Question about Microsoft Windows XP Home Edition
Wont boot into safe mode, hold up at loading driver acpi multiprocessor PC
I have a laptop with XP Home edition installed as the OS. One day it decided not to boot up properly. When trying to boot normally, it just restarts, due to some kinda problem, obviously... I try booting into safe mode and it stops at loading the acpi multiprocessor PC. I've tried to reinstall the OS, repair it, etc... Doesn't work. Any suggestions?
  • 1 more comment
  • dolphinsgt61 Oct 29, 2008
    I've reinstalled this again and again, repaired with the disk, I've moved RAM sticks already. I will now run check disk command from the recovery console. I'll keep you posted. Thanks
    Didn't seem to work, no sectors were bad, nothing was corrected. Any other suggestions? I"m thinking of running a killdisk on the drive and reinstalling it again.
  • Microsoft Master
  • 1,183 Answers
Try resating the memory modules on the system. check with each memory module one bu one.
If the problem is still there , check the harddrive for errors or bad sectors .
Posted on Oct 29, 2008
  • 191 Answers
Do you have XP bootable CD? If yes goto BIOS settings and select primary booting device CD Drive and save settings and exit. After restarting your system You will be asked to press any key for installing the OS.
My laptop running in win xp home edition sp3 does not boot. it only shows the options to run in safe mode, etc...Last known good configuration... how do i solve this? it doesnt boot.
Try to buy a Windows XP2 cd . The cd key is ( HH8M2 - JV8XT - PGWY2 - 8WV28 - 2B9M3 ). Replace your old OS xp home edition , with Windows XP2 OS. Hoping this would solve your problem sir. Have a nice day..
Aug 17, 2011 | Microsoft Windows XP Professional for PC
My Acer aspire one wont start into normal windows, only safemode
Did your system come with any software? I know when I bought my aspireone it did not. However, You can purchase a thumbdrive with at least 4 gb of space and if you have a copy of windows xp of the same version as that which is loaded on your aspireone (should be windows xp home edition) and you can use a program like magicISO to create a copy of the windows xp cd onto the thumbdrive.
Hope this helps, and I would be more than happy to give you more specific support as needed.
Good Luck!
Jan 06, 2010 | Acer Aspire One AOA150-1635 Notebook
My problem is identical as what is mentioned above. MIne says that "ACPI multiprocessor pc hardware is not recognized by Windows logo. Install anyway?" Should I install it
ACPI is a setting on the BIOS.
If you have problems with it, you can safely disable that option.
Don't forget to rate this answer if it helps.
Dec 06, 2009 | Microsoft Windows XP Home Edition
XP safe mode problems
you could try editing the boot.ini to switch the vista install and xp install.
try this
Mar 14, 2009 | Dell XPS M1530 Laptop
Windows XP Problem
if you got the OS cd, insert and boot from cd and try a repair.
or check for solutions in the solution range i used to fix similar problem from
solution dictionary for fixing all pc problems on htpp://
Oct 29, 2008 | Microsoft Windows XP Professional for PC
Installing xp freezes
If it will only boot in safe mode it means you have a driver conflict.
This is only a suggestion but try fresh reinstalling windows, with only basic xp drivers then install other drivers one at a time rebooting each time you do until you come across the faulty one. remove it or check its for xp not vista research net for correct one
Jul 17, 2008 | MSI K9N6PGM-F Socket AM2/ nVIDIA MCP61V/...
ACPI Multiprocessor PC is trying to install on my friend's computer. It started ocurring after she did system recover. It looks like she now has two hard drives -- one fat32 (?) and the regular drive c. At...
YES, do let it install !
ACPI stands for Advanced Configuration and Power Interface
This is a firmware interface in BIOS, that allows operating systems to call BIOS routines for managing power related
system hardware parameters:
1) CPU mode (Sn states): Run, Suspend, Sleep, hibernate ...
2) CPU Voltage and frequency
3) Fan speed... etc....
Multi-processor PC, means that the firmware has detected a
multi processor system or is confused by the hardware. There
are several conditions that cause this interpretation:
a) A genuine multi-CPU Board with 2 or 4 CPU sockets.
b) A multi-core, single CPU, such as the new Intel
CORE-2 DUO series...
c) Interleaved RAM on a single CPU, with dual buses.
This is OK, and nothing to worry about.
