Question about Technics SL-MC7 110-Disc CD Changer
How to fix my 110 disc cd player
When I turn it on it just keeps repeating 'checking discs... checking discs... and never stops. I recently moved and some cd's got jammed in it. I think it caused the damage. Is there any way to fix it? Where can I take it to have it fixed? I live in Burnaby BC.
  • CLOZIE Dec 01, 2008
    magazine/changer mechanism jammed not working. Same problem as "MNJM". Thanks for anyone that can help with this.
    CLH
2 Suggested Answers
techman
  • 3130 Answers
SOURCE: Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
Technics sl- mc6 110 disc changer just keeps saying checking disc dosnt respond to of the buttons
this is a common thing to happen when the laser gets dirty or out of tracking , as it cant "see" any of the disks so it's "checking disk" forever
Mar 05, 2015 | Technics SL-MC6 CD Player
Technics 110 Disk compact disc player constantly shows reading disks???
1, It thinks a disc is in the unit, 2 it may have a dirty laser lens if a disc is in the unit. It need a service call to fix the unit. It could be a Pickup is burned out but that needs to be determined.
Dec 11, 2012 | Audio Players & Recorders
BOSE WAVE MUSIC SYSTEM PLAYS CD BUT DOES NOT TURN OFF
It is probable that the battery will need to be changed, this the first step to find out if additional work is required.
May 17, 2012 | Bose Wave music system with multi-CD...
Tech SL-MC410. Continously displays "Checking Disc"
When the unit is saying "Checking discs" and neither goes further nor turns off (just says "Off" but doesn't), the reason is still the main belt (accessible from the top as soon as you lift the cover) that is too loose. When the belt is way too loose, the unit doesn't move at all, if the belt is little too loose, the player-unit will move a bit, but there is not enough torque on the gears to reach the end position (where the player unit is secured against movements).
May 07, 2012 | Technics SL-MC400 110-Disc CD Changer
Hi. I recently bought a Sony CDP-CX355. Until a few days ago it was working fine. Suddenly, the player stopped reading the discs. It grabs a disc as if its going to play it, but just reads it, and then...
This happens when your laser is not able to read the data of the disc. Either u are using disc which the player cannot read or the disc is not readable. If your CD player is not reading the discs which it used to read earlier then CD player laser head has to be replaced.
Aug 14, 2010 | Sony Audio Players & Recorders
When I try to play a disc, the message
Hi there! Depending on when last the CD Player was serviced, I would think that the laser is at fault and needs replacement. However it may also be a mechanical fault. The only way to know for sure is to take the cover off and to see whether the disc turns at least a little bit before moving to the next. Also check whether the disc lifts into position properly and moves freely. If all the above proves OK, then the laser is probably at fault. Remember that there is current running through the unit so please stay away from any wires and boards when checking this. Best Wishes and Good Luck. JUS004
Aug 21, 2009 | Technics SL-MC400 110-Disc CD Changer
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Technics SL-MC7 110-Disc CD Changer Logo
47 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
