access Point, the Access Point will drop down to 12Mbps for all connections! (Yes, twelve megabits per second).
You will have to replace the Access Point, or connect to an "N" Access Point if you are on a network with several AP's.
Oct 24, 2010 | ASUS USBN13 IEEE 80211bgn USB 20 Wireless...
Wirless connection wont connect to network.
On the WLAN world, exist a encryption key for connection. You will be able to see the "antenna", but until you enter the key you will not be able to access the network or the internet. First, disable the wireless security and try. Once you have verified the connection to internet then you add security. Use WEP.
Jul 06, 2009 | NetGear WG602 802.11g/b Wireless Access...
Can your laptor detect any other networks? If not make sure that your wireless switch is turned on.
If wireless switch is turned on and laptop detects other networks then your router is set not to transmit ssid (check router manual on how to configure SSID transmission mode).
Jun 03, 2009 | Nortel BAP 120 (NT5S40CEE6)
How to make my DWL-2000AP works like a wireles card and is there any driver for it?
It sounds as if you want to use your access point to connect into a wireless network. A typical, simple wireless network includes (1) access points and (2) clients such as a wireless card in your laptop. Access points can only communicate with clients and clients only communicate with APs. However, many access points can be configured to be clients. Usually you would find that in the basic wireless setup page. I don't know if the DWL-2000AP can be set up that way, but you can check in the manual. If it can, then you would select that mode, then specify the SSID of the network you want to join.
Apr 15, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Unable to get connected to Belkin f5d6130 AP
You need to be connected using  wired Ethernet (PC's LAN card to Router's Ethernet Port (at the back)).  This is the preferable INITIAL way to configure the router before going wireless. Also it would be to your advantage to initially set your PC (that will be used for configuring the router)  to "Specify an IP address" (static settings) and not "Obtain an IP address automatically."
For a PC connected via UTP networking cable attached to a Belkin F5D6130 AP, the networking settings could be:
IP Address
Subnet Mask
Default Gateway 19*
DNS Server
Post back results. Good luck and kind regards.
Oct 12, 2007 | Belkin (F5D6130) 802.11b Wireless Access...
Intel 2915AB Connection problem
Intermittent disconnection issues on a radio/wireless network will generally be caused by interferance (speakers, power board fully loaded, High wattage Lamp (flourescent bulbs usually) all parked too close to the wireless router, access point or network card. or possibly due to interuption of the active signal possibly because the distance of the router and network card/access point is just on the edge of the best signal limit and disruption occurs when someone or something gets up and moves itself inbetween the two service points)I resolved my disconnection issues by purchasing a wireless Kite for the access point and router, which will intensify the radio signal and bring the access points within closer range of each other, friends of mine have resolved intermittent signal issues by making a thin tube of rolled tinfoil about 30cm long slipped over each aerial affected by the intermittent signal disconnection. Also verify the "line of sight and non line of sight" signal distance limits for your radio equipment as the signal distance will decrease depending on the age of your wireless equipment, most equipment is in the 30Ft non line of sight- 100Ft line of sight arena out of the box but you can expect to half this figure after 3 - 5 years of continued use. Basically three options Interferance, Interupption or age only distance testing will verify this accurately IE: bring the router and access point withing 1Ft of each other and start walking away still holding the access point, whilst a user monitors the radio network condition.
Aug 04, 2006 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
Nortel BAP 120 (NT5S40CEE6) Logo
78 people viewed this question
Top Nortel Computers & Internet Experts
J John
Gopi Venkatesan
Gopi Venkatesan
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
