Question about HP LaserJet 2420 Printer
My HP LJ 2420 printer always lost network connection
My HP LJ 2420 printer is on a network. Everything was right till a month ago. Since then after power on it works properly, but after a short while it lost connection. I cannot even ping it. After a power off and on it works again. Please help me, 'cos I'm tired to always go to the printer and turn it off an on again :)
    Scholar:
  • 91 Answers
Fatuto,
I would recommend replacing the JetDirect card in your printer. What model is the card? The 600, 610 and 615 can be replaced with a newer 620. Make note of all of the IP address info before replacing the JetDirect card. If you send more detailed info, I can make sure that I send the correct info that you need.
Try this and let me know what happens. Binary Bob
Posted on Nov 28, 2008
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
LJ 2420 IN 49.FF95 SERVICE ERROR SHOWING PLS. CONFORME WHAT IS ISSUE IN PRINTER?
remove the network card at the back, re-insert or replace it...
Jan 21, 2011 | HP LaserJet 2420 Printer
Am not able to download drivers for hp laserjet 2420 printer
Hi, here's the link to your printer driver...
just click the link and press the "download" button.....save the file to start downloading...
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=416419&prodNameId=412123&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=lj-24947-4
Hope that fix your problem...
Much appreciated if you could rate this help.thanks.
May 24, 2010 | HP LaserJet 2420 Printer
HP LJ 2420 DN Slow of print output
I would upgrade the firmware on the printer and uninstall and reinstall the latest drivers.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=412132&taskId=135&prodTypeId=18972&prodSeriesId=416419&lang=en&cc=us
Visit that link select your operating system from there you can get the latest drivers and firmware.
Thanks,
Lee
Nov 06, 2009 | HP LaserJet 2420 Printer
I have a HP LJ P2015n. Should be on our network
As i understand your concern you have network printer which you want to setup with your network. And right now your printer is connected with the computer using a usb be cable. Thats the main reason why it is having different ip address because it don't required any ip address once you tried to connect your printer through usb cable. I can suggest you that once you connect your printer on the network and you will get the option to network setup on your printer where you can assigned static ip to you printer which is the range for your router or network device called DHCP.
I believe that will help your resolve your concern.
Thanks & Regards
Jaspreet Singh Saini
Oct 28, 2009 | HP LaserJet P2015dn Printer
LJ 2420 service error 49.2604
A critical firmware error has occurred. Hp suggest reseating memory modules and upgrading the firmware, but i've found in the past if by turning it off and on a few times doesn't cure it the formatter board needs replacing (quite common on this model)
Sep 01, 2008 | HP LaserJet 2420 Printer
Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Apr 08, 2008 | HP LaserJet 3055 All-In-One Printer
LJ 2430 Printing Blank Pages
HI there have you tried the toner cartridge as this could also cause this problem? Also change the transfer roller and are the bands going from left to right or from up to down. If the bands are left to right change both if up to down more likely to be the toner cartridge.
Hope this helps you
Thanks J
Jan 11, 2008 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
295 people viewed this question
Seeker5211
Seeker5211
