Question about AudioBahn A8002T Car Audio Amplifier
Audio system makes extra noises... pops
Audiobahn Sub: AW1206T & Amp: A8002T subwoofer extra noise/pop i have also posted this under the subwoofer page since i did not know which part of my system is malfunctioning now i dont know if its from the amp or not but amp light is on & ther is no short circuit or anything like that.... the sub was working fine till 2 days ago when my little brother needed the trunk space since he was moving n using my car... now what can this be... i have turned my system off since then to prevent any possible further damage... can somebody please help me with this? It does sumtimes stay silent or sumtimes makes noise by itself according to vehicle shakes, noises, moves on the road... but its pretty weird... after i first got into my car after the change... the sound n beat level sounded a lil weird n sub sounds like its a cheap sub now... its makin bad pops thnx
Check connections on remote wire to amplifier check all positive wire connections
Posted on Apr 24, 2009
Dear sir,
Pls help me what is the problem of my Peavey powered mixer model XR-696F. after few sec. on the left channel has pop pop sound, it seems frying. the right channel is okay. my speaker no problem because i have already interchange by putting the R-chl speaker to L-speaker. the problem still the same. hope you will help me coz this quite expensive unit which I bought last year jan. '08.
thanks.
Posted on Jan 03, 2009
    Problem Solver:
  • 18 Answers
Most of the time when a high power amplifier starts making noise not all the time but every once in a while or even all the time its the ground, if the amp turns on its not the power cable. try moving your ground to a different location or try using double grounds. the better the ground the better the sound. and as for turn on pops, put a toggle switch inline on your rem wire and turn it on after the car is started.
Posted on Oct 04, 2006
  • 55 Answers
Check all the wiring. It could be a loose connection since it's intermitent. Really pay attention to the power cable, both the end for the amp and the one that's going to the battery cable.
Posted on Sep 11, 2006
4 Suggested Answers
  • 631 Answers
SOURCE: AudioBahn A2300HCT no sound
Generally, if the amplifier smokes, the power supply FETs have failed.
Many times, the output transistors fail and that causes the power supply FETs to fail.
Audiobahn won't release schematics. The amplifiers are relatively simple and a schematic isn't generally required.
If you know how to check the transistors, check them to determine the severity of the damage. If you don't know how to check them, read through the following page following all links provided.
Basic Amplifier Repair
Let me know if you have any other questions.
Posted on Sep 05, 2008
wesmckay
  • 9 Answers
SOURCE: Protection Light On
If the speakers are still fine, then I'd say it blew the transistors in the amp.
Posted on Jan 15, 2009
  • 506 Answers
SOURCE: audiobahn a8002t amplifier in protection mode
Let's measure some voltages. If you have a DMM measure the DC voltage at your amps power supply input. If much less than 10 volts I would suspect you may have possibly damage your power wire. When you have a lot of current flowing through a wire the resistance will change and cause a larger voltage to drop across that wire. Having to low of an input voltage is a trigger mode for some amplifiers to go into protection. Let me know what you find and we can go from there.
Posted on Dec 22, 2009
Fix subwoofer
Pop open the back side of the sub and see if the to connections are soldered firmly to the wires/drivers themselves & make sure your system is grounded meaning the 3 pronged plug has to have the 3 post still connected to the power cord. If its broken off as most people do it'll cause that feedback or dull hummmmm noise.
Oct 15, 2013 | Altec Lansing VS4121 Speaker
My audiobahn eternal is making a rattling sound when it plays certain notes
might be your wires inside the box. My brothers does the same thing on deep notes, took the sub out and shorten the wires and seem to stop that noise or kinda rattling sound. I had two 12's the same ones you got, the noise i had was my 12's blowing the box apart lol. Don't hurt to check your box every now and again. hope this was helpful
May 05, 2010 | AudioBahn AW1206T Car Subwoofer
I got 8 terminals on a my 15 audiobahn sub how do i hook at 2ohm load
Yes audiobahn do make a QUAD coil, and some people get confused with the - - + + on the terminal, This is called a dual lug, Check out Audiobahn.com and go to tech suport. Thier you can look up the wiring diagram for this sub... TRUST ME hope this was helpful positive feed back be nice lol
Apr 08, 2010 | AudioBahn AW1206T Car Subwoofer
Audiobahn a8002t schematic
audiobahn.com under tech support you can download your manual for almost any thing even shows you wiring diagrams helped me out...
Mar 01, 2010 | AudioBahn A8002T Car Audio Amplifier
Need more bass
Bridge it. Should be marked on amp. According to specs should get u the power u need. Amp max 1500 watts. at 2 ohms. Speaker max is 2200 watts at 4 ohms. Turn amp down and adjust to your own taste. trust your ear man.
Jul 12, 2009 | Car Audio & Video
I have 2 AW1206T's how do you know when their blown?
when a sub is blown it usually makes a scratcy or grinding noise if you push the sub in but if its blow it realy wont make much of a sound so it sounds like your voice coil is going out you will want to get this looked at quick or it can get expensive...i had one were it was cheaper to buy a new sub rather than fix it. it can also just be it disorting from too much power. i would never go over the power limit when dealing with 3000 watts, that can get realy expensive quick
Apr 12, 2009 | AudioBahn AW1206T Car Subwoofer
Amp making crazy noise
What is your complete system set up?
Mar 19, 2008 | AudioBahn A8002T Car Audio Amplifier
The RCA inputs to the sub may be unplugged or damaged. Check them both for the sub and for the amp
Sep 05, 2006 | AudioBahn AW1206T Car Subwoofer
AudioBahn A8002T Car Audio Amplifier Logo
253 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
