I have a 2003 Ford Focus. Recently I was thinking of switching out my stereo, and I removed my current stereo to look at the wiring. (I have since decided not to get a new one) When I put the stereo back in, it stopped working properly. When I put a CD in it played it, but none of the controls work and the display does not come on. How do I fix this?
SOURCE: install a cd player
HERE YOU GO ALL WIRES U NEED PLEASE RATE ME GOOD LUCK WILL WORK GOOD!!!!!!!!
2003 Ford Focus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange/Black (Thick Wire)
Radio Switched 12V+ Wire: Yellow/Green
Radio Ground Wire: Black/Yellow and Black/Green
Radio Illumination Wire: Orange/Black (Thin Wire)
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: None
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): White/Black
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Gray/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): White/Purple
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): White
Right Rear Speaker Wire (-): Gray
SOURCE: 1969 ford mustang mach 1 brake / stop light switch challenge
I installed a new turn signal switch in the steering column, and it fixed my brake light problem. Evidentally the turn signal and brake light wires use the same plug wires. It cost about $70. I would suggest doing this.
SOURCE: 91 Ford Tempo - New stereo won't work ... Please HELP
here is the radio's wire color diagram, u should be able to fix the problem with this info.Fuse box is on drivers side under the dash.
1991 Ford Tempo Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
SOURCE: ford focus car stereo 6006e
you must make sure that the back of the radio has 3 'sockets' The odd one on its own has three wires and this is the one for remotes
