Question about Compaq Presario 2100T Notebook
Dead with a pulsing blue light
I've got a Compaq Presario 2113AP. It's been over-heating for a couple of years so it's been sitting elevated to help circulate air. However, it's also had the problem of not powering up even if there's normal external power. This would only happen if I had to restart the computer, or it didn't shut down properly. In most cases I've managed to get it up and running again via the reset button underneath. But no longer. There's no sound, and if I press the on button the little yellow light flashes 8 times really quickly then stops (the blue light continues to pulse slowly). The reset button does nothing. The last time it was used it was turned off nice and slowly. Is it really dead? And if so, how do I get the information from the hard-drive?
    Scholar:
  • 148 Answers
Okay, great, great question, thank you for the detail, good grammar, and certainly honesty as I can help you much more. The overheating is probably being caused by accumulated dust on the heatsink where the fan is and needs to be cleaned off to prevent it from overheating (sticking a can of airspray in there should do the trick). As far as not powering on, that is definitely a motherboard issue and may be related to the overheating problem. Doubtless, however, you will need to get a new motherboard. I suggest either www.preowned.com or ebay as they both have great prices for new motherboards. As far as recovering the data off the hard drive goes, the hard drive should be fairly easy to remove. They make a hard drive caddy that will convert it to two USB cables that you can hook up to any other computer as you would a removable flash drive and recover the files appropriately from there.
Posted on Nov 02, 2006
Display on Compaq Presario V2665US notebook cuts in and out.
BIOS does the screen fail in BIOS< no OS running?
power on hit ESC, F10 or what it told you to hit for 11 years.
does BIOS work
that button top left is the standby sleep switch .
if bad , no sure what will happen, but something wrong will.
the aCID TEST IS BIOS.
works on demand all the time or not.
LAMPS:
the back lamp is dead, CCFL
all do, on all old screens 2010 and older
the magic year is 2010 as that year LED phased in.
see? use flash light see, that data there? do you'?
no sure what button you are pressing?
an 11 year old Laptop 2006, so CCFL is there
test those.
for sure use a flashlight.(test)
and see if there is data if see that, the CCFL tubes dead, there inverter is dead, or the power to it or out of it is cut.
here is close manual for free.
https://www.manualslib.com/manual/30176/Compaq-Presario-V2605tn.html
Nov 28, 2017 | Compaq Presario V2665us Notebook
Hello, My Compaq Presario 750US will
The motherboard of your laptop might have encountered a short circuit. If you've already removed and reseated all possible removable parts and still get the same result, purchase a replacement motherboard or check if it is still under warranty.
Good luck.
May 17, 2011 | HP Compaq Presario F750US
I have a Compaq Presario F572US to which turns off on occasion and tries to reboot but fails. I then take a blow dryer to the heat sink side for a couple of minutes and will come on and work again for...
If your computer occasionally shuts off it may be due to overheating. As a safety precaution your computer will shutdown upon reaching a certain temperature. If you are using your laptop in bed, and it is resting on a blanket or some other object is blocking the fan it may cause the laptop to overheat. Try elevating the laptop or getting a laptop mat with built in fan to help keep it cool. If there is an issue with the Nvida card changing the BIOS will not help.
Mar 16, 2011 | Compaq Presario F572US Notebook PC
Hi I am using hp Compaq presario CQ50-210US is getting heat with 5 mints of start
Hi,your Hp Compaq Presario CQ50-210US heating up after five minutes of starting up is normal for AMD(Processor) systems,they are actually rated as very fast processors and they tend to heat up very fast upon start-up,usually it is advised that you use such System in very cool environment to avoid component damage.also avoid placing the system on the bed or carpet or covering the vent under the system if you must raise it up,do so by placing it on an elevated platform so as to allow proper circulation of air.
Feb 20, 2011 | HP Compaq Presario CQ50-210US Notebook
I have put in a new HD (exact replica) Old drive is dead dead dead. I ordered the recovery disks from ComPQ. after they arrived and didn't work, I "REVERIFIED" them, CQ says these are the right...
there is no Compaq, its HP
if you get this from HP they work
if you didnt his clone bs. and will not work,
the internet is full of crooks, do not buy from crooks.
who the H3LL CQ, ???
this and only this is your source of media kits, HP.com
not only that but the exact service tag MUST MATCH !!!!!!!
your tag was not presented here so zero help possible. !!!!!
CQ is a model prefix for a COMPAQ like Compaq Presario CQ62
CQ is not company or web site, its a model prefix.
why not start over.,
and ask for help first
say I have this Presario
the tag is below (mine below is random example)
then ask how to load the OS, (operation system)
that is first. do not use non HP media or you ill fail
or worse be victim of identity thief, do NO DO THAT.
HP bought out COMPAQ years ago. 16 long years ago
there is no COMPAQ now, only HP support./
Mar 26, 2017 | HP Compaq Presario SR5610F Desktop PC
I have a compaq presario v6211au with amd turion processor i hv purchase it in 2007 , after purchasing it gave me many problems like battry, adapter, but one problem still coming about its oipening...
the screens is dead right, no BIOS screens at all, means.? what?
power problems
main battery out , run now
coin cell dead? 2.9v and above is good.
power pack bad, 19vdc ok , is it.
power jack at the MOBO edge bad, as all do.?
see this?
https://www.amazon.com/Presario-V6210us-V6211AU-V6211TU-Compatible/dp/B009WWBWFY
Jul 17, 2017 | HP Compaq Presario V6000 Motherboard -...
Compaq Presario 700 Laptop..... Push the power button. It makes a couple little clicking sounds like normal and the power light comes on, but nothing else. No fans, nothing. I had this computer for a few...
I have run into this with lots of laptops. Sometimes its something simple like bad connections. Sometimes its the board. If you want to try to diagnose it yourself try the instructions here:
http://icompute.info/laptop_doesnt_start.htm
Theres no magic fix for this model that I know of. If you do get it started again, try to do a bios update from Compaq for that model. Sometimes there are BIOS updates that fix this kind of issue but the computer has to run in order to install the update.
Hope this helps...
Oct 19, 2009 | Compaq Presario 700 470024-192 Notebook
Computer does not start up.
sorry bud my advice would by 2 get a new 1 most laptops now adays are only have a lifespan of 3 to4 years but saying that you done well getting 6 years plumdj
Nov 11, 2008 | Compaq Presario X1000 Notebook
Where is wireless connection switch on Compaq Presario R3000?
Well if u have the same exact one as myself.
The wireless button is on the front right near the corner. above it and on the corner is the wireless symbol. If its working it should be lit blue. push it and see if it lights up blue for a few seconds. You should get a wireless connection confirmation on the screen.
hope this helps you
Nov 10, 2008 | Compaq Presario R3000 Notebook
Compaq Presario 2100T Notebook Logo
103 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
