Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU927QWDG1 Hi, The problem I'm having with my dishwasher pertains to the door cover for the area I place the soap. There is a small spring which helps the door pop open to release the soap when washing. I cant figure out how to place the spring so that the pops open.....right now when I run the unit the door stays latched and the soap doesn't get dispensed. Any ideas on how to repair this or where I could maybe get a parts manual??? Your expertise will be greatly appreciated!!!!
  • 5989 Nov 11, 2008
SOURCE: Dishsoap stays in soap dispenser
We had problems with soap remaining in the dispenser and dishes not getting clean when we used gel dish doap. We changed to the cakes of soap with a Jet Dry Power Ball in the middle, and now they clean fine.
Posted on Apr 14, 2008
rickzilla
  • 706 Answers
SOURCE: soap dipenser
Try this... Wipe out the soap dish with white vinegar and a soft cloth.. make sure you get everything off the edges of the door and look for any nicks, blemishes or deformation of the dispenser door to make sure it is not mechanically binding up when it is cycled open. If Ok.. then.. clean your drain filter.. then.. start a wash cycle using the hottest setting ( without any dishes) .. and after about 10 minutes or so.. stop the process and open the door and add in 2 cups of white vinegar.. Let it complete the wash cycle.. When complete..try running a dishless cycle on any setting with detergent ( use about 1/3 less than you usually use) and see if that dispense adequately. If that works, then the next time you load the washer. make sure you don't have anything up against or limiting the door from opening. Hope this helps..
Posted on Sep 23, 2008
SOURCE: Soap dispenser does not release
I found out for FREE on another sight. I'm replacing my timer.
Posted on Nov 10, 2008
  • 126 Answers
SOURCE: Whirlpool Gold Quiet Partner IV issue with soap dispenser
I'd check the spray arms it may be there is not enough water or the wataer is not getting where it needs to be to disperse the soap. that is where I'd start.
Posted on Jan 16, 2009
This happened to me as well. I think I solved the problem. It started when I first lowered the top rack. In doing so, the door doesn't open all the way. It also won't open all the way if your cutlery rack is in the front and you've put large utensils like a spatula. Consequently, detergent dried under the latch and it wouldn't firmly catch. For months I put up with it never emptying completely. The other day I took a tooth brush and very hot water and cleaned under the latch. After, I could feel a difference in the way the latch operated (with greater pop on opening). So far its been doing fine. Hope this helps.
Denise
Posted on Mar 14, 2009
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner I soap dispenser won't close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
May 18, 2011 | Whirlpool Dishwashers
The soap dispenser isn't opening all the way. Therefore it leaves a small amount of soap in the chamber after the rinse and dry cycle. How do I fix it?
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 20, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap dispenser cover latch will not stay in the hole. So now the soap holder will not stay closed.
Hi
Daniel
Jan 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap dispenser lid doesn't open
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it
Oct 25, 2010 | Whirlpool Dishwashers
Two problems: soap cover and seal?
Door leaked because of a plastic bearing ($4.10 part) on the lower arm causing water inside to surge and splash out the vents on the bottom of the door. Soap cover problem was a corroded spring caught on a plastic part inside the door panel. The spring actually broke and now seems to work fine because there was another spring helping to do the same job that is now allowed to work.
Dec 08, 2009 | Whirlpool DU943PWK - Multiple Color...
Main wash door won't open on whirlpool model du810swkqo recently bought new home with new (?) dishwasher but it looks like the main wash door (where the soap goes) doesn't have room to open. any...
the cover is spring loaded. manually open the cover and pour some really hot water by the hinge, manually open and close few time, onec it is loose, put few drop of machine oil and work it again.
May 15, 2009 | Dishwashers
Soap Dispensor does NOT open.
This is almost always a dispenser problem. The dispenser is replaced as a unit. you can reach it by removing the Phillips screws around the inside of the door and lifting up the inner door panel. The dispenser's frame is held in place with tiny (1/8 in or 5.5mm) screws.
Mar 11, 2008 | Dishwashers
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
57 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
