Question about BenQ DC S30 Digital Camera
Error 100 it comes up on my camera as error 100 in blue, it beeps twice then simply turns of. if there is anything you advise me to do i would be very grateful. thankyou.
0 characters
1 Points
Casio Exilim won't turn on
My guess, only support people know what the two beeps mean.
Try to remove the battery and after a few seconds insert it again.
Then again switch on. If the error returns, contact the dealer or Casio support. Still it could be you think the battery is charged, but the capacity is not enough to power up your camera.
Dec 31, 2013 | Casio EXILIM EX-ZS10 Digital Camera
The camera turns on but it is all blurry. And when I turn it off it beeps twice and the lense won't go all the way in.
Sounds like your lens assembly is damaged, it isn't able to twist the lens appropriately in order to fully close it or to focus in on the images you want. You will more than likely need to have the camera serviced. In most cases if it isn't under its warranty it will be a repair ranging close to $100, which is typically the cost of a new camera. Check your date of purchase as camera's come with at least a 1 year manufacturer's warranty, and hopefully you can get set straight.
Mar 13, 2011 | Samsung S860 Digital Camera
Canon ixus 60 - lens error restart, restart camera
Dear God, It was like a comedy. I got on the whale boat, after having the Canon ixus 60 for 4 years. I've never had any error messages. The whales came 10 feet from the boat and twice raised their head, and no camera, just the beeping and the error message: lens error; restart camera. How do you restart the ixus 60 Canon digital camera, anyone? Please help!! Thanks, Maui, Hawaii. Aloha!! & Mahalo.
Aug 26, 2009 | Canon Digital Cameras
Samsung S760 wont turn on properly - beeps twice lens comes out n in, then goes off n beeps again
it may be a lens error. mine does that all the time. make sure you remove the batteries or make sure it can't turn on while it is in a jam packed place like a purse or the case for it because the lens could get jammed. it sounds like that's what your problem is.
May 28, 2009 | Samsung S760 Digital Camera
Focusing Still Photos with SD870 IS
If you check page 45 in the manual, you'll see that the orange light during the half press indicates that the flash is turned on. A single beep means that the camera is having difficulty getting a "focus lock" (usually when shooting in low light conditions). See page 100 of the manual for suggestions on how to improve the chances for getting a well-focused picture.
May 01, 2008 | Canon PowerShot SD870 IS Digital Camera
Kodak p850 Help!! error code
also having same problem after 18 months of no problems. As well, camera will not read memory cards which I have used in this camera almost since new. Format card, still no read. Sometimes when I take first photo, lens retracts as though camera is powering off but then changes it's mind and is o.k.
Jan 09, 2008 | Kodak EasyShare P850 Digital Camera
Error message 5e02
Turn on your camera, when the lense is opened, hold it till the blue screen appears, extend the lense to his maximum forcing it a little bit then when you turn off your camera, the noise won't be here. Turn on again your camera and hopes it works. I tried it on my camera, works well at the first try then again the error, i did it twice holding the lense when you turn it on, then it worked perfectly.
Hope it works for you.
P.S : my english isn't well but i hope it helps.
Oct 17, 2007 | Olympus Stylus 710 Digital Camera
Switches off whenever I try put it into photo mode
This is the lens motor not responding Nothing for you to do there any repair is likely to be expensive Contact Panasonic for further advise a New camera perhaps
Aug 02, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Zoom error
it needs to have the lens replaced, it´s a new camera, just send it to repair they will do it for free
Dec 02, 2006 | Olympus SP-700 Digital Camera
BenQ DC S30 Digital Camera Logo
Top BenQ Digital Cameras Experts
Are you a BenQ Digital Camera Expert? Answer questions, earn points and help others
