Question about Canon PIXMA MP150 All-In-One InkJet Printer
Problem installing driver
Installation was not completed
no printer driver installed
Install the printer driver of canon pixma mp 150
Posted on Oct 30, 2008
MP Navigator EX not installed
There are two possibilities. Maybe drivers does not support the operating system, or maybe the wrong drivers installed.
Solutions for possibilities drivers do not support OS
1. Download drivers from Canon Support & Download
2. Select Product category = Multifunctional Inkjet Printers
3. Product series = Pixma
4. Model = Pixma MP258
5. Document type = Drivers & Softwares, then click Find
6. Select OS = Example; Linux
How to install the the printer driver
Install the printer driver, then connect the USB to the computer. If the USB cable is plugged into the computer, then install the new driver, happens is the failure of drivers install process.
Solution to fix the drivers install error
1. Unplug the USB cable from the printer, to the computer.
2. Uninstall all software and drivers are already installed, then restart the computer.
3. Insert the Driver CD, do the install process. About a 90% of the install process, it would come the request "connect the printer to the computer".
4. Connect the USB cable, with a computer.
5. The computer will detect the printer, and install process will continue until completed. After the install is complete, the printer is ready to use.
Hope it helps
Nov 14, 2011 | Canon PIXMA Office Equipment & Supplies
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
The scan function does not work. The print and copy functions work as the printer is hooked on as default printer with the software that came with it loaded on to my computer. Tried using the MP Navigator...
Hi
Check the your install the complete installation in your printer, because if you install complete installation then you did't get this type of problem, remove the your printer driver and install the again with installation CD which come to printer, please install the complete installation.
if u don;t have a driver CD pleas click the mention below link for the driver, select your OS and download.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#DriversAndSoftware
Good luck
May 13, 2011 | Canon PIXMA MP210 InkJet Printer
Installing HP4795 printers in Windows XP. During install XP cannot find print drivers. Can you tell me how to point install to the print drivers?
Click on the link below to download the Printer Drivers and later install them.
Download Link
After you download the file, run the file to start installation and complete the installation.
Disconnect the Printer cable before the installation starts and connect it when asked to.
If for any reasons, it does not recognize the printer connected, complete the installation by clicking on the option ( I will connect the printer later ) and complete the installation.
Then Click on the Diagnostic download option below to run the diagnostic tool to diagnose the issue.
HP Print Diagnostic Tool
My Suggestion would be to completely uninstall the software and reinstall it using the Download Drivers option above in this solution.
Thank you for contacting FixYa
Regards,
Ron
Dec 23, 2010 | HP C4795 AllInOne InkJet Printer
Can't install 1210 printer
Insert the software disc for the HP 1210 printer before you plug the printer into the computer with the USB cable. Allow the disc to install the software. You will be prompted to choose a destination for the software.
Plug in the printer USB cable to the computer when the installation program tells you to. This will be after it has installed any drivers that you need to run the printer on the computer.
Complete the installation by running a print test to make sure the printer software is installed correctly. You may remove the disc after the print test is complete. Installation without a Disc Visit the website http://welcome.hp.com/country/us/en/support.html to find the available drivers needed to run the printer on your computer. On this page, select "Download drivers and software." Enter "HP 1210 printer" in the product box and click the arrow to find the drivers. Select your printer from the list provided. This will take you to the next page, on which you will indicate your operating system. Select the "HP Officejet and PSC Full Feature Software and Driver" under "Driver" to begin the download. After the download is complete, you can open the file from the download location and install the software and drivers. Follow the installation software's prompts, after you finish download the drivers you need to double click it,it will give you the option to RUN or DON'T RUN the driver click on RUN and it would continue the installation. Run a test print.
