Question about Kodak EasyShare Z1275 Digital Camera
Blue lcd display
I replaced a broken lcd display with a new one but now it only shows blue without any picture. Suggestions?
You will need to take it apart and take the screen out and clean the wire ribbon that go's to the screen use a alcohol base cleaner to do this and when you put it back in do not tuch it with your hand's ok and that should work
Posted on Dec 01, 2008
Videocomyn haute lcd display is not showing picture please tell me what is the problem
If the sound comes out from it; the fault is related with its back-light. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Dec 17, 2014 | Televison & Video
Why, when turned on, my Stylus 840,shows an LED display that looks like night time with pink and blue colors. If photo is taken, it comes out pink. Why is this? Any suggestions as to why this is do
I'm afraid you have a defective camera. Or the sensor is defect, or the connection to the sensor is not good. (lose, oxidised, broken or lots of other stuff) also the main board can be defect. If also the pictures come out (on the computer) dark and pink, I.m afraid you have to start saving for a new camera.
Make sure the lens is clean and not greasy.
Sep 21, 2014 | Olympus Stylus 840 Digital Camera
The screen on my zeepad jellybean 7.0 cracked how do i know if i need a new lcd display. I already purchased the digitized touch screen replacement
tha't an easy task to handle
See the pictures below
if your whole screen shows an image and the cracks are in front of it then its just a cracked digitiser
if you dont see the whole image and tyou see horizontal and vertical line or an image like spilled liquid then your Lcd is also cracked too
92dabd2f-7f4a-4795-976d-d97d7e32fa0e.jpgthis is a broken Lcd (the screen is distorted by the lines or no picture at all)
83952950-d5b2-47e3-b228-81f41d0190af.jpgthis is just a broken digitiser (the screen below the broken glass works fine )
hope that was helpful
May 20, 2014 | Tablets & eReaders
Blue ink spot on monitor
That is not an ink spot, that indicates the LCD panel is cracked and the "ink" is the liquid parts of the "liquid crystal display" LCD that is coming out from the broken glass. When you have a broken LCD panel you just need to get a new monitor, the panels are not repairable and to replace one will cost almost as much as a new monitor.
Sep 10, 2012 | eMachines E19T6W 19" Monitor
Sansui 1908 sound but no picture, kid was using
Return the thing. Ur LCD inverter board is dead.Or call for warrenty repair.The LCD inverter have no set of times,it dies anytime.Must replaced the LCD inverter board to get picture back.
Nov 06, 2009 | Sansui 19 in. LCD TV
Giant blue spot on 50" Hitachi LCD HDTV
The problem is an expensive one. The blue display has become distorted due to excessive heat overtime. The blue display is closest to the lamp and gets most of the heat. The Light Engine must be replaced by a repair shop to correct the problem.
Mar 22, 2009 | Hitachi 50V720 Television
Screen problm bcoz of broken
- if an LCD screen is broken, it would show white patches. - Ensure that the display is not in demo mode. (Usually in Demo, one half would be normal, where as the other would be a preview of some custom setting - Check the display controls below the LCD Screen to change them.
Please try these first, then you can go for a replacement, if these don't help
Jan 08, 2009 | Dell InspironTM 1501 Notebook
Replacement LCD?
When the display is cracked Sony charges a dud fee in additional to the cost of the replacement panel that is about the same price or more than the replacement LCD panel. They can't refurbish a defective. Add to that about $400 for in-home labor, then taxes and the repair will cost the same or more than a new TV. Example, $1200 panel cost, $1500 non-return of rebuildable dud, $400 labor, Taxes = $3300+
If you could replace the panel yourself, all you would save is the labor cost and the tax on labor charges.
Basically if any flat panel screen (LCD or Plasma) is physically damaged, the TV set is junk. They do make pretty abstract art pieces though. You could sell the whole set for parts on Craigslist or eBay, but don't expect to get much.
Aug 11, 2008 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Broken digital camera.
Hi, I have this camera & when it takes multiple pix, I usually find I've hit the delete button, which also is the "multiple pic" button. Just keep pressing it until the display doesn't show the papers stacked on each other with the letters H, L, or the infinity symbol. If you can see your display...no answers for you on that.
Sep 18, 2007 | Fuji FinePix E510 Digital Camera
LCD display showing shattered lines - no picture displayed
Hello CathyCool The LCD itself may not have problems. If it ain't broken it most probably doesn't have a problem. Most likely the problems you have are given by a faulty connector between the LCD and the camera's mainboard. You should take the camera to a service center to have it checked. Tell them to make an estimate over the repair costs before they actually do something. In this way you will know what prices can you espect over the repair. I'll give about 60% chances that this is a minor defect involving that connector. In this case they will just need to reconnect it back firmly.
Mar 16, 2007 | Sony Cyber-Shot DSC-S70 Digital Camera
Kodak EasyShare Z1275 Digital Camera Logo
59 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
