Wharfedale PowerCube PC-10 Subwoofer
Problem for Wharfedale PowerCube PC-10 Subwoofer
Wharfedale PowerCube PC-12 Subwoofer Problem
By boyd717 on Oct 29, 2008
I have a PC-12 with a problem in the amp section. The light comes on but the sound is only just audible. I have checked all fuses and inspected the amp well with a torch. I am able to replace any components and can check for voltages if needed. I have tried to source a circuit diagram but am only getting told be the rep company in New Zealand firstly that I cannot have one, and then that she (parts lady) doesnt have one. She wouldnt help me with a contact either. Can anyone help me with a diagram? Even a trouble shooting sheet with some voltage takeoff points? Any help would be appreciated. boyd@wwp.co.nz
Comments:
Oct 31, 2008
- Hi,
The only number I can find is "N1189" or "POWER CUBE 12+" There is a serial number although I would doubt there is a database which would include such? Really looking forward to hearing from you again electech1
Regards
Boyd
Oct 31, 2008
- Hi,
Many thanks. I will have no problem checking and/or replacing any items although I am unable to identify the individual components ie the pre amp transistor. Is there a diagram I am able to download to assist me in this? The part number of the board is 053-1293002110 Part numbers on the ICs TL072CN which I see nteinc have replacements for which is a win. Regards, Boyd
Clarification Request
Posted by electech1 on Oct 29, 2008
whats the model # ?
Solution #1
posted on Oct 31, 2008
Not Rated)
electech1
Rank: Guru
Rating: 88%, 621 votes
ok , what your going to need to do is give me the numbers on the amp IC's , and i will see if they are available , but first you will need to see if the pre amp transistor is failing , to do this leave the power off and unplug from the wall then with a digital multi meter on diode check , check to see if the emitter to base reads about 680- 700 , if it does then its ok but i would replace that anyway because it could be the reason the amp is not amplifying correctly , sometimes they don't act up untill power is applied , then also replace any resistors in line with the input line that do not read thier values( if you need help identifing them let me know and i upoad the codes for them) and also the electrolitic capacitors on the transistor line to the amp
once you have completed these steps let me know if there is a change
you can cross reference you transistor here also maybe the power amp http://www.nteinc.com/
Was this helpful?
Yes
No
Popular Solutions for Wharfedale PowerCube PC-10
Questions and Unsolved Problems for Wharfedale PowerCube PC-10
Do you recommend Wharfedale PowerCube PC-10 Subwoofer?
Answer
Answer
when i turn it on,the dvd tray automatically opens and says "upgrad dvd
Answer
Hello all. I have a set of wireless speakers (Acoustic Research AW877 900 Mhz Indoor Wireless... (More)
Answer
my grandaughter pressed something and now the phone says unregistered. Ihave followed the... (More)
Answer
its been getting quite frustrating considering i've spent quite a bit of money on my sound system... (More)
Answer
Hello, Thanks for your support but main problem is i bought it in Abudhabi, UAE and now i am in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Home Theater... Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
