Question about Canon NP 6050 Copier
What is about Error 212 ?
I have error 212. Camera is stop near first sensor.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
E212 Lens sensor or motor problem
remove the glass, check to see if sensor is out of place. turn off copier move lens by hand and turn on does lens move, yes motor is most likely O.K.
does it stop at the sensor and give code? yes replace ( or swap sensor) doesa it still do it? No? replace bad sensor
Posted on Oct 29, 2008
Showing error 047-212
That is an OCT2 error, exit error. If it happens every time or right when you turn on the machine it's either a defective exit sensor or exit pwb. The error itself indicates that the paper is late to get to that sensor so could also be from the registration section below, possibly a registration clutch slipping. Look at the print on the page and see if it's centered correctly.
Feb 29, 2016 | Xerox CopyCentre C123 Copier
Code 212 1995 Volvo 850
If you are using port A2. error 212 is a bad O2 Sensor.
if you are using port A1 error code 212 would be a bad transmission and it would behave quite badly.
Mar 23, 2015 | 1995 Volvo 850
When i switch on ma toshiba e studio 212 its showing me error c26. how can i fix it
it is cis unit error check connection between cis unit and main board otherwise replace cis unit ribbon OR cis unit OR main board
Feb 06, 2014 | Compatible Toshiba T1810 For E Studio 181,...
New memory card put it in and it said card error formatted it and it still says card error
I see that the Fujifilm Finepix Z2 model is 6 years old. Do the cards that you are using say SDHC? If so your camera is probably not compatible with them. Try using a regular SD card (no HC) and that might solve your issue. Fujifilm might also have a firmware update that can make your camera work with SDHC cards. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10001
212-673-8400
Jul 01, 2011 | Fuji FinePix Z2 Digital Camera
Lens error message when turning power on
Did you drop this camera anytime in the near past , if so then it apparent that the barrel assy is off aligment , jammed or broken. Very common problem with dropped cases. If not then you have a sticky/defective motor/sensor which is not allwoing the barrel to complete it startup cycle. There is nothing much as user you can do to sort this problem out , instead take it to a camera reapir centre. best of luck
May 12, 2009 | GE A830 Digital Camera
E212 Error code
"E212" Lens problem (sensor, motor)lift document feeder and look inside. is the lens stuck? when turned on it goes back and forth to check where it is
Aug 11, 2008 | Canon NP 6545 Copier
Error 211, 212!!!
Hi Antonyo,
The codes you are getting (211- 212) relate to the boiler tank behind front panel.
210 Temperature probe short circuit Check probe cable (plug contacts)
Replace probe(rinse tank)
Install probe correctly
211 Temperature sensor interruption See 210
212 Actual boiler temperature too high Contactor welded
Incorrect sensor / defective sensor
Check probe / cable (Contact plug II XA5)
Hope this helps ,regards KIT
Jun 06, 2008 | Meiko DV 80.2 Dishwasher
Error code 212
Verify that the phone line is ANALOG, not DSL
Aug 30, 2007 | Panasonic Panafax UF-790 Plain Paper Laser...
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Canon NP 6050 Copier Logo
117 people viewed this question
old marine
old marine