The ACPI interface is very advanced and complex, about 3500
pages of engineering specifications, and most P'sC only use
a very tiny sub-set of its capability.
The ground level ACPI settings and options are contained within
the system BIOS. The best solution is to set them to their
default settings, unless you know what all the settings mean.
To access the BIOS settings, on most PC's:
Press DEL or F1 right after the POST/memory test.
Depending on the BIOS settings, the operating system's HAL
(Hardware Abstraction Layer) may need to install additional
interface and control drivers.
On a desktop, these so called "GREEN" power saving features
are a horrible pain in the neck. and I would disable them all
together, unless you pay $20,000 per months for your
On a laptop, however, these drivers are fairly important to
significantly extend your battery life, so you should enable
If the computer was restored to factory condition, by pressing
a magic "blue" button, these drivers are part of the original factory installation and should be installed, just let the PC recursively do its thing, until it calms down.
Most name brand manufactures provide a hidden partition on
the hard driver, typically a FAT-32, which contains a complete
set of recovery files, unique to the PC model and all the features
it supports.
This restore partition is most often formatted as FAT-32,
because FAT can be accessed using primitive BIOS calls
while NTFS cannot:
1) FAT16 = Original DOS, support drives < 2GB only.
2) FAT32 = Extended FAT-16, for larger drives.
3) NTFS = Windows NT, 2000, XP, and Vista only.
Cannot be accessed before Windows is running.
The manufacturer then provides a boot/ BIOS hook,
activated by their MAGIC or BLUE button, which in turn
un-hides this restore partition, loads Windows PE
(a special pre-install/ repair version of windows),
and then loads the recovery program.
In any event, you need to let the installation/ restore process
finish, including the ACPI install.
After several annoying re-boot cycles, this process will (should)
restore the PC to original factory conditions.
Factory restoration is, however, a very drastic and destructive process. All your settings are lost and (depending on the particular system) sometimes your data as well. I should
be avoided like a biker on a bad day.
It is a good idea to back-up everything possible, before taking such a drastic step, and I prefer to use an external USB drive for doing this. Also this step should only be used as a last resort.
However, in your case, all the DRASTIC and LOSSY part has
happened already, so you have no choice but to proceed and
let it finish. Once the restoration is complete, the FAT-32
partition should disappear, that is it will be hidden again.
Do not damage this partitions, unless you own a set of factory
repair CD's !!!
It is also a good idea to request the FACTORY repair CD's for
your machine from the manufacturer and keep them in a safe
Once you have the recovery CD's, you can delete the hidden
recovery partition, and use the recovered space for more
useful things, such as data or applications.
To do this, you need a partition manager tool, such a Norton's
Partition Magic or Acronis tools. Norton's bought the original
tool from Power Quest, and royally phluquified it, so I much
prefer Acronis these days.
Also after you PC is fully restored, go into the power settings
in the control panel (or via the screen saver settings) and
configure the ACPI as you wish. But you must install it first.
Hope this answers all your questions,
please rate my answers.
Jul 16, 2008 | Microsoft Windows XP Home Edition
Fail to load files during text mode setup
Maybe its a software problem, have you tried putting in a bootable XP installation CD? After the bios boot and it asks you to boot to CD, press R for repair, it will try to repair your OS, and if it is an OS problem ,then it will boot once again... If not you can try formatting your HDD and reinstalling windows...
Mar 10, 2008 | Toshiba Satellite A65-S126 Notebook
OS load failure.
The bluescreen saying about the ACPI, I had the same problem at work with a older computer. Next time you get the bluescreen read everything it says.
It tells you to press a button, I'm not sure thats why I'm telling you to read the bluescreen (windows 2000 or xp) it was f5 or f8.
You press f5 or f8 I think it was f5 since f6 is to load custom drivers.
So you press f5 when it asks you to press f6 This disables the ACPI subsystem in the setup and you should be able to install windows 2000 without any more problems. If its not f5 read the bluescreen thats where I got it!
Good luck, keep me posted and tell me if theres anything else.
Feb 23, 2008 | Toshiba Satellite A65-S1065 Notebook
6480iPTD notebook- boot problem
Video drivers not loaded for that laptop, in safe mode reload the video drivers.
Jan 26, 2008 | KDS Valiant 6480iPTD Notebook
Microsoft Windows XP Home Edition Logo
362 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
