Question about Sunpentown Platinum Trim Cabinet Thermoelectric Wine and Beverage Chiller - 20 Bottle Wine Cooler
Does not chill drinks
i bought this thermoelectric wine cooler, only to find out later that it only cools to 12 degrees minimum, which is not cold enough to drink.
Is there a way of improving the efficiency of the unit (turning it to minimum just makes it so noisy!)?
Are there any devices i could add (I am an electical engineer by trade) i can buy to make it better (heat exchanger or something off the shelf)
  • hawkesy Oct 29, 2008
    Correction - its not the Sunpentown wine cooler. its some 'made in china' Homewell brander 28 bottle cooler.
  • hawkesy Oct 31, 2008
    i meant 12 degrees centrigrade, 12 degree Celsius = 53.6 degree Fahrenheit. Thats not cold enough.
You wrote that the wine cooler "only cools to 12 degrees minimum" I don't understand the problem?
12 degrees is really cold, in fact its freezing.
Posted on Oct 31, 2008
What is the correct temperature for beer? Or wine. Or pop? Please
Hi Laraine:
Beer:
- If you're British, warm. Canadian, wet. Otherwise, who cares?
Wine:
- white - chilled, red - warm. If you're Canadian, wet.
-Pop - cold, but if you're Canadian, stick to beer and wine so....... Who cares?
Cheers
Jun 06, 2016 | Furniture
Plugs in but wont turn on
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - ‎42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - ‎In stock
Jan 20, 2016 | Koldfront 12 Bottle Stainless Steel...
Does a thermoelectric wine cooler have a ventilation system?
Absolutely, every wine cooling system has to have a ventilation system that will channel the heat generated in the operation, outside of the unit, including the thermoelectric wine cooler.
Aug 14, 2012 | Furniture
What is a thermoelectric cooler?
A thermoelectric wine cooler contains a cooling node. When an electric current passes through the node the outside of the tile heats up and the inside of it cool down.
Why should I buy a thermoelectric wine cooler as opposed to a compressor model?
There are many reasons to purchase a thermoelectric cooler including, but not limited to, being quiet and eco-friendly. Personally, I prefer thermoelectric coolers because they don't vibrate. The vibration of a compressor cooling system can cause the sediments in the wine to be disturbed and affect the flavor/taste of the wine.
Jul 31, 2012 | Furniture
What is a thermoelectric wine cooling system?
Thermoelectric cooling is best used in small wine coolers. Small fans from inside the cooling fridge evenly dispense cool temperatures throughout the interior of the unit.
How do you use a breville wc15xl wine chiller
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
Apr 10, 2009 | Breville WC15XL Compact Wine Cooler
Sunpentown Platinum Trim Cabinet Thermoelectric Wine and Beverage Chiller - 20 Bottle Wine Cooler Logo
541 people viewed this question
Top Sunpentown Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Sunpentown Refrigerator Expert? Answer questions, earn points and help others
