Question about Tally T6215 Matrix Printer
Paper out LED won't go off
My tally T6215 print has the Paper out LED staying ON after the self test. The printer Loads the paper still the LED come ON and will not allow you do any other thing on the printer. Can you help out and can I get the techincal Manual for this product since I have about 4 of it. Thanks
  • 114 Answers
I had the some problem. and it was on the position of the sensor, i needed to replace the sensor, because he was pointing to a paper hole, the ones used to pull the paper.
Posted on Jan 17, 2007
Am running windows7 and when i try to add a form with 21" width and 30.50" height my form is not added.
The form width you are trying to create is wider than the T6215 is able to print on. The maximum page width that you can print is 13.6 inches, if you try to create a custom size paper wider than 13.6" Windows will not show you this form within the T6215 printer driver. As you can not physically print 21" wide you do not need to define a paper size this wide. Simply create a paper size which reflects the maximum print width or 13.6" You will then be able to print the maximum width the T6215 is capable of and also see this form in the printer driver.
Jan 03, 2011 | Tally T6215 Matrix Printer
Tally t6215 is printing continuously, one line a page. how do i make it print normally?
I would suspect this is happening because the system printing to the T6215 is sending only Line Feed Commands and not Carriage Returns. Access the menu on the T6215 and enable the AUTO CR function. This will cause the printer to append a Carriage Return each time it sees a Line Feed, this should resolve the issue.
Dec 22, 2010 | Tally T6215 Matrix Printer
After creating a new form of size 15 x 12 fanfold in the printer settings option, form is saved but not applied. So after selecting printer in a software, the paper size option of 15 x 12 fanfold does not...
THe T6215 can only print a maximum width of 13.6 inches. If you create a form wider than this Windows will not allow you to select this form within the printer driver as the printer is not physically able to print this wide. Your paper may be 15 inches wide but it is unlikely you will be printing 15 inches, simply create a form whose width is equal to the maximum print width or 13.6 inches. You will then be able to select this form in the printer driver.
Dec 13, 2010 | Tally T6215 Matrix Printer
GenicomTally T6215 line printer not printing on edges
If your still having problems? 1st make sure the gap is not to tight(cause the to ribbon to drag up with paper). 2nd While printing in test mode, carefully lift up or push down on the ribbon where it comes out or where it goes back in the catridge. After doing the 2nd you should see the exact same thing as will stop printing on right and left edges. Remove the ribbon, their are 2 philip screw on the left and right side of the ribbon deck, loosen them(they will not come all the way out, held on by clips) lift the rbbon deck up and reseat it... tighten the screws back down. last you may have some bad ribbons...
Jan 14, 2009 | Tally Line Matrix T6215 Printer
Tally T6218 show paper out even if there is paper. what is the solution
Have to enable techmode (go offline and hold the line feed and enter button for three seconds)
then go into the test menu and do the fault override and turn off paper out sensor and then must calibrate the paper out sensor by checking and verifying voltage with paper in and paper out, this is done on the control panel.
Oct 21, 2008 | Tally Line Matrix T6215 Printer
Cant print from pc
I was using a parralell port i ended up removing the network card and that solved my problem
Aug 11, 2008 | Tally Line Matrix T6215 Printer
Tally printer form feeding continually on its own
When was the last time it was services? It may be nothing more than a dirty paper sensor. Also, some Tally printer sensors require adjusting, it may be a simple matter of adjusting a sensor setting. That would require a technician with the manual and settings chart. Let me know how it goes!
May 01, 2007 | Tally T6215 Matrix Printer
Paper motion fault
This info is from the Maint. Manual for T6212/T6215/T6218.
gp+3ytmzowxemaaaaaelftksuqmcc
xotihxffu1saaaaasuvork5cyii=Sensor is located below the upper left tractor item 99 below. Clean it and make sure the V is facing your holes in the paper. If that isn't the problem? see below how to meter sensors procedures...
0tzegsr+ic4n46ssuqv4el30qgpfj8tqefx2f8bvlqvvrw0muuaaaaasuvork5cyii=imeb+a4pe3uaaaaasuvork5cyii=
ak0nfwmwb8waaaaasuvork5cyii=
Jan 24, 2007 | Tally T6218 Matrix Printer
Tally T6215 Matrix Printer Logo
149 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
