Question about Car Audio & Video
I need the color of the wires and which ones are negative and which are positive for a stereo in 2004 hyundai santa fe
  • 360 Answers
Give me email addy and ill send them to you......... but you got to rate as fixya justuscc
Posted on Oct 29, 2008
How do you remove and replace a crankshaft position sensor on a 2005 Hyundai Santa Fe 2.7 L engine
My info says it is located on rear of engine, sorry I don't have a picture of location. Three wire connector, wire colors white--yellow--pink.
There is a bolt that holds sensor, have to remove. Also, remove electrical connector.
Apr 08, 2017 | Hyundai Cars & Trucks
Radio/amp wiring diagram 2004 hyundai xg350 ?
2004 Hyundai XG350 Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: White/Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown/White
Car Stereo Dimmer Wire: Green
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Black/Yellow
Left Rear Speaker Positive Wire (+): Brown/Red
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Black/White
Dec 22, 2016 | Hyundai Cars & Trucks
What is the pink wire for in the stereo of a 2006 Hyundai Santa fe? and what do I connect the dimmer wirefrom the santa fe to in a new stereo
The pink wire from the stereo unit is often the dimmer wire, and is connected to a power feed from the vehicle's side lights. Not all stereos have a dimmer function however, and may not have this wire available.
Nov 04, 2012 | 2006 Hyundai Santa Fe
2006 hyundai santa fe stereo wiring color code
I was given two Lanzar 6.5 and two Pioneer 6.5 speakers. There is nothing wrong with my stock speakers, I just wanted to add a little more thump and clarity. I took off the front drivers side interior panel, Which wasn't all that bad, but i'm having major problems putting it back together. I'll get into that a bit later. I figured swapping the old for the new would be simple. Being it has two wires (pos/neg) going to the driver/speaker cone and two wires going to the tweeter portion that goes over the lower part, four wires total. The wires are White, Brown, yellow, and Black going into a black clip, then they turn black coming out the other side. I cut the four after the clip. My new speakers have only two posts to accommodate the driver and tweeter. So I left off the two for the tweeter and it sounded awful. I tried combining the two positive and two negative and hooking it up that way. That too sounded awful. The tweeter was squealing and chirping. I tried every configuration. They all sounded like ***. What am I doing wrong. I know people swap out stocks for after market all the time. I wanted to be sure my new speaker wasn't defective, so I tried all four (Both brands) with the same results. So I gave up and put the original back in. It sounds fine, just like it had before. But now I can't put the door panel back on. I know it's just tricky and i need more patience. I'm so bummed. I have these great speakers and have no idea why I can't install them. Do I need some aftermarket clip? It seems so easy, why is it so flappin hard? I've done this with other cars in the past with no issues. This four wire thing is killing me... Please HELP ME!!!!!!!!
Jul 10, 2010 | 2006 Hyundai Santa Fe
Which wire is which in replacing an old stereo in
go to best buy and buy a wiring kit. it has manual to guide you step by step. best of luck
Aug 07, 2009 | 2004 Hyundai Santa Fe
Are 08 hyundai santa fe and tucson desame stereo wiring harness?
NOPE! . Go to http://www.hmaservice.com/ and register (vehicle by VIN). Afterward, you'll have access to technical information (manuals, wiring diagrams, service bulletins, etc) about your vehicle.
Jun 29, 2009 | 2004 Hyundai Santa Fe
Hyundai Matrix audio wiring
2004 Chevrolet Trailblazer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
pls rate
Jun 10, 2009 | 2004 Chevrolet TrailBlazer
Need help with 2004 Hyundai Santa Fe Audio Wiring
Sounds like you need a light tester. I would guess that at least 8 of the wires are speaker + & - the others will be Main power and earth Possibly electric ariel, Memory store and a wire for the anti theft circuit. Assuming the stereo is factory. Any Audio shop can perform a test to clarify the purpose of the wires Wouldnt worry about the blank its probably a position for a newer or different model to yours. Steve in the UK
May 13, 2009 | 2004 Hyundai Santa Fe
Steps to remove radio
  • Step 1:Disconnect the negative cable from the battery terminal. Position the cable to is doesn't come in contact with any metal parts.
  • Step 2:Pull out the ashtray and remove the two screws that connect the bezel around the radio. Pull off the climate control knobs and remove the two screws at the top of the bezel trim.
  • Step 3:Remove the trim and disconnecting any wires. Not all models will have connecting wires on the trim.
  • Step 4:Locate the two screws, one on each side of the Hyundai Santa Fe stereo, and pull the head unit out of the dash. Disconnect the wires behind the radio.
  • Thanks for using FixYa - a FixYa rating is appreciated!!
    Feb 20, 2009 | 2004 Hyundai Santa Fe
    Car Audio & Video Logo
    113 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
