Question about HP Compaq Business Notebook 6910p - Core 2 Duo T8300 / 2.4 GHz - Centrino with vPro - RAM 2 GB - HDD...
Hp compaq 6910p BIOS Bypass
A blue screen comes up displaying a Power-on password lock every time i startup, i don't remember ever putting a password lock or i just cant remember what password i used. im wondering if theres a way to bypass this BIOS password or maybe thers a default password ?
any help is much appreciated.
  • 3 more comments
  • draygon001 Feb 28, 2009
    I'm having the same problem, I've google searched this issue but could not find anything, please help!!
  • TXWOLFDADDY Mar 23, 2009
    MY KID PUT A BIOS PASSWORD IN OUR HP 6910P NOW WE CAN'T BOOT IT UP PLEASE HELP
  • Anonymous Apr 16, 2009
    bios password problem
  • Anonymous Apr 28, 2009
    same problem
  • marcaveli Mar 16, 2013
    i did those password now they refuse how can i get rid of these puzzler?
I removed the keyboard, unplugged the bios battery, holded down the power button about 30 secs, plugged back the bios battery, assembled the computer, didn't plug the battery and instead of that just plugged the ac adaptor and the bios passwd was gone =)
Posted on Mar 12, 2010
  • Kennedy Mbewe Oct 29, 2011
    Thanx! I did as instructed and it worked!!
  • 37 Answers
Only 2 ways to reset (clear) bios. 1 - is to unplug cmos battery located under keyboard and wait at least 3 days (10 days is recommended) before putting battery back in or AC power.If password is still there then repeat and wait longer. or option
2 - remove motherboard, locate bios chip on the back (upper left hand corner) , just below the bios chip there is a capacitor (NEK jE8) use a volt meter to discharge capacitor. Use the lowest setting like 2.5v, connect ground test lead to ground and hold positive lead to the + side of capacitor. Continue to hold untill you have zero voltage, once you have a zero reading, locate the fuse (M15) , on same side of motherboard, just under the docking station, use same process until discharged, Flip motherboard over and locate capacitor just to the left of the cpu, Use same process until zero, flip back over and return to the capacitor next to the bios chip and test, if zero your good to go, if you still have voltage repeat process until zero reading on both capacitor and fuse. Remember all this is to be done with No power from AC, Battery, and CMOS. Discharge process should take about 20 minutes. Tested and proven 100% and much faster than 3 to 10 days. Remember this will void your warranty. Good Luck
Posted on Jul 16, 2009
  • informaci465
    informaci465 Dec 12, 2012
    I can't find the capacitor Nek jE8 you're talking about, how it looks?? Could you add a precise indication, please?
I've tried the way which is written in the post and i found small thing which solved the problem in 10 minutes.
As is written above is totally right, BUT what you should make is:
No need to wait 3-10 days, it's only 10 minutes, but when u put back the CMOS battery, DON'T PLUG THE LAPTOP'S BATTERY, JUST THE POWER CORD, and try it then
Good luck ;)
Posted on Jan 27, 2010
Amazing.. it works.. All i did was removed the keyboard took out the cmos battery and kept holding power button for 30 secs and with out putting in the laptop battery connect the laptop power cord and turned on the laptop.. and bammm the cmos password was gone
Posted on May 08, 2011
Worked geat thanks ElectronicRe
Posted on Jul 20, 2009
Yes, that's rigth, it works great
Conclusion: to bypass the HP Compaq 6910p bios in 5 steps
1. To remove the laptop battery
2. To remove the keyboard
3. To take out the cmos battery
4. To keep holding power button for more than 30 secs
5. To connect the laptop power cord and turned on the laptop ( without the laptop battery)
Posted on Jul 27, 2012
I had tryed all this, no solution.
Posted on Jun 09, 2016
There is a bios setting with extra strict security which I unintelligibly enabled with a password so long and impossible to remember that I of course didn't. Apparently, if this setting is enabled you can't clear CMOS. According to HP the procedure (if you don't have that security setting enabled) is to remove power battery, the AC and disconnect the CMOS battery for 30 min (make it an hour to be on safe side), then only plug the AC. This will achieve the same as voltmeter trick the guy used above. I'm going to leave it unplugged overnight. If still it prompts me for the password, then I try flashing the bios.
