Question about Synercard Asure ID Enterprise (932011001) for PC
Import Database - No tables
Am importing excel and access files using the Import Wizard into the 'Data Centre' of Synercard Asure ID Enterprise. Have done it many times before, no problems.
Step 3 is "select table" with information. Every way I've tried it, no table shows up in the selection window. I cannot select anything so cannot move to the next step.
Have tried changing formats and location of files and tried restarting computer.
Thanks for your help!
  • 3 Answers
Your table may be open in another application. Try closing the database or file, and then try to the import process again.
Posted on Oct 17, 2014
When I try to import a file into a new session, the sample rate box pops up. I click Ok on 44100, but then another box pops up about but rates and other foreign jargon about PCM and raw data and stuff. I...
This procedure is a common one for the Audition 1.5 when trying to import (or open) an unknown file type. At most of the cases the result of this kind of import is wrong. Could you please clarify me what is the file's extension that you're trying to open in order to guide you to get (for free) the proper import plug-in (the extension has to be like wav, or mp3, or m4a, or mp4 etc)
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 28, 2011 | Adobe Audition 1.5
Tip
Import Error 0x80048003 on DVD-VR with Pegasys and TMPGEnc Products
Typically a DVD-VR media format is in ISO9660, UDF v1.02 with an import label of DVD-RECORDER and the preferred Media format is that of DVD+RW that can be written on without finalizing a erased several hundred times before it fails.
If you are trying to import a DVD-VR created on a DVD Recorder into your PC for editing and re-encoding you might get this error with either the excellent TMPGEnc Authoring Works v4.0; TMPGEnc v4.0 Xpress or the TMPGEnc MPEG Editor v2.0
When using the preferred media format of DVD+RW It might be able to find the VIDEO_TS folder and software like VSO Inspector OR Nero ROM's Info Tool may also indicate that the DVD-VR has track information on it as shown below
Possible Faults :
  • Corrupt VOB or VOB's this is the most common fault.
  • The DVD+RW reads in the DVD recorder as BLANK means that it has not authored the media correctly.
  • Faulty DVD+RW media that can only be used a finite number of times, you need to bin it and buy new media and try to record the Video again for re-import.
  • The AUDIO_TS folder is missing.
Possible Solutions:
Create an ISO file using Lightning's Excellent ImageBurn then import the DVD-VR from a mounted drive you can either use Slysoft's Virtual CloneDrive OR Alcohol 52% FE to do this make sure that you read at about X2.4 or slower and check the ignore read errors shown in red in the Settings Menu
Use DVD Shrink great user guide by Mr. Bass there also to try to import as much of the media as possible it might fail however but you will find out where the DVD-VR fails on the import it will also save the files that it has imported correctly for you which is a bonus and save them in a folder called DVD_VR or whatever the DVD Recorder labels the media as.
In this case DVD Shrink throws an I/O read error 19 seconds before the end of the track or 65% good files fails on 66%
This case shows a DVD-VR that has 10 good files however the last three VOB's of the DVD-VR format are unreadable hence the 0x80058003 error on DVD-VR import.
If you use Total Commander you can copy the 7 good files to the Harddrive and use evilmaster's excellent VOBMerge v2.51 remixed to join VTS_01_1 to VTS_01_2 together as the IFO files are still intact this will work and you will be able to import the resultant file for editing.
This is not ideal however you will still be able to retrieve about 50% of the video data from the corrupt DVD-VR from the first 2 complete Video Object Blocks (VOBs)
Even if your VOB's are not consecutive like in this example you can still join them and import then using the Add File Option or add the individual VOB's as long as the video that you want to edit is on the good VOB then you are OK.
Each one contains typically 30 mins of SLP DVD-VR video (MPEG-2 @ 720 x 576 4,380kbps 25fps) you may also need to change the file extension of merged.vob to merged.mpg to avoid any import errors although in my experience VOBs will import correctly in the latest versions of the software despite the warning shown below.
on Apr 05, 2010 | Pegasys DVD Author (123594)
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
Hi, i have a problem here regarding the subject. when i try to open a mp3 file an error appears and ask me to make it PCM Raw data as file type and do the asterisk thing and try open the file again, i...
I don't have the manual for this, however, the program may be INCAPABLE of opening an MP3 file.
One will find that many programs will not open every file type.
OFTEN one will find they have to use the "Import" feature instead of open to accept the file type they have. Often these programs will output a file type or export it in a different format.
So see if they might have an "Import" function.
