Question about Sony MHC-DP1000D System
Disconnected optical input cable
I connected a DVD player SONY DVP-NS51P to my audio system SONY MCHDP-1000D through the optical output and failed to get any sound. After several adjustments on both the player and system without sucess i finally opened by system only to find the cable from the optical input had disconnceted from on the sytems motherboard. I need your assistance in telling me where this cable should be fixed as I am not a service engineer nor do i have the service manual.
  • kikato78 Oct 30, 2008
    Hi Welcomjee,
    Thanks alot for the solution, it was spot on. Icant believe you have answered me within one day. Thanks fixya too for saving me time and money. This site is just great!
    Rgds
    kikato78
  • 10,594 Answers
Optical Input connector will go to CN601 of DSP board right under DVD mechanism.
See picture to find DSP board in MHC-DP1000D Hi Fi system.
Posted on Oct 29, 2008
I am not able to play DVD and CD in my Sony DVP NS51P
Have you tried cleaning the player with a disc made for cleaning optical drives? These such units are available at retail locations such as Traget and Best Buy.http://www.target.com/Memorex-DVD-Laser-Lens-Cleaner/dp/B000P0OJ8O/ref=sc_qi_detailbutton
May 05, 2011 | Sony DVP-NS51P DVD Player
Does it support surround sound
Well not buit in, but it has a 92 KHz/16bit Audio DAC/96KHz/24bit decoder and coaxial digital audio output. So to get surround sound you need to connect the DVD player to your home theater receiver using the Digital coaxial/optical output connector (i.e. fiber Optic). Your home theater has to be equipped with the same type of input and you could enjoy your DVDs in surround sound soon.
Note: the optical inputs and outputs are generally capped when not in use and you will need to remove the the cap to be able to plugin your cable.
Good luck and please don't forget your thumbs-up to help me help you further. ty !
Apr 07, 2011 | Sony DVP-SR200P DVD Player
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
Have Sony KDL-40EX400 LCD TV, Sony STR-DH510 AV reciever, Sony DVP-NS57P dvd player. When connected to reciever using component connections the TV does not show a picture. I have seen this problem in a...
  • If I understand your question correctly you want to watch your DVD on your TV thru your receiver,
  • you need to connect either composite connections "Audio/Video Output " red/white/yellow RCA jacks or "Optic cable output" of your receiver
  • ( pls note that component to composite conversion is not possible on receiver ..use one type connection thru all the way )
  • to "Audio/Video input " red/white/yellow RCA jacks or "Optic Cable input" of your TV
  • than just switch to DVD mode on corresponding your RCA or Optic connection...
There you go..Your DVD sound and video both are on the TV..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Feb 06, 2011 | Sony DVP-NS57P
Need owners manual for proper connections to tv w/direct connections I hsve a sony dvp ns300 cd/dvd player
The connection you use will depend on the TV. For the best picture, connect component video cables (not included) from the DVD player's output (to the right of the other jacks on the back of the unit) to the component video in of the TV. Then connect the Right and Left audio from output 1 to the appropriate audio input of the TV. (These may vary depending on the TV and other devices connected to the TV. They might be audio 1 or part of a group with the component video inputs.)
Otherwise you can use an S-video cable connection and the separate audio cable or the composite video cable (which has 1 yellow RCA plug for video and 2 others (red and white) for audio). Connect these from the output of the player to the matching input ports of the TV.
For TVs with only RF in, you need a composite video to RF modulator (converter). See a store like Radio Shack for this.
The manual is available from Sony: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPNS300 . Pictures of the connections start at page 15 and more detail is provided from page 17 through 23. See the manual for details if you have a home theater system or other external speaker option.
I hope this helps.
Dec 08, 2010 | Sony DVP-NS300 DVD Player
Since disconnecting my Sony DVD player it now only plays in black and white. It is relatively old model DVP-NS51P. I have successfully connected an alternative DVD player to the same TV so it cannot be a...
Make sure that the TV system that the DVD is outputting is NTSC, Press SYSTEM button on the remote control (is there's such button) or change the system in the DVD's menu.
Nov 09, 2010 | Sony DVP-NS51P DVD Player
There is no video output from my Sony DVP NS51P dvd player though audio output is there.
Im guessing your connecting via a scart lead..... Try swapping the cable ends round so that the DVD end goes into the TV and visa versa.
Mar 23, 2010 | Sony DVP-NS51P DVD Player
Hi, I have connected component leads from my dvd
Enable the component output on the DVD player menu. Sometimes the component output is shared between RGB/S-Video/Component, make sure you select Y/Pb/Pr on the player's menu.
Nov 04, 2009 | Sony DVP-NS51P DVD Player
DVP-NS575P fail for DTS system
I have an Transistor(Radio) of Sony but it does not play the AM signle
May 12, 2008 | Sony DVP-NS575P DVD Player
Is Sony DAV-S500 optical input compatible with optical output from Pioneer DVD player DV-566K?
I don't think this has an Optical but a Coaxial connection. You might try a coaxial audio cable not optical.
Dec 30, 2007 | Sony DAV-S500 System
246 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
