Question about ASUS CROSSHAIR Motherboard
My xfi xtreme gamer sound card not recognised in any pci port on croosshair mobo
Hi i have a crosshair mobo from asus ,i had been using asus own small sound card in a very small sound port which is above the pci ports. due to recent blue screens indicating sound conflicts , i reformatted and reloaded windows all went well no problems, single beep post. only the brand new creative sound card x-fi just isnt recognised as even being in the pci port, which it is tightly secure in pci port, anyhelp appreciated
antiochpc
  • 1314 Answers
SOURCE: ASUS P4SP-MX motherboard no POST and no beep without ram
Try removing everything attached to it. The only thing should be the cpu and cpu fan. Turn it on. If it is the same, then it is your motherboard. If you do get the beeping, then start installing things one by one starting with the memory.
Posted on Jul 03, 2008
SOURCE: asus p4p800-x no screen no beep
Could be that your ram is either Bad or the wrong type. I just had a similar problem. I changed the ram and up it came.
Posted on Aug 04, 2008
mulmol
  • 184 Answers
SOURCE: cant get sound card working in Windows XP Pro 64 bit
Go to Add/Remove Programs and uninstall the software related to your soundcard.
Go to Device Manager and remove the sound card it is the device that has an exclamation point or question mark.
Turn off your PC and remove the Card. Then turn it back on again and enter the BIOS setup and disable the built in sound card of your motherboard then press F10 and save the changes.
Restart your computer and verify that windows is not going to scan for missing devices. Check the Device Manager again and look for any devices that has an exclamation point or question mark. If there is none. Turn off your computer put the sound card back in and turn it on again. Put in the CD Driver but exit on the autorun let windows detect the card automatically and wait for it to ask for the location of the drivers. Point or browse to the driver location and let the installation finish and click on ok. Your PC may ask for another restart do that turn on your speaker and listen for the boot up sound if your hear it then your card is now working.
Posted on Jan 23, 2009
bunnydawg
  • 5158 Answers
SOURCE: just put together a new
further to this... go to this site... you will see a button that says autoupdate.... click on that it should detect and install the driver for you
http://support.creative.com/Products/ProductDetails.aspx?catID=1&CatName=Sound+Blaster&subCatID=208&subCatName=X-Fi&prodID=16770&prodName=PCI+Express+X-Fi+Xtreme+Audio
SOURCE: ASUS M2N-E SLi Motherboard No Graphics
I have the same board (M2N-SLI) with a BFG 9800 GTX with no video either. I have the card in the black slot and I have 2 mem sticks in the yellow. Shouldn't make a difference if I'm using a monitor not an LCD right? Everything spins up for me too, hard drive, vid card has power, CPU fan is on, post (green) light is on.
Posted on Sep 25, 2009
Hy, I have your mainboard AsusP4S800 vith soundMax digital audio we are conect game pad in the game port but he is not worked. In the control panel we have not driver for this hardware on Asus board....
This is your board:
http://www.asus.com/Motherboards/Intel_Socket_478/P4S800MX/#download
Unfortunately Sound Max is no longer available and you may be able to find the driver at the Asus site I gave you. It would only work for the version of Windows your system came with and, I can't guarantee that. Your easiest and best option at this point, would be to upgrade to a PCI or USB sound card. You can use something like this:
http://us.store.creative.com/Creative-Sound-Blaster-XFi-Surround-5.1/M/B0044DEDCA.htm
Which is a USB card or, something like this:
http://us.store.creative.com/Creative-Sound-Blaster-Audigy-SE-PCI/M/B000LP0R3E.htm
There are others available:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100009293%20600011977&IsNodeId=1&name=PCI
Any of these sould work for you and, in the long run, you will be happier with an added card.
Good luck,
Dave
Aug 20, 2011 | ASUS P4S800-MX Motherboard
Trying to install a Creative X-FI Xtreme PCI card (Model # SB0792) on an Inspiron 1100 (the 2.5GHz Celery model, Dell mobo #OWF887, A01 BIOS) - device is brand new, but on installation the card isn't...