Posted on Dec 09, 2013
  • Dash Riprock
    Dash Riprock Dec 14, 2013
    You know it cracks me up when I hear about people using complicated passwords like they're protecting the launch codes to nuclear missles. Just use a simple 4 digit password, nobody will try to figure it out.
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
Jan 10, 2013 | HP Compaq 6910p Notebook PC PC Notebook
Where dos jumper located on compaq 6910p and how can i remove bios password on 6910p
Most "laptop" computer do *NOT* have a jumper that can be used to bypass a BIOS password.
This is DELIBERATELY done, so that a thief in possession of your laptop cannot bypass your password, and thus cannot use your stolen laptop.
Find your original bill-of-sale, to prove ownership, and telephone HP/Compaq, and ask for Technical Supoprt in resetting the BIOS password.
Jun 20, 2011 | SIB SATA 250GB for HP/Compaq 6910P NW8440...
I have a HP Compaq 6910p with blue lines down screen ? can you help ? Please ; )
Hello there
I had this issue too with a Vaio i had. This means that there is a faulty connection between the ribbonconnecting your LCD monitor to the motherboard. Now, you can attempt to disassemble the PC and check the connection, but this would void your warranty and if you havent done something like this before, then i dont recommend it. What you should do is take it into your local service location to get this fixed.
I hope this helps. Thumbs up always appreciated.
May 06, 2011 | HP Compaq 6910p (GU888US) PC Notebook
How can i remove the power on password hp compaq 6910?
which os your using?if your answer is xp,then go to control panel,then click user accounts,u can see remove password icon.thank you.plz vote me
Sep 24, 2010 | HP Compaq 6910p Notebook PC PC Notebook
I Need Help Unlocking My Hp Compaq 6910p Every Time I Turn It On A Blue Screen Pop Up And It Say POWER ON PASSWORD .... PLEASE ANYONE HELP ME UNLOCK MY LAPTOP!!!!
Unfortunately HP says: "If you forget the power-on password, the computer must be reset at an HP-certified repair center. Please contact HP to schedule a repair. The Drive Lock password cannot be reset. If you lose or forget the Drive Lock password, the hard drive must be replaced. Please contact HP to order a new hard drive. These services are not covered by the warranty."
Sep 13, 2010 | HP Compaq 6910p Notebook PC PC Notebook
I have a laptop hp Compaq 6910p, and by mistake I ...
Its too risky for a user to open the laptop, access the mainboard and reset to its factory setting..
Very dangerous for the hardware too..
My suggestion is to bring your laptop to a credible technician to open your laptop, reset the cmos to its factory, and return the cover properly..
Hope you understand.
Much appreciated if you rate this help.. thanks
May 20, 2010 | HP Business Notebook 6910p Notebook
Power-on password --Computer locked up solid and I do not know how to reverse the option..
So this is because you must have set the password while under a user. Unfortunatly there is not much you can do for this, unless you have also set up to have a 'guest' user. This shouldn't require a password to get in. Otherwisee, contact HP and they should be able to talk you through the step sof bypassig the power=-up password lock.
May 04, 2009 | HP Compaq 6910p Notebook PC PC Notebook
Hp Compaq nx9020 bios password screen
The easy way is to open up the laptop and remove the smal batery from inside for about 15 minute and put it back, the hard way is to dowload KILLCMOS from internet put it on a flopy disk and insert the flopy disk if you have one in your laptop and falow the prompter
Jan 18, 2009 | HP Compaq nx9020 Notebook
Bios password lock
It is my understing that Windows XP was asking for a password and you chenge the one in the BIOS
Now the BIOS is asking for the password that you put when you say you resetted.
Please enter the password that you put in the BIOS and let me know if you are going to get a different screen other then the blue square with the picture of a key.
Best regards
Sep 25, 2008 | HP Compaq Presario SR1220NX (PJ517AAR) PC...
HP Compaq Business Notebook 6910p - Core 2 Duo T8300 / 2.4 GHz - Centrino with vPro - RAM 2 GB - HDD... Logo
24,014 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
