Ferroli optimax HE 31C boiler
No idea how to set the clock no instructions came with it for this
  • 3 more comments
  • Anonymous Nov 17, 2008
    Can't figure out how to set the timer.
  • martyfly284 Jan 10, 2009
    I've got exactly the same problem, nothing in the instruction booklet refers to timer!
  • Anonymous Jan 22, 2009
    fiter didnt no how to work it. nothing in the manuel on setting the time clock.
  • Anonymous Jan 27, 2009
    its ****!
    why not tell people how to set the times!
    you would have thought that was a vital instruction!!!!
  • kev51773 Mar 08, 2009
    No instructions on timer settings in the manuals for any of Ferroli's products.
    Nice one Ferroli, very proffesional.
Setting time is not in manual that we received, however, we did get a separate sheet: Buttons top left-right are A - Clock adjustment B - Operating Mode selecting C - Override Buttons bottom left-right are: D - - E - Programmes F - +
To set clock: 1 - Push A 2 - When the DAY and the CLOCK icons on the LCD are flashing use + and - (D and F). You should set the day of the week (1 = Monday, 7 = Sunday). To confirm the day press A. 3 - The HOUR and CLOCK are flashing use + and -. Confirm with A. 4 - MINUTES and CLOCK are flashing use + and -. Confirm with A.
My LCD is not working correctly, so I have to press the screen gently to see what icons are displaying. Annoying.
Posted on Nov 08, 2009
  • 1 more comment
  • Atikur Patel Feb 20, 2012
    how many times a day can u set it to go on and off, i cant figure that out.
    how many times a day can i set the heating to come on and off from the boiler and how do i do this,
  • rgarford Feb 21, 2012
    I don't have the boiler anymore, but I think it was 8 separate times per day. Rgarford
If its the mini digital clock each day has to be set individually.
Posted on Jan 26, 2009
Hello! I've got a Ferroli Optimax HE Plus 31c boiler with the F37 fault flashing.
Try bleeding the air out of the rads then represure system
Sep 17, 2016 | Heating & Cooling
Ferroli optimax he 31c. brand new system will only heat 3 of 8 rads. boiler on 90c will only burn for 15sec then D2 shows and it cuts out. Why??
it is either your pump is not running or blocked [ debris from installation ect ] or your diverter valve is stuck partially open allowing a little water to pass into the heating system [ usually first rads on system ] it runs for a short while and cuts out because your overheat stat is kicking in because of poor circulation [ it is only running around the primarys in the boiler where it quickly reaches the over heat limit ] temp tends to rise approx 1 deg per second a clear indication of circulation problems.
Dec 22, 2010 | Heating & Cooling
Do you know where I could get the instructions for setting the clock timer on my optimax he 31c
I sent an e-mail to telling them that my Optimax HE 31 C
manual didn't include instructions for the timer, and received a manual via e-mail within minutes.
You probably won't get a reply during the weekend though.
Nov 28, 2010 | Quasar HQ2051TH Air Conditioner
Hi i have a ferroli optimax 31c , hot water works but my heating dont ,it comes on the the heat temp raises to its highiest then cuts of saying A3 AND D2 can you help please
hi had same problem engineer came out and the diverter valve was cloged up sorted it and recomended a system flush plus install a magnet clean whitch picks up debri be 4 it gets 2 the boiler.
Sep 26, 2010 | Quasar HQ2051TH Air Conditioner
Fault code ( nocn ) on a ferroli boiler
if nocn is on the time clock then check the wiring to time clock and if all good then it is the time clock at fault and will need repleacing
Apr 25, 2010 | Heating & Cooling
I have just tried to run my ferroli optimax 31c boiler. The boiler fires up, but then displays a d2 message and the radiators do not heat up. Any ideas what causes this problem and how I can solve it...
D2 is not a fault what that means is delay and 2 refers to CH which means the boiler has gone into standby mode. you need to check that your CH circut is open, there is a filter on the return valve into boiler make sure this is not blocked. If this is blocked the water is just going though the boiler by-pass so then the boiler thinks its up to temp. hope this helps
Oct 07, 2009 | Comfort-Aire RAD-243 Air Conditioner
Problem with heating on ferroli optimax 31c
d2 is the code symbol for delay after central heating. and is not a fault code.. however if this is coming on then stopping the operation of the boiler then it usually points to a sticking diverter valve.
Mar 28, 2009 | Quasar HQ2051TH Air Conditioner
Ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
3,524 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