Windows should recognize it and ask you to intall a driver for it. Make sure it is secure in the slot and make sure you are using the correct slot. If it still does not recognize it then the card is most likely bad.
Mar 25, 2011 | Creative Labs Computers & Internet
I would like to know what are the replacement parts for a video card and sound card for my Gateway GM5480E, or suitable parts.
You have a PCI Express slot on this computer (the black slot that run horizontally on the bottom half of the board. It is compatible with PCIE spec 1.0, so whatever video card you get MUST be 1.0 spec. The 2.0 spec won't work. You did not provide the information on your power supply, but this is another important consideration. Many video cards require a certain wattage output, and many will also specify a minimum output on the 12V rail. The more powerful the video card, the more likely this will be a problem. If you are a gamer, get the best card you can for the price, and make sure to check about power and the PCIE specs for the prospective card. If you are not a gamer, look for a slightly cheaper card, as you really don't need all that power.
As for sound cards, your PC has 2 PCI cards, which you can slot in any PCI sound card. I prefer the soundblaster line of cards or Xfi from creative labs. Depending on your Operating system and how much you want to spend, I can provide a better recommendation. Feel free to post more information on your PC if you want a more specific recommendation.
Mar 15, 2011 | Computers & Internet
How the way for actived a Multimedia audio controller in my computer Asus Pentium(R) 4
that defend on your hardware setup, stereo is common setup specially for the onboard audio jack,  your sound blaster check this, http://www.ask.com/bar?q=audio+pci+card&page=1&adt=0&qsrc=168&dm=all&ab=4&u=http%3A%2F%2Fus.store.creative.com%2FSound-Blaster-XFi-Xtreme-Audio-PCI%2FM%2FB000W7PNZI.htm&sg=y6Erk07usi5GfC3wKedD%2BZAHYN%2FUiBrQVZClJS5e29M%3D&tsp=1270366803701
Apr 04, 2010 | Computers & Internet
Sound on asus p6t6
Yes,
Creative Sound Blaster X-Fi Xtreme Audio PCI Express Sound cardfrom $50.
Mar 20, 2010 | ASUS P6T6 WS Revolution Core i7 / Intel...
IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
Asus crosshair mobo problem
you need a more powerful power supply
Apr 23, 2009 | ASUS CROSSHAIR Motherboard
Computer won't turn on.
This sounds like an overheat problem, is your cooling fan working properly, also the processor you are using is a powerful one, so needs a cooling fan much more powerful than the lesser powered athlon 64 processors.
Dec 02, 2008 | ASUS CROSSHAIR Motherboard
Post
hi i also have a crosshair mobo and it will not post or start up if the internal blue led's are on switch them off on the back and i'm sure it will start
Aug 24, 2008 | ASUS CROSSHAIR Motherboard
System do not reconize the PCI card
Does it ask for a driver to be installed? Or have you got the wireless version of the mobo that needs an ASUS WiFi-b add-on card with an omni-directional antenna?
Like on the previous version of the mainboard, the PCB contains five PCI slots and an exclusive WiFi slot, in its left part. By the way, when you install the original WLAN card from ASUS into this slot, the last PCI becomes unavailable. Now let’s examine the card, too.
The card supports the wireless networking protocol IEEE 802.11b, describing data-transfer rates up to 11Mb/s. Using the software that accompanies the card, you can use it in the Ad Hoc as well as in the Infrastructure mode, and the card can perform the functions of a programmable access point, providing connections to 31 clients. Thus, the owner of the WiFi-b kit can easily deploy wireless networks and connect to existing ones.
Jul 11, 2008 | ASUS 802.11G WIFI-G 54MBPS WIRELESS LAN...
ASUS CROSSHAIR Motherboard Logo
130 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
