I left my lights on and my battery went dead. got a jump and now my keyless entry pad doesnt work.
SOURCE: Ford battery operated remote entry keypad
if it looks like a sealed remote either at top or bottom take a quarter or penny there should be a little **** on the form line big enough for the quarter or penny this is how you open the key remote other type is a screw type and i dont believe you have this type cause your asking how to open it
SOURCE: keypad keyless entry code missing
Ford has an add on keypad also if it is pretty much flush on the door it is factory if it is a fat keypad it is an add on The factory module is under the dash by the fuse panel the number should be on it
SOURCE: CHANGE CODE ON KEYLESS ENTRY SYSTEM FORD EDGE
Yes you can program your own code by inputting the original code then hit the no. 2 button then input your own 5 digit code.
SOURCE: Need factory code for keyless entry pad
To locate the original keypad code, open the passenger/rear door. Pull the on-body rubber weatherstrip out, around the rear side of the door closure. Fold the right/rear seatback down into the locked position to facilitate access to the right/rear seat belt anchor. Carefully pry the upper plastic panel that houses the height adjuster and seat belt anchor off the body taking care not to damage the panel. Now pry the lower panel outward just far enough to enable access to the Vehicle Security Module, where you'll see three electrical connectors plugged into it, coloured green, grey, and blue. On the module will be a series of digits on a label similar to 5L2T-15K602-EA. Beside those digits are five numbers. Those five numbers are the keyless entry keypad code.
SOURCE: 2008 FORD EXPLORER - KEYLESS KEYPAD CODE LOCATION?
Do to a dealer and they can reprogram it for you.
