Washing Machines Logo
Danny Spooner Posted on Feb 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hotpoint aquarius TCL770 isn't drying clothes
The drum and everything is working fine and the load is appropriate. The water is emptied, the filter is fine but it just doesn't dry the clothes
Kolbrun Gunnarsdottir
Level 3:
  • Hotpoint Master 1,228 Answers
  • Posted on Feb 26, 2012
Hotpoint Master
Level 3:
Answers
1228
Questions
6
Helped
277390
Points
3915
Good evening
There is most likely something wrong with the electricity in the machine.
Kolbrun
5 Related Answers
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 31, 2008
SOURCE: Noise when draining
U will find the filter by removing the lower rear panel of the m/c.
Locate the large black hose at the right side, and remove clip securing hose. Get some thing ready to catch any water that will be in there, and remove hose.
There u will see the filter, remove and clean, refit filter and hose,making sure that u get the hose on properly, test for leaks before u put the panel back on.
U will find this much easier to do if u tilt the m/c forward, and support it with something underneath.. Check inside the pump as well.
Plz rate my solution.
Thanks.
Anonymous
  • 213 Answers
  • Posted on Jan 10, 2010
SOURCE: I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Anonymous
  • 155 Answers
  • Posted on Mar 08, 2008
SOURCE: Drum Paddle broken Hotpoint Aquarius
The paddles in the drum are there to agitate the clothes being washed. Without them, it is possible that the drum would just spin while the clothes sat still at the bottom.
For optimum performance, it is best to have all the paddles present, but if one is broken/missing then it shouldn't have too much effect.
Hope this helps,
Matt
reddyanantha
anantha reddy
  • 205 Answers
  • Posted on Oct 04, 2009
SOURCE: hotpoint aquarius wd440. Flashing lights
hello mam please check the timer switch.
57 varieties
Karl Wright
  • 1653 Answers
  • Posted on Nov 06, 2009
SOURCE: wdl540 clothes go through drying cycle but come
If there is no heat at all then the heater or the temp sensor or the thermal fuses are defective and need replacing.
Also check that the lint filter is clear of debris and lint. Rinse it if necessary in some mild washing up liquid in warm water and dry thoroughly. Check that the air outlet hose is clear if you have one fitted. Check that the condenser is empty of water and the case is free from dust and lint. Vacuum / brush or wash the outside of the collector in washing up liquid and warm water and dry.
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Tumble dryer has stopped working
you can check pump ,if pump isn't working water stay all time .
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Hotpoint tcl 770 aquarius tripping electrics
REMOVE TOP OF WASHER AND CHECK WIRING ON FRONT RIGHT SIDE AS IT IS PRONE TO CHAFFING CAUSING AN INSTANT TRIP.
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
2answers
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Clothes wont dry but gets really hot
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
1helpful
2answers
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Hotpoint aquarius
What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
