Question about Intel Motherboard
Can't read memory
When i start ism software the message appears cannot read memory
    Scholar:
  • 60 Answers
You either have corrupted settings in your BIOS Setup or your Ram is bad. Before condemming ram, you should pull the sticks and try and re seat them. Also, some older PC's require bank 1 and 3 or bank 2 and 4. Check your documentation for any order that must be followed. Finally, make sure it is not miss matched ram. (60ns, 70ns, parity, non parity, etc.)
tnmatt
Posted on Nov 06, 2008
Brother FAX-8070P memory shows full and does not send all pages at one time?
This message means the memory capacity of the unit has been exceeded. The amount of memory used depends on the amount or type of data on the documents being faxed or copied.
  1. If you get an "Out of Memory" message while scanning the first page of a fax, press Stop/Exit to cancel scanning.
  2. If you get an "Out of Memory" message while scanning a subsequent page, you can either press Fax Start to transmit the pages that were scanned so far or press Stop/Exit to cancel the operation.
When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify Fax Storage is set to Off by doing the following:
  1. Press the Menu/Set key.
  2. Press the arrow key until FAX appears on the LCD. Then, press Menu/Set.
  3. Press the arrow key until REMOTE FAX OPT appears and then press Menu/Set.
  4. Pressthe arrow key until FAX STORAGE and then press Menu/Set.
  5. Check the setting. The display will read ON or OFF. If the setting is ON, press the arrow key until the display reads OFF.
  6. Press Menu/Set.
  7. If you have faxes stored in the memory, you will receive a message that reads Erase all fax? 1. Yes 2. No. If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Note
    If you would like to reprint the saved faxes, press 2 (No), press Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
  2. Press the arrow key until FAX appears on the LCD and press Menu/Set.
  4. Press the arrow key until PRINT FAX or PRINT DOCUMENT appears and press Menu/Set.
  5. Press Fax Start.
  6. After printing is finished, press Stop/Exit.
Jun 06, 2011 | Brother FAX-8070P Plain Paper Laser
I cant save my messages to my memory card
In nokia 3230 you cannot save the messages to memory card.You dont have option in this mobile itself.
Dont worry, please download MSV driveE software in your mobile phone so that messages can been directly saved in MMC.
Download the MSV software from below website
http://www.ziddu.com/download/8277766/MsvDriveE.jpg.html
After you downloaded it, you’ll find that you save file named MsvDriveE.jpg. Don’t worry! You just downloaded the right file. Rename the extention *.jpg, and change it to *.sis. Then you’ll get MsvDriveE.sis then install it to your phones.
But in this feature it just saves the incoming messages to the memory card instead of saving it to phone memory to keep the phone memory unused.But you cannot read your messages.
To read your saved messages in PC please install a software called as FE explorer.
You can download FE explorer from below website
http://gallery.mobile9.com/f/1210278/
Using this FE explorer you can copy the messages in your inbox and you can paste in any of the folder in memory card.Then you can open the messages in your computer using Note Pad and read the messages.
To copy please follow the below steps,
1.Select inbox from the main page in FE explorer.
It shows the messages in Your inbox,sent item,saved messages also.
2.Copy it and Paste where ever you want to copy in E:/ drive(Memory card)
3.Then you can put your memory card in your PC and can open up the messages in Note Padfd6f18b.jpg Thank you
Aug 08, 2010 | Nokia 3230 Cellular Phone
Windows won't come out, with message fatal error.
If its appearing in blue screen..mostly it may be because of your memory. chek your hard disk also with any checking softwares like NDD, or seagate softwares
Apr 09, 2009 | Computers & Internet
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
Lock/read only card message
Make sure all the files from the memory card have been downloaded and saved to the computer. You are going to need to format the memory card to remove the write protect/read only/lock issue. By formatting this will permanently erase all data from the memory card so you are able to use it again.
To format the card: go to Menu - to Submenu - to Format option - Start - then Start again - Press Menu to initiate the process - When done the recorder will be able to be used for recording purposes again.
Dec 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Problem with Memory Card door
I read some reviews for this camera, and other people are having problems with their battery compartment. It is a design flaw. If it is not under warranty, a repair might be around $200
Sep 15, 2008 | Olympus Camedia E-10 Digital Camera
PC Start up
hi dear
choose safe mode with pressing F5 button
try to fix your start up program, uninstalling your relation software
or try anti spy
or hijack
reset your computer
and try to normal login
oke
Mar 27, 2008 | Computers & Internet
Intel Motherboard Logo
32 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
