Question about Ricoh Aficio 450 Copier
POWER SHUT DOWN
WHEN I BEGUN TO COPYING THE MACHINE WAS QUICKLY SHUT OFF AND AFTER A FEW SECOND IT IS RESTART AGAIN AND SO ON.
  • Brian Bell
    Brian Bell May 11, 2010
    Can you tell me what brand and model the copier is please?
  • 162 Answers
They must have defective solder in the power supply.
Inspect and repairs the solder in the board of the power supply.
Posted on Sep 14, 2009
  • 183 Answers
Here you can't do nothing the machine has problem with the power supply board and it need to be fixed by electronics technician
Posted on Jul 15, 2009
How do i fix the error code sc 322 of my ricoh 3045 copy machine?
Have to open the Laser unit and clean the laser diodes carefully.
Dec 28, 2015 | Ricoh Aficio 3045 Digital Copier: 45cpm....
The orange on/off button lights up. however the start/pause button does not.
It's hard to tell by the way you've phrased the question whether or not the button is doing what it is supposed to do, or if it is just the light indicator that is not working. So, I will answer both scenarios. // Press start button fully until you hear machine start; (usually less than one full second). In other words, hold button in until ''start'' is _heard_. After start has begun, holding button for 3 full seconds will ''pause'' the cycle. After ''pause'' pressing button again (just like first time) will restart cycle (i.e. ''take it off pause''). But while ''paused'' holding the button in again for any longer than a fraction of a second will cancel the wash. // TO CLARIFY: Press button for approx 1 second to start wash. After start has begun, pressing button for 3 seconds will ''pause'' wash. While ''paused'' pressing button again for less than a second (i.e. ''quick press of button'') will ''resume'' wash. Also, while ''paused'', pressing button for longer than a second (usually 3 seconds) will cancel the wash. // If the machine is (otherwise) working correctly, and your complaint is a light not lighting, then it is just a bad LED light. Best bet is leave it alone. Or, you could buy a new switch if the LED is _inside_ the switch. If the LED is on the control panel, then do yourself and big favor and don't mess with it.
Aug 15, 2015 | Washing Machines
Can't restart windows 7 on my dell d610, did a format on the hd, re-loaded the windows 7 disc, everything runs great until I shut it down then it won't restart
Recently a put windows 7 on my latitude d610 only problems I had were incompat. Drivers (wifi, sound, graphics.) all were fixed with googling those drivers with windows 7 because this hardware is not compatible with 7 but seeing as it is a restart thing,
Check the drivers u have installed try to see if any need updating or are no compat.
Nov 19, 2012 | Dell Latitude D610 Notebook
My Toshiba A215 is frozen. The power button does not turn off. Cntrl/alt/del does nothing Mouse and claock are frozen as well. How do I fix? I was trying to download video files to ext hard drive. Window...
hello, press down on power button and hold it for about 10-15 seconds and it should shut-off, wait for about 5 seconds before turning it back on. If for some reason holding down power button doesn't shut it off, then simple unplug the power from the laptop and then flip the laptop upside down and locate the battery eject lever(little slider switch to kick out the battery) slide it to the unlock position and remove battery. Once again wait for about 5 seconds and plug the battery back in and then the power adapter and power on your laptop.
Tip: try copying few files at a time to get a better success rate and avoid any failures.
I hope this helps.
Regards & happy holidays.
Amar Sondhi
Dec 24, 2009 | Toshiba Satellite A215-S5822 Laptop
HP Pavilion dv6700 Entertainment wont boot
1. Power on (NO Disc.)
2. Press Pause
3. Enter 314159(with remote)
Display will show "FF"
4. Quickly press "0" (for all region)
5. Press pause
6. Power off and powere on after 20 secs.
Dec 09, 2009 | HP Pavilion DV6700T Notebook
POWER SHUT OFF
you probably have a power supply problem.
Oct 29, 2008 | Office Equipment & Supplies
Macbook cdrom stuck in copy mode
hold down power button until your machine shuts off. then power back on. you should be fine. if the cd is stuck in the drive, restart the machine and hold down the mouse button while restarting - the cd should eject itself.
Sep 02, 2008 | Apple MacBook PC Notebook
Ricoh Aficio 450 Copier Logo
81 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