May 11, 2010 | Adobe Audition 1.5
How can we import id information with a preleading zero.
import into what application - excel, access other set the field to be a text field
Mar 19, 2010 | Identity Asure ID Express ID Card Software...
Is there an users manual for Asure ID 2009
http://www.fargo.com/users_guides_pdf/AsureID_2009_User_GuideRev.1.2_English.pdf
Oct 23, 2009 | Identity Asure ID Enterprise Full Version...
Verify database
If your database is located on a mapped drive, then check your drive letter for the mapped drive. If it is "X:" for example, then your software will need to be pointing to the X: drive within the SetDBStr.exe setup tool.
That tool can be accessed by exploring your C: drive as follows:
c:\program files\asureid\program
You should run SetDBStr.exe and specify "Custom Configuration" (second choice) and then browse to the database on your mapped drive. Hope that helps!
May 18, 2009 | Synercard Asure ID Enterprise (932011001)...
Mail Merge won't print
AppleWorks is a quirky and hopelessly outdated product. I am aware that a few people have an extreme fondness for it however.
It should only have taken minutes to import data, but don't do it in AppleWorks - they stopped making it years ago and it is unsupported and non-standard.
I have just taken two AppleWorks databases, - one older and one newer that needed to be combined. I exported them as tab delimited text and then imported them into Excel (You could use Apple Numbers - the modern equivalent to AppleWorks). Because the to db's had different headers, I imported them into two different Excel docs first and moved the columns around so the matched first, them copy each column over to the 'master' excel sheet.
You can either use the basic database tools in Excel, or once your data is combined and in this kind of data form, it is easy to import a .xls, or .csv into a new database program, such as Filemaker.
If you do copy over the data to Excel, any merge function - for label printing etc. has to be done in Word (or at least up to Word 2004). I was thrown by this until I realised you have to do this. Once a merge doc is set up with the right labels, it worked beautifully. Typical MS though it is a wholly unintuitive process.
Copy and importing data should be done with attention to care obviously. Make sure you have your original AW files backed up before you start.
May 20, 2008 | AppleWorks 6 for mac
Dreamweaver CS3
Import Microsoft Office documents (Windows only) You can insert the full contents of a Microsoft Word or Excel document in a new or existing web page. When you import a Word or Excel document, Dreamweaver receives the converted HTML and inserts it into your web page. The file’s size, after Dreamweaver receives the converted HTML, must be less than 300K.
Instead of importing the entire contents of a file, you can also paste portions of a Word document and preserve the formatting.
Note: If you use Microsoft Office 97, you cannot import the contents of a Word or Excel document; you must insert a link to the document.
  1. Open the web page into which you want to insert the Word or Excel document.
  2. In Design view, do one of the following to select the file:
    • Drag the file from its current location to the page where you want the content to appear.
    • Select File > Import > Word Document or File > Import > Excel Document.
  3. In the Insert Document dialog box, browse to the file you want to add, select any of the formatting options from the Formatting pop-up menu at the bottom of the dialog box, and then click Open. Text Only Inserts unformatted text. If the original text is formatted, all formatting will be removed.
    Text With Structure Inserts text that retains structure, but does not retain basic formatting. For example, you can paste text and retain the structure of paragraphs, lists, and tables, without retaining bold, italics, and other formatting.
    Text With Structure Plus Basic Formatting Inserts both structured and simple HTML-formatted text (e.g., paragraphs and tables, as well as text formatted with the b, i, u, strong, em, hr, abbr, or acronym tag).
    Text With Structure Plus Full Formatting Inserts text that retains all structure, HTML formatting, and CSS styles.
    Clean Up Word Paragraph Spacing Eliminates extra space between paragraphs when you paste your text if you selected Text With Structure or Basic Formatting. The contents of the Word or Excel document appear in your page.
Source: Dreamweaver CS3 Help
Feb 06, 2008 | Adobe Photoshop 7.0 for PC
TOC Page Numbers Don't Display in PDFed Document
Apparently Adobe doesn't consider importing pagination data from Word documents to be important enough to code Acrobat to find Microsoft's record of the page numbers and import them properly. I would suggest using Adobe Acrobat 7's page numbering feature, and simply number your pages appropriately, to match your table of contents.
Nov 13, 2007 | Adobe Acrobat Professional 7.0 for PC
Synercard Asure ID Enterprise (932011001) for PC Logo
145 people viewed this question
Top Synercard Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Synercard Computer and Internet Expert? Answer questions, earn points and help others
