Question about Acer AL2032wd (Black) (Black, Silver) 20 in. Flat Panel LCD Monitor
Monitor turns on and then off right away at time of power up
Turn on computer, monitor clicks on, then strobes once, then click off again. this keeps going on and on and on and on and on.......... anyone know if this can be fixed or do i now have a $350.00 paper weight??
SOURCE: menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Posted on Feb 28, 2008
  • 5158 Answers
SOURCE: The monitor turns off and on repeatedly.
does sound like a power supply issue... they are fixable but it's somewhat involved.
Posted on Aug 28, 2008
SOURCE: config screen keeps popping up
A friend of mine had the exact same same problem. I think I fixed it, because it has been 2 hours, without the menu popping up. You need to open the monitor:
- Place it face-down on a flat surface
- Remove the cover of the hinge by gripping it with both hands and gently squeezing and pulling.
- Undo the 4 screws and remove the stand (base)
- Undo the four screws tha hold the cover down (4 corners)
- Use a flat screwdriver to seperate the 2 halves (I used 2, a small one to lift the back, a bigger one for leverage)
You will see a small PCB, fastened by 3 screws, at the bottom (where your menu+on/off buttons are) with a ribbon connection to the screen. Next:
- Unscrew the PCB, and gently lift it out.
- Clean the microswitches and the ribbon cable connection.
- Reassemble the monitor.
To clean microswitches and the connection, I used Kontakt Video 90 spray. There must be sprays on the market where you are. It's basically an alcohol-based cleaning spray. Good for cleaning video/tape/floppy heads, CD/DVD lenses, memory modules, etc.
Posted on Jan 07, 2009
  • 4 Answers
SOURCE: Monitor turns on during computer start up but right away goes off
reinstall the drivers only after you remove the current ones for the monitor
Posted on Sep 01, 2009
  • 11361 Answers
SOURCE: Mouse click turns monitor on, (green light), but
It has dying power supply due to bad DC filter caps, that will be the first place to look.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER and other monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
Capacitors kit: he can make you a set of caps for you.
Posted on Nov 02, 2010
  • 27725 Answers
SOURCE: HP monitor keeps saying "monitor
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Jan 07, 2011
0 characters
1 Points
When I power off my LCD monitor, the screen goes all white, but once I turn the monitor back on it goes right back to displaying whatever it should on the screen. Or when I shutdown the computer it also...
If this has happened to two monitors on the same computer, then i dont think the problem is with monitors, i think the problem is with the graphics on the computer, i suggest uninstalling the driver for the graphics card in device manager and then restart the pc to see if that makes any difference. The divice manager in in the properties of my computer icon, just right click and choose properties, then device manager.
Feb 06, 2010 | Sylvania L181 18.1" Flat Panel LCD Monitor
Hi. when i set my acer x193w monitor to 1440 x 900 resolution, the display becomes scarmbled. please help. thanks
One option you have is to go to safe mode and uninstall video driver in device manager and reboot your pc and it will detect it by it self and put it in right resolution. It is possible that drivers were corrupted if it got scrambled, also make sure it can support it. Best place to get drivers would manufacturer site not via update driver button. To get to safe mode you need to shut down your pc and press power to turn it back and and once this is done keep on tapping F8 key until you get Advanced Startup Menu. From here just choose safe mode and follow prompts. Once in safe mode right click on my computer and click manage option.On left side of new window click on Device Manager and locate driver for display. Right click on it and click uninstall and follow prompts. Once done reboot and should be all set. Good luck
Dec 31, 2009 | Acer X193W LCD Monitor
My gateway monitor shows a picture for about 1 second then turns to blacked out screen with power light still on. I can shut the power off on the monitor then turn it back on only to have it do the same...
Your power settings may need to be changed, it appears to be going into sleep mode or power saving mode.
If you are using Vista, Click Start> Control Panel > Power Options > "choose when to turn off display" (in the left hand pane) and check that it says at least 10 minutes. Click apply and then ok.
Alternatively, right click on your desktop, select "personalise" and click on screen saver - then select "change power settings" to bring you to the same thing.
If you have xp, right click on your desktop and select "properties" then "screensaver| > "Power" and change it to turn off the monitor after 10 minutes. Click apply then ok.
If your monitor is going to sleep, either press a key or wiggle the mouse to wake it up.
Hope that helps.
Nov 01, 2009 | Gateway HD2201 22" LCD Monitor
The monitor keeps going blank after a minute or so
hey right click on your desktop.go to the propertes menu go to screen saver on the screen saver the screen saver tab menu you will see a tab called on the power tab.change your settings there for the monitor.let me know if it works.
Sep 09, 2009 | Proview PL713B 17" Flat Panel LCD Monitor
Model L196WTQ keeps going into Energy Saving mode. How do I get it to stop - black screen not really useful
Right click anywhere on the desktop and select properties. Hit the screensaver tab and click Power. There you can turn Hibernation on or off, and set the amount of time before turning the monitor off or set it to not turn off at all
Jul 31, 2009 | LG Computer Monitors
it seems to be the power management
right clik on desktop click properties
click on screen saver tab
and from there click on power
ther you can adjust monitor stanby mode
Jul 24, 2009 | Computer Monitors
Gateway FPD1530 loses image shortly after powering up.
try booting into safe mode. press F8 while the computer is booting. see if everything stays normal. It should tell you that it booted into safe mode. Once there, change the resolution or the frequency of the display(also known as the refresh rate) by right clicking on the desktop and selecting properties. Once there, click the tab all the way to the right, it should give you color quality options and resolution options. At the bottom, there should be an advanced tab. Depending on our video card this menu can be different from others. Look in that new window for and option to change the refresh rate or the frequency. The value will be in xxx hertz. try setting it to 60 hertz.
Jan 31, 2009 | Computer Monitors
Sony SDM-HS74P/S 17 Monitor won't stay on the right picture.
This is a duplicate post, click the following link to read the active posting:
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
Monitror keeps cycling through on-off
I also just recently started having this problem. If you look at the power brick the power indicator flashes on and off with the monitor. I think that the power brick is bad. I switched to a different monitor and the computer works fine. The en-9110 cycles on/off with or without a computer attached. I contacted Envision about an RMA.
Oct 16, 2006 | Liquid Video L17LCD2 17" Flat Panel LCD...
Monitor turning off
If I understand you problem correctly, your monitor is turning off when it remains idle? Does it come back on when you use the keyboard or move the mouse? If so, then this could just be caused by the computer's power-save settings. This can be adjusted by right clicking on the the desktop and selecting propeties. Go to the screensaver tab and click on the power button. From here, you can either set the "Turn Off Monitor Time" to never, or to a greater period of time.
Oct 16, 2006 | Sylvania CL972B (Black) 19 in. Flat Panel...
Acer AL2032wd (Black) (Black, Silver) 20 in. Flat Panel LCD Monitor Logo
100 people viewed this question
Top Acer Computer Monitors Experts
Steven Wander
Steven Wander
 Mike M
Mike M
Are you an Acer Computer Monitor Expert? Answer questions, earn points and help others
