Question about Lands Phones
Phone charging indicator shows when in the cradle, but there seems to no power when taken out of the cradle.
  • pogo73 Oct 29, 2008
    Thanks, i found the problem though, i was being a bit thick and had not turned the handset on.
    Champion:
  • 242 Answers
If it shows it's charging and doesn't actually charge, then the battery is no longer good. It's probably a NiCd battery and they only last a few of years depending on the charge/discharge cycles. Hop down to Wal-Mart for a new battery, or Radio Shack if it's a hard to find one.
Posted on Oct 29, 2008
Panasonic cordless phone rings, but when you answer the phone goes dead
Check the charging contacts make sure it is charging when in the cradle. If problem is remove the battery and let it stand for one minute than re-plug battery in unit place briefly in cradle, until display and or charge indicator lights up . Try making a call . IF ALL ELSE FAILS RUN TO TOP OF HIGH RISE BUILDING THROW HANDSET TOWARD EMPTY PARKING LOT !! BUY a BETTER QUALITY PHONE S#&@T HAPPENS
Sep 01, 2012 | Panasonic KX-TG1100 Cordless Phone
Phones are powered but do not connect to base so can't receive or make calls. Is there a way to reset?
The manual, which can be found at: http://www.home-electronics.net/ge/pc/IB/25952EE1_IB.pdf, reads:
4. Place the handset in the base cradle. The charge/in use indicator turns on,
verifying the battery is charging. The unit will take 20 seconds to register
and verify its security code. READY shows in the display.
NOTE: In case of a power failure, the handsets may display
UNAVAILABLE when the TALK/CALL BACK button is pressed.
You must then place all handsets on the main base cradle
for 20 seconds to re-register.
That should reset your handsets. Hope this helps :) Thank you very much.
Feb 08, 2010 | GE 25952EE1 Cordless Phone
Registering handset
If all else fails, read the instructions.
"4. Place the handset in the base cradle. The charge/in use indicator turns on, verifying the battery is charging. The unit will take 20 seconds to register and verify its security code. READY shows in the handset’s display."
Dec 12, 2008 | GE 25922 Cordless Phone
Not Charging
Same thing happened to me the other day. For some unknown reason my wep500 seemed to just die with no apparent cause or reason. So I took the unit apart and tested the battery with a multi meter. It read 3.9V. So power was not the issue, I then put it back together and by chance, happened to continue pressing the power button for 5 seconds in hope I would see the LEDs flash but no dice. Then for no reason, I went to my phone and tried to pair and to my amazement it actually paired (meaning the device must of been on). So I then hit the big button on the wep500 and sure enough it calls the last number stored in my phone. It turns out (out of all things) the led itself went bad for some unknown reason. I suggest you try charging it (you won't see the red led), try turning it on (you won't see the blue led) and then try pairing from your phone. If you phone indicates it paired, then try calling the last number from your wep500. If it works, then you too have a bad LED (I have never seen an LED go bad before). Hope this helps.
Sep 13, 2008 | Samsung WEP500 Wireless Headset
VTECH VT9121
voice message light keeps blinking
Aug 25, 2008 | Vtech 9009111 Cordless Phone
O2 XDA II Grounded? (No one Cant Solve it)
Hi
Do you use a USB mouse then it may be due to conflicts and it has recognized it as another device .... try other USB port.. it may solve ur problem
May 15, 2008 | O2 Xda II Smartphone
Not charging
Try to turn on the Keyboard.
There's a switch in the right side of the Keyboard.
For more information download the User Manual at Logitech Site
Sep 15, 2007 | Logitech diNovo Edge 9676850403 Keyboard
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Lands Phones Logo
103 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
