HP LaserJet 3550 Printer Logo
Posted on Oct 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp 3550 fuser problem
Hi guys. Recently changed fuser on my HP 3550 but page counter did not reset so the printer still thinks the fuser hasn't been changed. Is it possible that i may have installed the wrong fuser. It still carried on working for a while but kept alarming that the fuser still needed to be changed. Now it has stopped working as i guess the page count has exceeded for the life of the fuser. Any ideas?
jason
Level 3:
  • Master 905 Answers
  • Posted on Oct 29, 2008
jason
Master
Level 3:
Answers
905
Questions
8
Helped
321066
Points
2511
Try this
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support
Hp cm4540 fuser kit counter reset
allot of the newer HP printers can not be reset they have a fuse in the new fuser when it is installed it blows the fuse in the new fuser & resets the count.
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
50.1 fuser error not fixed by instruction on machine; HP color laserject 3500
17 posts - 8 authors - Last post: 23 MarWe are getting a 50.1 fuser error with our Colour Laserjet 3500 printer ... fuser from HP in the UK, but was told that they are not currently available ... hi I have the same problem error 50.1 with two machine 3500/3550 ...
www.fixyourownprinter.com/forums/laser/31146
1helpful
HP Laserjet 3550 Fuser Jam Error 13.20 Had it in
You need to ask them to change the fuser..The fuser is the part of the printer that actually melts the toner onto the page. Here is a website that gives you more info on the fuser so they can't B.S. you anymore..either the fuser works or it doesn't..
http://www.theofficeguide.com/toner-cartridges/faq2.html
Please rate this solution thanks.
1helpful
HP Colour Laserjet 3550 printing problems
I can tell you that it is NOT the Fuser unit. I would change the drum unit first. This would be the most likely cause.
1helpful
HP Deskjet 3550 keeps printing in pink
HP Deskjet 3550 MODEL NUMBER:VCVRA-0202
Hp 3550 fuser error 50.1 and it is cold.
The fuser error 50 means that the fuser heater lamp is blown and you need to get another one (whole assembly). I personally use printerworks at www.printerworks.com to order a new one if you want to do it yourself, otherwise you will need to drop it off at an HP Authorized repair center..
Good Luck!
Rich Lilja
k24674
Grand Canyon Tech
Grand Canyon Tech
