Question about Microsoft Windows XP Professional
Problem with my drive
When I try to open my drives (D,E,F) it is displaying an error message
The F:\ application can not be run in win32 mode
But when I try to open C drive it is opening normally because I have formatted the C drive recently.
can you help to resolve this.
I am using windows XP SP2
    Sergeant:
  • 155 Answers
ur pc infected with spyware or maleware.
u can use to remove these maleware bites, super anti spyware.
this is the best removel that r free avlbal in market.
Posted on Sep 21, 2009
  • 30 Answers
You can open d,e,f from the top adress menu. first move all the files to anu other local disk and empty one local disk, so that u can save ur data. now format that disk which showing mesage. after formating the drives in this way, they can open. now you can restore your files
32 win files is problen
Posted on Aug 05, 2009
Cannot open C: & D:
Your system is infected with a virus. Please Scan it in the safe mode. Post results here.
Mar 26, 2009 | Microsoft Windows XP Home Edition
Removal of win32mode of hard drives
While researching this problem, it seems that the most likely cause is a virus called FUNNY UST SCANDAL.....it is mostly an annoyance, not too evil, they say.
Please back up your data!
Some people recommend using a noob killer program to kill the virus, but when searching online for one, I come up with very sketchy sites, use at your own risk!
Others have recommended the following site for answers:
http://www.edmartechguide.com/2007/11/funny-ust-scandal-aviexe-remover.html
Then there are these anti virus programs to try, one is free, other a trial, both good:
http://www.eset.com/download/free_trial_download_eav.php
http://www.avast.com/eng/download-avast-home.html
FINALLY.......I found a jumble of instructions to try to fix the problem, and they are as follows.
I have not had this problem myself, but it looks like a messy one, good luck!
Go to Start/Run and type :
reg.exe add "HKCRDriveshell" /ve /d "none" /f
then type:
regsvr32 shell32.dll
If this doesn't work - try this
Problem
when you open any drive letter from your pc it gives the following error
c: application can not run in Win32 mode
d: application can not run in Win32 mode
Solution
To correct and solve this error follow this procedure
Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
Stop wscript.exe process if available by highlighting the process name and clicking End Process.
Then terminate explorer.exe process.
In Task Manager, click on File -> New Task (Run…).
Type “cmd” (without quotes) into the Open text box and click OK.
Type the following command one by one followed by hitting Enter key
del c:autorun.* /f /q /a
del d:autorun.* /f /q /a
del e:autorun.* /f /q /a
c, d, e each represents drive letters on Windows system. If thereare more drives or partitions available, continue to command byaltering to other drive letter. Note that you must also clean theautorun files from USB flash drive or portable hard disk as theexternal drive may also be infected.
Type “regedit” (without quotes) into the Open text box and click OK.
Navigate to the following registry key
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionWinlogon
Check if the value name and value data for the key is correct (thevalue data of userint.exe include the path which may be different thanC drive, which is also valid, note also the comma which is also needed)
“Userinit”=”C:WINDOWSsystem32userinit.exe,”
If the value is incorrent, modify it to the valid value data.
Dec 30, 2008 | Microsoft Windows XP Professional for PC
D:\setup.exe is not a valid win32 application
I don't the problem in the drive, please try to copy the file to your desktop then run it again the same error appears, download the installer for your windows then try from the CD
Dec 04, 2008 | Microsoft Windows XP Professional With...
Hard drive problem
it was a virus that you've removed from your drive. This causes the drive not to open automatically. open the drive in the explorer address bar. please rate this answer
Oct 28, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
Error: "The application cannot be run in win32 mode"
click on start>>all programs>>accessories>>communications>>network setup wizard. follow the online instruction to describe yr network to the end u can access yr hard drive
May 22, 2008 | Computers & Internet
Open my system, click mycomputer and then opening only c drive, but D,E,F drives are not opening, if telling application cannot be run in win32 mode ( how can i solve the problems.)
Jan 07, 2008 | Microsoft Windows XP Professional for PC
Open drive
reg.exe add "HKCR\Drive\shell" /ve /d "none" /f
then type:
Dec 18, 2007 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional Logo
151 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
