Question about GE Spacemaker JVM1640SJ Microwave Oven
Surface lights We replace the light bulbs frequently, about 12 in two years. We had the same style Microwave prior to the new one and did not have to change bulbs but once a year (approx). The bulb socket is dropping little black pieces of a plastic material, I think the socket is deteriorating! When the old bulbs are removed they are very black, like they are over heating. Any suggestions.
  • 6 more comments
  • gwshaw Nov 12, 2007
    I replace the lamps several times a year. The lens also cracks. I was told by a local dealer not to us the nite light function and to remove the lens to allow more air to the lamps. Why doesn't GE come out with a fix?
  • Novex Nov 17, 2007
    The bulbs on mine went out...Then when I tried to remove them, the glass broke away from the base. Now I can't seem to remove the metal base from the socket! What a piece of junk...How can I get these out of the socket???
  • southern led Nov 25, 2007
    the socket???
    i have the same problem as novex
  • CrankyBob Dec 02, 2007
    How do you change the surface light bulbs when they separate from the metal socket? Are they threaded? I can't seem to turn them, and I've tried a number of ways!!!
  • cmccmc Dec 06, 2007
    I have this same problem - sockets falling apart. Constantly replacing light bulbs.. etc.. What a pain.
  • CrankyBob Dec 08, 2007
    Thanks Mikey_001. That was one of the ways that I tried to extract the base of the bulb. It almost seemed to be spot-welded into the socket. The thin metal of the base simply twisted itself into a gnarled-up mess that mostly remains in the socket. Now, if someone turns on that light, it will create a short circuit and blow the breaker. I've completely ruined the microwave, and after the holidays, we'll probably replace the whole unit (and it won't be a GE!!!!!!)
  • Novex Dec 10, 2007
    The problem is the housing for the bulb is not very tight, so when you try to turn the broken bulb socket with pliers, the whole unit moves...I don't see any way to fix this, unless you take the microwave apart...I will be looking elsewhere for a microwave next time around...the GE spacemaker line is junk IMO...very frustrating
  • Anonymous Mar 24, 2014
    one bulb wors other doesnot
I also have had a problem with the glass part of the surface light bulb separating from the metal base when trying to change the bulbs under my G.E. Spacemaker Microwave.. I see someone used a carrot or potato but I had not seen this suggestion before I whittled one end of a wine cork small enough to insert into the metal part of the old bulb stuck in the socket. It also worked great and in no time I was able to get the old base out and replace the bulb. I'll save the cork for next time because it seems to happen to at least one of the bulbs everytime they need to be changed. DON'T FORGET TO UNPLUG THE MICROWAVE FIRST!
Posted on Oct 27, 2008
  • LFC58 Dec 07, 2010
    I removed the bottom panel of the microwave (7 screws). It wont fall down because of a couple metal tabs that hold it in place in the back. The light socket can easily be unscrewed and using the outer sides of the pliers I easily twisted the broken light bulb base out. Able to clean it up some as well.
If your socket is not falling apart like CMC''s, then:
1. either unplug your microwave or turn off the breaker at your electrical box
2. Use a needle nose pliers and wedge one end of the pliers between the metal base and the socket.
3. The other end of your pliers should be in the middle of the metal base so you can squeeze the pliers and tightly grab the metal base.
4. now begin twisting in the same direction as unscrewing a bulb (counterclockwise).
5. the metal base will begin to twist up and eventually it will unscrew.
Posted on Dec 08, 2007
Use a potato or a carrot (cut small enough to fit in the whole but large enough where it has to be wedged in tight) apply pressure and turn counter clockwise. This works everytime
  • lerchland
    lerchland Mar 21, 2012
    worked for me!
    Problem Solver:
  • 15 Answers
The socket it self needs to be replace before to much of that plastic comes off.
Posted on Sep 05, 2006
Changed the light bulbs in my ge jvm315 and know the surface light will not turn off ?
This sounds like the control board also called a smart board in some models has to be replaced.
May 02, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Over the range Danby Model dom16a1wdb surface light replacement
a screw at the back side when removed get access to the bulb.Usually 40Watts bulb with1/2 " threaded
Mar 28, 2014 | GE JVM1790SK Convection/Microwave Oven
My microwave heats, but the surface light and interior light don't light up and the turn table doesn't rotate. Everything else seems to be working fine. What is the best way to trouble shoot the problem?
follow this steps and fix it. God bless you
  • Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#6#ixzz2gUUt9D8f
    Sep 30, 2013 | Microwave Ovens
    Replacing old flor 48" tubes
    There are three types of fluorescent 48" bulbs t 12, t8, and t5. they are not interchangable. if you have a fixture that has a t12 type ballast, it will not light up the t8 bulbs. you have to change the ballast to a t8 style. just to clarify, the number stands for 10ths of an inch in diameter on the bulb. a t12 is 1.2 inches, a t8 is .8 inch and a t5 is .5 inch.
    Nov 20, 2010 | Microwave Ovens
    Can I replace the surface light switch on a SCA1000HBB microwave or do I have to call for service?
    From the ever-handy owner's manual:
    1. To replace the cooktop light/
    night light, first disconnect the
    power at the main fuse or circuit
    breaker panel.
    2. Remove the screw from the
    side of the light compartment
    cover and lower the cover until
    it stops.
    3. Be sure the bulb to be replaced is
    cool before removing. Gently pull
    the bulb from the receptacle.
    Replace with a 12 volt, 20-watt halogen
    bulb. Order WB36X10176 from your
    GE supplier.
    4. Raise the light cover and replace
    the screw. Connect electrical
    power to the oven.
    Jan 14, 2010 | GE Microwave Ovens
    One surface light bulb on GE Profile microwave keeps burning out
    I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
    Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Surface and night light bulbs
    If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
    May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
    JVM1460 surface light problem
    We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
    This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
    This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
    Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
    Feel free to contact me directly for more information & help.
    William E. Miller
    prototech@usa.net
    http://www.microwavedisplay.com
    Aug 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Surface Light & Vent Fan Won't Work
    We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
    Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Mar 17, 2008 | GE JVM1440 Microwave Oven
    GE Spacemaker JVM1640SJ Microwave Oven Logo
    1,050 people viewed this question
    Top GE Microwave Ovens Experts
    vince
    D. E. Hev
     Larry
    Larry
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
