Question about Lenovo ThinkPad T61 Notebook
My hardrive is not picked up in the BIOS
Im trying to Reinstall Winsdows XP, in the set up the hardisk is not detected what can i do .
    Genius:
  • Lenovo Master
  • 1,250 Answers
Check whether the hard disk is detecting on BIOS or not
Posted on Oct 29, 2008
The computer does not boot into the operating system and displays "Operating System not found."
For that problem, do this first check-up your bios setting.
Power on your PC laptop
, when screen popped up ( press F2, delete etc. ) to get into standard bios Setup you see there if your hardisk drive detected or not detected. if not detected try to open your Laptop PC ( need power off. open cover at the back of your laptop ) check-up your hardisk drive for loose power cable, data cable hardisk Some burn , noise hardisk sound ) if detected, your operating system corrupted. you need to Reinstall your operating system like windows xp, windows 7 or linux base operating system. try that Solution first.
Just let me know if not yet working your laptop PC.
Regard.
Aug 26, 2011 | Toshiba Satellite M30 Notebook
Tried to install win xp but windows cannot detect harddrive harddrive detected in bios
GOTO BIOS and change your hardisk LEGECY MODE
that is show in advance option
Hope this helppful
Jan 12, 2011 | Computers & Internet
By startup fails to see IDE 0 and IDE 2 , says no channel 0 and channel 1. Is it possible that the cmos battery is empty?
Once your powered on the CMOS battery is no longer an issue. If it isn't reading the IDE or SATA channels it could be because they are not set in the BIOS. Check your BIOS setting and double check your cable connections. You also need to make sure, for IDE devices, that one of the drives is set to Master and the other to Slave otherwise they confuse the board and cancel each other out.
Jan 03, 2011 | Asrock P4VM8 Motherboard
Did not detect the additional sata hard disk?
Have you tried connecting the SATA hard-drive to a different computer, just to prove that it is not a "dud" ?
Is the SATA hard-drive getting power?
(It should warm-up a bit, and you make feel it vibrate as it spins.)
Have you tried a different SATA cable between the hard-drive and the SATA connector on the motherboard?
Check the BIOS settings, to be sure that detection of SATA drives is "enabled".
Apr 09, 2010 | Computers & Internet
Can't load xp on hp xw4300. Has sata hdd & ide dvd drive. Xp can't detect hard drive and if press f6 it says there is no floppy drive
replace your cables and try again. if unsuccessful locate your hardrives manufacturer ie: maxtor software MAXBLAST , download the hardrive software utility and ``0 fill`` your hardrive to factory default.
Nov 05, 2009 | Cars & Trucks
My Dell Dimension would not Boot when I try to Boot the power light jush flashes if I remove the yellow and black cable from the power surploy you can here it booting but there is no video
hi there,
well,unplug your pc, try to put back cable supply,try to configure your hardisk on cmos/bios set up,if the hardisk have detected by your cpu,refresh your hardisk,disconnect hardisk ide cable from motherboard and put it back.then try to run again.if windows does not
come out,reinstall your windows again on your cd installer you can fix from repair your system.have a nice day
Jul 06, 2009 | Dell Dimension 1100 PC Desktop
I have a new 8ogb sataII Exelstor hardisk which i
Windows XP does -not- have native SATA support and therefore will not recognize a SATA drive without first installing 3rd party drivers.
To go around this problem without installing drivers check your BIOS. There might be something in there where the bios will emulate an IDE controller.
If not, you'll need a floppy and the sata drivers. A flash drive will also do if the motherboard bios supports legacy USB. To find the drivers, simply go to the motherboards manufacturers website.
Mar 03, 2009 | EPoX EP-8KRAI-X Motherboard
My maxtor drive doesn't work as a slave drive. It is recognized by bios but not by windows XP
Maybe your hardisk is not compatible with xp, was it an old hardisk? Try it with other computer if it detect.
Thanks
Nov 22, 2008 | Computers & Internet
Laptop HP NX9010 will not boot, Will go to bios, powers off after that.
u must have to detect your hard disk.
check u detect your hdisk in bios settings.
then also try to boot option and select hdd .
Oct 15, 2008 | HP Compaq Business Notebook NX9010
Reboot problem..
Easiest possible solutions first:
1) download and install the latest drivers for your video card
2) see if there is an update for the game that causes the problem
3) run memtest86 from http://www.memtest86.com/ to check if your RAM is bad
4) swap out the current video card with a known good video card
Nov 09, 2007 | MSI MS-6366 Motherboard
Lenovo ThinkPad T61 Notebook Logo
201 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
