Question about Sony KP-48V80 48" Rear Projection Television
Part of the picture is out of focus
When our Sony was turned on today, about 8" of the screen on the left side is out of focus, you can see (2) of everything from top to bottom, the green & red mainly, they are not lined up, the rest of the picture is ok.
  • 2 more comments
  • Dave Miller Sep 12, 2006
    Your diagnosis was perfect, I purchased the IC's on E-bay and replaced them in less than 2 hours, My wife is very happy, Thanks again. Zappy
  • Anonymous Nov 09, 2007
    The whole picture is out. It is bleeding reds and greens. It will not show a picture.
  • Anonymous Sep 27, 2008
    I have the same problem with just the left side showing double
  • nelsonjleedc Dec 22, 2008
    My whole picture is blurry.
  • 3,130 Answers
Typical convergence problem. Its 2 ICs that start with stk standing up on the printed circuit board, and this is not a repair for the layman. No insult intendedb there is a lot of High Voltage inside these sets neven when they are unplugged. You also need to unsolder ansd resolder the IC's when they are replaced.
Posted on Sep 05, 2006
Sony KP 51 HW 40 Blue Lines
Some of these sets had problems with bad picture tubes; there is something you can do to try to correct this without replacing any parts.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You may have a bad blue picture tube but there is a way to deal with this first----the set has a black plastic block with six controls---three are Focus(red,green,blue) the other 3 controls are Screen controls(red, green, blue) Someone has to remove the entire piece on the front of the set below the screen(usually a plastic part) most of the time it is secured with 3 screws on either side of the set in the back; once you remove the screws the entire piece should pull out(pull from right to left(it will not fall off or come out easy--it is held in with several large plastic pegs) With it removed there is an inspection plate with 4 screws-----the screen/focus block is behind it.
You need to look very closely at the block to identify the focus versus screen controls----one row left to right will be marked Focus and the other row left to right will be marked screen------YOU need to locate the Blue Screen control(they are black like the block) With the set on(be careful) go to a video input clip_image001.gif with nothing connected---if you see a blue screen as well as the input number turn the BLUE SCREEN CONTROL SLOWLY TO THE LEFT UNTIL THE BLUE is gone.
If this cures the problem you may only be buying yourself some time----if the blue picture tube is bad sooner or later this trouble may return----I have seen sets where this was adjusted and the set worked for a year or more with no repeat of the trouble----replacing the blue tube would likely cost you 400 - 500 parts and labor.
I do this here for free so if this has helped you rate this solution as I do this here for free.
Dec 01, 2009 | Sony KP-51HW40 51" Rear Projection...
Half of the screen is clear and left side of the screen is blury
Its a Common Problem with Projection Tv's ~ If your flash focus is not correcting the problem, And It can Not be Adjusted in your service menu: under Manual Convergence, your IC chips and maybe a few resistoirs may have failed and need to be replaced!... onegeo
Jul 07, 2009 | Sony KP-46WT500 46" Rear Projection...
Red horizontal curvy lines
You need to turn the voltage on the red tube down slightly, also you would need to adjust focus to compensate for the lower voltage to the red tube. On the left and right bottom side of speaker cover are two round covers, take them out and there are 2 1/4" hex screws take them out carefully take cover off, there is another service cover same hex screws remove. You will see the focus block on the right side, tubes are labled on block. 2 knobs for each tube. Make voltage adjustments while tv is on a black screen, then for focus, turn color all the way off in the menu, and adjust focus until it looks right in black and white. These adjustments should only be very small; if alot of adjustment is needed, you may have other issues.
May 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
I have a 2001 sony wega 36 inches and the channels
If you are comfortable with working inside the set where there are potentially dangerous high voltages present, you can probably fix this easily. Open up the back and remove it. Plug the set back in and turn it on. In the lower right hand side will be the flyback transformer (large red wire coming out of the top and going to the side of the picture tube). DO NOT TOUCH IT!!! On the back of the flyback should be 2 "knobs". One will be marked screen and the other focus. Carefully adjust the focus until the picture is clear. When you do this, go beyond the clear point and work the control back and forth a few times before settling in to the focused spot.
That should resolve the problem.
Apr 07, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Double picture & color problem
see if the mirror in side is broke or cracked
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony projector kp53hs10
I recently had this same issue. If you remove the speaker pannel in front of the set, you will see a block with 6 knobs on it, just to the right of the center panel. This is called a focus block. 3 knobs on top which control the voltage going to each tube, and 3 on the bottom are for fine tuning focus for each tube.
If your problem is the same as mine, it is a convergence problem. and due to the fact that the picture is turning off, says that one of the tubes is not getting enough power.
1. Make sure the screen is blank, ex video 2 with nothing on. It's easier to tell.
2. very slowly, one at a time turn up the knob on the left top, should control red, untill you start to see lines come on the screen, then turn back just till they dissappear, and you see a black screen again.
3. continue with the second knob on top, just the same as the first.
4. And continue with the 3rd knob on top right just the same.
5. when you're finished, turn off the set, then back on, let is set for a min or 2, then hit the FLASH FOCUS.
If the problem persists, it most likely is a IC chip.
Best of Luck
Nov 20, 2008 | Sony KP-53HS10 TV
KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Aug 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-48V80 48" Rear Projection Television Logo
115 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
