How to connect wireless router, Netgear WGR614, to my computer?
    Genius:
  • 1,142 Answers
4 steps to set up your home wireless network
1.
Choose your wireless equipment
The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
Shopping list
• Broadband Internet connection
• Wireless router
• A computer with built-in wireless networking support or a wireless network adapter
A wireless router
The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
A wireless network adapter
Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
2.
Connect your wireless router
Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
How to connect wireless router, - wireless_chart.jpg Next, connect your router to your modem:
Posted on Oct 29, 2008
  • Maanita Chadha
    Maanita Chadha Oct 29, 2008
    Note: The instructions below apply to a Linksys wireless router. The ports on your router may be labeled differently, and the images may look different on your router. Check the documentation that came with your equipment for additional assistance.
    If you currently have your computer connected directly to your modem: Unplug the network cable from the back of your computer, and plug it into the port labeled Internet, WAN, or WLAN on the back of your router.
    If you do not currently have a computer connected to the Internet: Plug one end of a network cable (included with your router) into your modem, and plug the other end of the network cable into the Internet, WAN, or WLAN port on your wireless router.
    If you currently have your computer connected to a router: Unplug the network cable connected to the Internet, WAN, or WLAN port from your current router, and plug this end of the cable into the Internet, WAN, or WLAN port on your wireless router. Then, unplug any other network cables, and plug them into the available ports on your wireless router. You no longer need your original router, because your new wireless router replaces it.
    Next, plug in and turn on your cable or DSL modem. Wait a few minutes to give it time to connect to the Internet, and then plug in and turn on your wireless router. After a minute, the Internet, WAN, or WLAN light on your wireless router should light up, indicating that it has successfully connected to your modem.
    3.
    Configure your wireless router
    Using the network cable that came with your wireless router, you should temporarily connect your computer to one of the open network ports on your wireless router (any port that isn't labeled Internet, WAN, or WLAN). If you need to, turn your computer on. It should automatically connect to your router.
    Next, open Internet Explorer and type in the address to configure your router.
    You might be prompted for a password. The address and password you use will vary depending on what type of router you have, so refer to the instructions included with your router.
    As a quick reference, this table shows the default addresses, usernames, and passwords for some common router manufacturers.
    Router
    Address
    Username
    Password
    3Com
    http://192.168.1.1
    admin
    admin
    D-Link
    http://192.168.0.1
    admin
    Linksys
    http://192.168.1.1
    admin
    admin
    Microsoft Broadband
    http://192.168.2.1
    admin
    admin
    Netgear
    http://192.168.0.1
    admin
    password
    Internet Explorer will show your router's configuration page. Most of the default settings should be fine, but you should configure three things:
    1.
    Your wireless network name, known as the SSID. This name identifies your network. You should choose something unique that none of your neighbors will be using.
    2.
    Wireless encryption (WEP) or Wi-Fi Protected Access (WPA), which help protect your wireless network. For most routers, you will provide a passphrase that your router uses to generate several keys. Make sure your passphrase is unique and long (you don't need to memorize it).
    3.
    Your administrative password, which controls your wireless network. Just like any other password, it should not be a word that you can find in the dictionary, and it should be a combination of letters, numbers, and symbols. Be sure you can remember this password, because you'll need it if you ever have to change your router's settings.
    The exact steps you follow to configure these settings will vary depending on the type of router you have. After each configuration setting, be sure to click Save Settings, Apply, or OK to save your changes.
    Now, you should disconnect the network cable from your computer.
  • Maanita Chadha
    4.
    Connect your computers
    If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows XP will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
    Note: The steps below only apply if you're using Windows XP Service Pack 2. If you're running Windows XP and you don't have Service Pack 2 yet, plug your computer into your wireless router and download and install Windows XP Service Pack 2.
    Windows XP should show an icon with a notification that says it has found a wireless network.
    Follow these steps to connect your computer to your wireless network:
    1.
    Right-click the wireless network icon in the lower-right corner of your screen, and then click View Available Wireless Networks. If you run into any problems, consult the documentation that came with your network adapter. Don't be afraid to call their tech support.
    2.
    The Wireless Network Connection window should appear and you should see your wireless network listed with the network name you chose. If you don't see your network, click Refresh network list in the upper-left corner. Click your network, and then click Connect in the lower-right corner.
    3.
    Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
    4.
    Windows XP will show its progress as it connects to your network. After you're connected, you can now close the Wireless Network Connection window. You're done.
    Note: If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key.
How do i add aditional routers to gain access to the network from a detached shop using wireless
Connect your addition routers to NetGear WGR614 Wireless Router port ,Use NetGear WGR614 Wireless Router as a switch ....
Check if it works
Thanks
Snadeep
Mar 08, 2011 | NetGear WGR614 Wireless Router
HAD UNPLUG MY PERSONAL ROUTER TO GO WIRELESS WITH THE CABLE COMPANY , NOW WAS VERY DISSATISFIED WITH THE WIRELESS AND ASKED TO JUST CHANGE TO TURBO AND I WOULD RECONNECT MY NETGEAR WGR614 WIRELESS ROUTER....
Connect Modem to WAN Port on Router
Connect Computer to LAN port
Checked Lights on Router
if the i-Lights amber Powercycle the Whole N/w
then if i-Green check Internet for Wired
then Loginto Router and Do Wirelesss Settings
Scan and Connect to Wireless N/w
Sep 29, 2010 | NetGear WGR614 Wireless Router
Netgear wireless wgr614 is configured and the ports wired connected and is working ok while wireless portion the laptop running vista says connection is limited and unable to browse
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Apr 07, 2010 | NetGear WGR614 Wireless Router
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Xbox360/netgear WGR614 V9 connection issue
Do you have encryption enabled on your router? If so you will need to enter the encryption key of the passphrase in the network setup of the xbox 360
Sep 19, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Router setup
Verify the physical connection. From the modem, it should be connected to the router's Internet port, then your computer must be connected to port 1 on the back of the router. Then do a power cycle, then try to run the setup CD. If it doesn't work, you need to manually configure the router. You may need assistance from Netgear tech support. Call their toll free number
Jun 20, 2009 | NetGear WGR614 Wireless Router
Can't access configuration for Wgr614 v5 Netgear Wireless router
Since you cannot ping the router, first thing to do here is to reset the router by pressing the reset button of the router for 30 seconds while power is On and then after the reset power off the router for 5 seconds and then when the router is already power On try to ping the IP of the router using a computer that is wired to it if still cannot be ping better contact Netgear support if the router is still underw arranty and have it replace...
Dec 22, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Problem
dear leetheone,
your network wireless is not properly set up. you have to properly set this, try using the windows wireless wizard and follow the prompts.
sid
Dec 02, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
964 people viewed this question
David Payne
David Payne