Aug 27, 2010 | HP PSC 1210 All-In-One InkJet Printer
Lost my installation disk
1. Go to the website http://support.epson.com
2. Under the ALL-IN-ONES heading select FLATBED and then your printer model.
3. Under the Drivers & Downloads section select WINDOWS. Download the most current version of the Printer Driver and Scanner TWAIN Drivers to your DESKTOP for your Windows operating system. You can also download the Status Monitor, if listed.
DOWNLOADED DRIVER INSTALLATION.
Scanner Installation
1) Before beginning, ensure the cable for the printer is disconnected and the printer is turned off.
2) Locate and double click on the downloaded Twain driver installation file.
3) Click on OK at the first WinZip screen.
4) Click on UNZIP at the second WinZip screen.
5) Click on OK when WinZip is finished extracting files.
6) Follow the prompts to complete the installation.
Printer Installation
1) Locate and double click on the downloaded Printer Driver installation file on your DESKTOP.
2) Click on OK at the first WinZip screen.
3) Click on UNZIP at the second WinZip screen.
4) Click on OK when WinZip is finished extracting files.
5) At the PRINTER UTILITY SETUP screen, click on OK.
6) The installer will now copy files to the computer. When this step is complete, it will tell you to attach the cable and power on the printer. Please connect the USB cable and turn on the printer.
7) The computer will install the new hardware.
8) Click on OK when the driver installation is completed.
Status Monitor 3 Installation (optional)
1) DOUBLE-CLICK on the downloaded file.
2) Make sure the STATUS MONITOR is highlighted and then click on OK. The installer will now copy the necessary files to your computer.
3) When finished click OK and restart your computer.
Aug 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Canon S450 wouldn't print test page
hi
i first need to know what is the eror message
you need to uninstall\reinstall the printer
this can solve your problem
Uninstall and Reinstall the Printer Driver (Windows) Instructions to uninstall the printer driver
  1. Select 'Programs' or 'All Programs' from the 'Start' menu.
  2. Select the printer driver you want to uninstall, and then select 'Uninstall'.
  3. When the confirmation message shown below is displayed, click 'OK'.
  4. A window showing the progress of the uninstallation is displayed. Wait until the "Uninstall successfully completed" message is displayed.
  5. When the message is displayed, click 'OK'.
  6. This completes printer driver uninstallation.
Note: If you use Add or Remove Program to uninstall the printer driver, the printer model name will remain in the Start menu. To completely remove all files, including the printer model name from the Start menu, uninstall the printer driver using the procedure described in Step 2.
Instructions to install the printer driver for the using the prepackaged CD (Windows) Before installing the printer driver, confirm that the printer is powered off.
  1. Set the prepackaged CD into the computer. (The installer starts automatically, and the following window is displayed.)
  2. Select 'Printer Driver' on the left side in the window, and click 'Install'. (The Printer Port dialog box is displayed.)
    Note: Click 'Readme' to refer to notices on installation.
    Initially, the manual is installed.
  3. Confirm that printer and computer are connected, and turn the printer on.
    Note: To display the explanation about the printer port, click 'Help'.
  4. The Printer port window will be displayed while automatic recognition is performed. (After automatic recognition is completed, the window will close automatically.)
    Note: It may take a while to recognize the printer automatically. If the automatic recognition is not completed, re-connect the printer cable again. If you want to select the port, check Select printer port, and click 'Manual' selection.
    When the printer driver installation is completed, the message below is displayed. (Installation of the manual and printer driver, and the system setting change are completed.)
  5. Click 'OK'.
    Note: If a BJ Raster Printer was previously installed, the following message may appear.
  6. Click 'Yes' to restart the system.
    Note: In the Windows 98/Me environment, if a BJ Raster Printer was previously installed, it may be necessary to re-start the computer in order for the USB port driver to be updated. In this case, click 'OK' to re-start the system and begin the installation process again.
if you are not able to do so write me a email
Jun 19, 2008 | Canon Office Equipment & Supplies
Canon PIXMA MP150 All-In-One InkJet Printer Logo
37 people viewed this question
old marine
old marine
