Question about Video Game Consoles & Games
PS3 Motherboard problem
Hi nunuk,
Saw your post saying: "Check the PWM circuit in the unit those along with drive transistorsoften fail in these supplies due to its compact size (they often cheapout with parts) also check duty cycle when it works."
Was wondering if you could run me by how to check the:
1- PWM circuit
2- drive transistors
3- Duty cycle
and were they are. I actually got 3 PS3s off ebay for quiet cheap and planned to repair by replacing and swapping parts that are faulty from the units to at least get one of the 3 running, however, to my misfortune (and this was confirmed) all the MOBOs are the one having the problems. All the HDDs, Blurays, etc.. are perfectly fine as tested and verified by a working MoBo.
Please help me. If i can just verify what on the mohterboard is faulty, i would be so excited to get my hands into replacing the faulty components.
Thx!
  • 98 Answers
You are going to have to go to System Settings and Restore your PS3, this will start you out fresh and brand new.
Posted on Nov 24, 2008
How do i fix my panasonic crt tv model tc-21xy3 no power
The power supply circuit is faulty. Generally you have to be good with electronics to do it by yourself. Unplug the tv before opening and servicing! Check the fuse, check the capacitors and replace inflated ones, check the transistor that gets signal from the PWM IC. Check the power to the PWM. Replace the small capacitor that stabilize the voltage of PWM. Replace the optron. If your PWM is burned out, you have to check the entire powering circuit - diodes, resistors etc. and replace all at once with PWM. Only one faulty element will burn down entire circuit again.
Oct 09, 2014 | Panasonic Televison & Video
1997 silverado installed used trans n speed senser plug is diferent and now it wont down shift
If you have adifferent plug for the speed sensor then you probaly have the wrong year model transmission.Even though 93 through 97 look similar they do not interchange.Your speed sensor should be on the passenger side of tail housing,That is the 1995 up design.If you have a trans with the speed sensor on the drivers side of tail housing then you have a 93 to 94 design.93 and 94 were non-pwm units with 5 solenoids.95 was a pwm unit with 6 solenoids with low impediance pwm solenoid.96 and up are pwm units with 6 solenoids and high impediance pwm solenoid.Swapping these units can blow computers.It is probaly stuck in third gear because the fuse is blown or because of open vss circuit.You will not be able to make this transmission work.
Feb 14, 2011 | 1997 Chevrolet K1500
I put a used transmission in my 2002 Isuzu Rodeo and code P1860 came on how can I fixed the problem if there is one
CODE P1860 TORQUE CONVERTER CLUTCH PWM SOLENOID CIRCUIT MALFUNCTION. THE TCC PWM SOLENOID FAILED.
Jul 09, 2010 | Cars & Trucks
Servise engine light on the code is p1860
code - po1860 tcc pwm solenoid circuit malfunction 4t80- E conditions.5 possible causes 1. tcc solenoid control circuit is open or shorted to ground. 2.tcc solenoid control circuit is shorted to system power b+. 3.tcc solenoid power circuit is open check the trans fuse. 4.tcc solenoid is damaged or has failed. 5.pcm has failed.
Dec 07, 2009 | 2001 Cadillac DeVille
Says upon start up Aserious error has occured. Contact tech support. in many languages
Ugh...this one can be anything really. Hardware / Software.
Google "The Five Most Common PS3 Problems"
I'd say try #3 first and also the manual video reset too.
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
PS3 stuck on screen saying hard disk corrupted
Hi
Please refer to this link for ways to troubleshoot the hard drive and sometimes if you are lucky you can recover the problem - however if these solutions fail the unit will have to be sent in for repair I am afraid.
Check out this link
http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=441&p_sid=LcojCxNj
Thanks for using FixYa.
P0740, p0753, p0758, p0785, p1860 all of them lit up on me
PO740 IS TCC SOLENOID CIRCUIT MALFUNCTION CONDITIONS.CHECK TRANSMISSION FUSE - PO753 IS A/T 1-2 SHIFT SOLENOID CIRCUIT MALFUNCTION CONDITIONS.THE 1-2 SHIFT SOLENOID HAS FAILED - PO 758 IS A/T 2 -3 SHIFT SOLENOID CIRCUIT CONDITIONS. CHECK THE ERLS FUSE - PO1860 IS TCM PWM SOLENOID CIRCUIT MALFUNCTION CONDITIONS.CHECK TRANSMISSION FUSE+ IGNITION FUSE.
Aug 02, 2009 | 2002 Dodge Ram Maxi
Will not boot up
I have seen a lot of Toshiba Laptops with bad "DC Connectors" on the motherboard. It sounds like you know what your doing so here a link on how to disassemble your laptop.http://www.irisvista.com/tech/laptops/ToshibaM2/tecra_M2_disassembly_1.htm
and here is another on how to repair the dc connector. http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
May 27, 2009 | Toshiba Tecra M2-S530 Notebook
Ps3 power supply to console
BUT A NEW POWER SUPPLY OFF OF EBAY !!!!!! IT WILL COST YOU AT MOST 47.98 DO NOT PAY MORE THEN THAT .......!! TRUST ME DO NOT PAY SONY NOTHING 150 DOLLARS IS OUTRAGEOUS WHEN I KNOW FOR A FACT ALL THEY DO IS SWITCH OUT THE POWER SUPPLY UNIT ..THAT IS ALL THEY DO .....!!!!.....I HAD THE SAME PROBLEM ......I WAS PLAYING COD WORLD AT WAR AND THEN OUT OF NOWHERE IT JUST SHUT DOWN COMPLETELY ,..WHEN I TRIED TO TURN IT ON IT SHOWED A GREEN LIGHT FOLLOWED BY AN AMBER LIGHT QUICKLY TURNING TO A FLASHING RED ........I THOUGHT IT WAS AN OVERHEATING ISSUE BUT MY AMBER LIGHT SHOWING INDICATED A HARDWARE ISSUE SO I TOOK A CHANCE AND BOUGHT A POWER SUPPLY UNIT OFF OF EBAY AND RECEIVED IT WITHIN A WEEK .......IT BOOTED UP PERFECTLY FINE TRUST ME ...FOR GET SONY AND TRYING TO DO ALL THAT FANCY TRANSISTOR SWAPPING GEEK TALK BULL......JUST SWAP YOUR POWER SUPPLY UNIT AND THATS IT ...YOUR PS3 IS BACK ONLINE !!!!!!!!!!.....THATS IT BOTTOM LINE !!!!!!.....TAKE MY ADVICE OR LEAVE IT I DON'T CARE BUT I FIGURED I SHARE THIS WITH YOU GUYS SINCE I WENT CRAZY RESEARCHING WHY THIS HAPPENED AND I BASICALLY PUT COMMON SENSE INTO THE EQUATION TOOK A CHANCE AND BAMMMM!!!!! BABY I FIXED IT LOL..LOL...HOW ABOUT THAT ..FOR ALL YOU SO CALLED KNOW IT ALL PEOPLE OUT THER ..LOL..LOL.!!!!!...DAMN GEEKS TURNING THINGS INTO ROCKET SCIENCE ALL THE TIME .....LOL...........EBAY OR ANY OTHER PLACE YOU CAN GET YOUR HANDS ON ONE OK .........THANK ME LATER OK ..LOL.....TAKE CARE ..
Nov 04, 2007 | Sony Playstation 3 (PS3) Console
Abit eq software
Does it vary? If it changes, it's probably a bug. If it stays static, it could be either. Try installing a different version, ask ABit Support, check the forums, etc.
Sep 30, 2007 | Abit KN8 Ultra Motherboard
Video Game Consoles & Games Logo
638 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
