Question about Hitachi 46W500 46 in. TV/DVD Combo
Removing the screen from Hitachi 46W500
I need to remove the screen from my 46W500. I removed all the screws from the sides and top and the screen pulled away except for the bottom. What is holding the bottom?
Pop the speaker cover off and then remove the screws holding the two small black covers on either side, then you will see the screws holding the bottom of the screen.
Posted on Mar 18, 2008
SOURCE:
The tv model number is hitachi 46w500. the dvd picture is stuck on one screen and now the dvd won't eject.
Remove the power off and let the set rest for about few hours. Now try out to see if the DVD releases.
If the picture is still with the old memory of thelast scene then the processor has hung up.
You must have to release the DVD by opening panel if a reset of an overnight power on the set does not work.
Oct 30, 2010 | Hitachi 46W500 46 in. TV/DVD Combo
How to remove back of 32 a hitachi flat screen
The front panel does not really come out, the rear panel will have to be removed by removing all the screws and the stand. The chassis is screwed down to the front panel bezel. May I ask the reason for removing the front panel? The front and rear case can be separated by uisng thin flat blade screw driver.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 13, 2010 | Hitachi 32HDL51 32 in. HD-Ready LCD...
Rca tv is blurry
2 types. If wooden top rail of screen surround: remove end screws of top rail by removing caps over screws on upper front sides. Remove the two screws. Remove top wooden screen bezel piece. Now pull up and out screens. If sceen surround is plastic one-piece all-around: remove speaker grill board. Remove screws along lower front of screen bezel. Pull bottom of screen bezel out a 1/2 inch. Lift up on screen bezel to remove entire screen assembly.
May 06, 2010 | RCA P52926 52" Rear Projection Television
I know the screen comes off I have seen the repairman remove it before but I don't remember what he did and we would like to remove the dust off the inner screen can you help us.
You should be able to work it up another inch or two. Use firm and steady pressure. It's a tight fit... then you should see four screws on the back side of the frame. Remove all 4 screws and then hold the top edge firmly... slowly pull the entire screen out of the frame. Remeber when you put it back in, there are some pins along the inside top edge of the frame, as the frame is pushed back down to its original possition you may have to flex the top frame out a bit to allow the pins to go back into the holes. this is all visible from the top side, provided you have good lighting. I nope this helps...
Jan 10, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Can am Hitachi 50GX49B rear Projection TV be diassembled to move it to an area where narrow stairs prevent the complete unit to be mover through this area? I have noticed that inside there are 3 screws on...
Removing the screen is your best bet -
1 Remove speaker grill
2 remove 4 screws holding the screen frame
3 then lossen the bottom corners where the screen meets the frame by pulling outward (some force is required) and work your way upwards towards the top (two people may be required for support)
4 tilt the loosened frame(20-30degrees) from the bottom up and the top shoul lift and seperate from the frame.
After the screen is of you'll be able to tell what to remove next.
Good Luck!
Sep 21, 2009 | Hitachi 50GX49B 50" Rear Projection...
Spider web behind front of screen
Take the front speaker grill, and ther will be a few screws on the bottom of the screen. Remove those and lift the screen up and out.
Feb 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Removing screen from Hitachi Ultrasound TV
you take off the back cover all the screws down to the bottom and remove the speaker cover then remove the screws that hold the screen in on either side of the speakers and you should be able to remove it. I am not 100% certain that is how Hitachi does it but that is how my Sony is and my Panasonic was
Jan 10, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi ultra vision, removing the front screen
Remove front bottom cover then remove all screws holding screen on Now slide screen up and out.
Dec 25, 2008 | Hitachi 53UDX10B 53" Rear Projection...
How to disassemble an old Hitachi projection TV (model 53sbx59b)
To remove the protection screen and lens from my Hitachi model 53SDX89BA:
1) Remove the speaker cover from the bottom. It is attached by velcro.
2) Remove the 4 screws on 4 plastic tabs on the bottom of the screen frame.
3) Remove the 4 screws on the 4 metal tabs on the bottom beneath the screen frame.
4) Pry the bottom corners loose with a wide blade screw driver and work both sides of the screen frame away from the case from the bottom up. CAUTION: The top does not snap away as the sides do. When the sides are loose let the screen frame hang down vertical and lift the screen frame straight up.
5) The protection screen and the lens will come off together.
When reinstalling the screen frame perform the steps in reverse. Be careful when resnapping the frame back onto the case - there are two small wooden support blocks on the bottom. Don't try to force the frame back on until you are sure the bottom of the frame clears these block. You may find it easier just to remove them temporarily until the frame is reattached.
Apr 13, 2008 | Televison & Video
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Hitachi 46W500 46 in. TV/DVD Combo Logo
198 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
